04-06-2024, 05:25 AM | #1 |
Rep 65
xDrive and 9.5" vs 10" rim for 275/35 tire
Im considering to buy wheels front: 9x18 +tire 245/40 and 9.5" or 10x18 +tire 275/35 for xDrive car. Can the different stretch ratio 245/9(=27.2) and 275/ 9.5"(=28.95) vs 10"(=27.5) have any impact on the circumference and potentially on xdirve? Respectively is the 9.5" rear rim fine for this combo with the 9" front rim?
04-06-2024, 07:46 AM | #2 |
1161
Rep 3,190
9.5 is fine for a 275, it won't be stretched or bulging. 245 on a 9 will be slightly stretched which would make the diameter slightly smaller And closer to the 275. However, I would run 245/45 and 275/40 unless you are significantly lowered.
Lada-16.00 |
04-07-2024, 12:40 PM | #3 | |
Rep 65
THANKS
Does it mean - smaller diameter and bigger width eg 250? Quote:
https://ibb.co/vkVTmHL |
04-08-2024, 11:34 AM | #4 | |
1161
Rep 3,190
04-08-2024, 12:41 PM | #6 | |
Rep 65
04-08-2024, 12:58 PM | #7 | |
3126
Rep 4,374
245/40/18(25.7")mild stretch+275/35/18(25.6")mild pinch, mild lowering req'd 255/40/18(26.0")*+285/35/18(25.8")pinched due to min rim width req'd. will have slight sidewall bulge *=treadwidth same as rim width with no pinch or stretch |
04-08-2024, 01:16 PM | #8 |
Rep 65
This is almost like the stock setup
for the 285 tire is a 10" rim needed I guess. And Im afraid of the front wheels rubbing and the rear ones will pop out |
04-08-2024, 01:20 PM | #9 | |
3126
Rep 4,374
here is strawhatdan with 255/40/18 on 9" ET30 front, 285/35/18 on 10.5" ET40 rear. 285/35/18 on 9.5" ET45 will be 5mm more tucked and sidewalls will bulge on 9.5" compared to vertical on a 10.5". https://f30.bimmerpost.com/forums/sh....php?t=2057469 235/45+265/40 are both 10mm wider and 0.3" taller than stock . Last edited by alohasurftoad; 04-08-2024 at 01:28 PM.. |
04-08-2024, 01:54 PM | #10 |
3126
Rep 4,374
https://f30.bimmerpost.com/forums/sh....php?t=1991818
in the above link mclovin69x is running 255/40/18 on 18x9.5 ET35 front + 285/35/18 on 18x9.5 ET45 rear |
Lada-16.00 |
04-09-2024, 06:37 AM | #11 |
Rep 65
alohasurftoad
which wheel tire combo would you recommend to me from the PROTACK ONE (for F31 340iXdrive with stage2-3) ? The car is lowered on the KW PnP suspension, and neg camber front/rear ca -1,7° Im generally afraid of rubbing so wanna be 100% sure I will not. Some people here claim even the 275/35 rubs Thanks https://www.pro-track.de/en/wheels/Protrack-ONE/?feature_categories_id=15&filter_categories_id=15& filter_fv_id[1][]=8&value_conjunction[1]=0&filter_fv_id[2][]=10&value_conjunction[2]=0&value_conjunction[3]=0&value_conjunction[4]=0&filter_fv_id[5][]=32&value_conjunction[5]=0&filter_url=en/wheels/Protrack-ONE/&cPath=130_15&language=en Last edited by Lada-1; 04-09-2024 at 06:53 AM.. |
04-09-2024, 12:09 PM | #12 | ||
3126
Rep 4,374
255/40/18+285/35/18 on 18x9 ET30+18x10 ET40 Quote:
although increasing tire width(and compound) is one solution for traction. even on an x-drive, you should consider an LSD if you want to put big power to the rear wheels efficiently. |
