F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Spec check before pulling trigger on new wheels/tires
GetBMWParts
      04-09-2024, 07:38 AM   #1
Stucks
Stucks's Avatar
172
Drives: 2017 F30 340i Xdrive
Was looking at a new set of wheels and tires. Sanity check that i would have no issues with fitment on my F30 340i xdrive lowered on H&R sport springs with factory EDC.
18x8.5 et30 front and 18x9.5 et35 rear.
Been going back and forth between tire sets, depending on total diameter and what tire manufacturer would work within the 1% limit of xdrive.
235/45-18 front, 265/40-18 rear
or
235/40-18 front, 265/35-18 rear
Current: 2017 F30 340i xdrive
Previous: 2008 e92 335i coupe: RB turbos, mach 116 race fuel, methanol, alot of boost.
Previous: 2003 Honda Accord V6 coupe: AEM V2, zex 75 wet shot (sold)
      04-09-2024, 11:20 AM   #2
alohasurftoad
3126
Drives: 440i gran coupe w/mppsk
https://f30.bimmerpost.com/forums/sh....php?t=2094283
in the thread above, kif30ki has 265/40/18 @ ET40 at the rear. your setup will poke 5mm more...
235/40/18(25.4")+265/35/18(25.3") since the diameters are smaller than OEM, speedo will read higher and odometer will accrue higher, than actual.
imo, the rear offset needs to be at least ET40 but ET42-45 would be better
are those the only sizes for the rims you're thinking about?
      04-09-2024, 12:58 PM   #3
Stucks
Stucks's Avatar
172
Those are the only sizes for the rims I was considering. I'm really after obtaining another lightweight set of 5 spoke style wheels. I had LTW5's on my e92 335i for years. Haven't come across any others that style that would work without using spacers or going custom.
      04-09-2024, 02:29 PM   #4
alohasurftoad
3126
how about enkei kojin? 18x8.5 ET35 (20.6#), 18x9.5 ET45 (20.25#). these offsets would be way better for looks and also handling and you can run 245/40/18+275/35/18. if i think of something else, i'll let you know.
if you're staying with the wheels you desire, i'd probably go with the taller setup, but it might rub the fenderlip occasionally under compression.
      04-15-2024, 09:54 AM   #5
Stucks
Stucks's Avatar
172
Hmm, I will look in to those.
If I wanted to just simplify things and run a square setup with 255/40/18s, What 18x8.5 or 18x9 offset would achieve the best flush visual while avoiding too much poke? I see 18x9 et30 all the time on here, but do you think it might poke too much with that tire size?
      04-15-2024, 12:07 PM   #6
alohasurftoad
3126
255/40/18 @ ET30 will poke, especially up front.
for a 255/40/18 to be flush the offset needs to be around ET38 front, ET35 rear
255/40/18 lightly stretched on 18x9.5 ET35 square is also possible. in this case the lip will be 1.3mm more poke than the 9" ET30 but the tire shoulder will have 5mm less poke due to 5mm higher offset.
lately, there's a few of you asking the same fitment questions and i've grown tired of linking specific posts. this apex thread contains members with specs that you may be considering to determine poke/flush/etc...
https://f30.bimmerpost.com/forums/sh....php?t=1393886
jmanB45154.50
      04-18-2024, 07:21 AM   #7
Stucks
Stucks's Avatar
172
Well my order for the Enkei Kojin in 18x8.5 et35 and 18x9.5 et45 was cancelled due to being discontinued so its back to the drawing board. My search for a good 5 spoke wheel not requiring spacers or custom offsets continues.
      04-18-2024, 11:26 AM   #8
alohasurftoad
3126
with your original planned rims use 225/45/18(somewhat stretched) on 18x8.5 ET30 front + 255/40/18(lightly stretched) on 18x9.5 ET35 rear OR
do 255/40/18 lightly stretched on 18x9.5 ET35 square, such as in the link below...
https://f30.bimmerpost.com/forums/sh...&postcount=460
      05-01-2024, 02:44 PM   #9
Stucks
Stucks's Avatar
172
Since I am lowered on H&R sports and the car in that link is stock suspension, would that negate an 18x9.5 et35 fitting without rubbing?
Alternatively, if I were to go with an 18x9 et41 in front, it would require a spacer I believe.
      05-01-2024, 04:49 PM   #10
alohasurftoad
3126
if you have lowering springs with stock(or aftermarket OEM replacement) dampers, a 255/40/18* on 9.5" @ ET35, will still fit without interference. i will try to find links with this setup. here's one...
https://f30.bimmerpost.com/forums/sh....php?t=1991818
with most 255/40/18* on 9" @ ET41, you will not need a spacer for interference, however you may use a 3mm-5mm spacer if you desire a more flush fitment. here is 255/40/18 MPSAS4 on 9" @ ET42
https://f30.bimmerpost.com/forums/sh...&postcount=463
*in a given size, a tires broadness may vary depending on brand/model
f30post
