BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Non-M and M front tension arm (not bush) difference (if any)?
      06-10-2014, 05:17 AM   #1
bradsm87
596
Drives: F25 LCI xDrive30d
Hi,
I've seen various comparison pics of E8x/E9x M vs non-M front tension arms (aka upper control arms) and can't see any difference other than the bushes. Turner Motorsports's site says that the M3 bushes alone are an upgrade for non-M cars, meaning that they can be fitted to the non-M arms. Also the same BMW Motorsport bush lists compatability for both M and non-M models, further confirming the cross-compatibility of the bushes. I understand that the part numbers for the arms are different but is it only because they are only available to buy with bushes fitted and obviously the bushes are different?
I can't seem to see a difference in length on comparison pics but IF the non-M arms are a touch shorter but can take the M bushes, then I see that as THE best option as it'll increase caster when used with M lower control arms.
TRW M3 tension arm bushes are $20.30 each at ecstuning. That along with a decent shipping saving to AUS for me looks like the way to go!
Who has seen both items together and can confirm any differences?
Cheers,
Brad
      06-11-2014, 05:55 PM   #2
bradsm87
596
Surely someone has upgraded to M3 arms and done a good visual comparison between the two?
      06-11-2014, 07:44 PM   #3
drunkenup
215
Drives: 2009 135i, 2021 F150
I did the mod two months ago and upon visual inspection, the M tension arms are in fact shorter in length by maybe an inch than the stock tension arms. There also seems to be some difference in the clearance angle near the center of the arm. I have photos if you really really need them.
      06-11-2014, 07:59 PM   #4
bradsm87
596
Photos would be great as all photos I've found on the net show the length to be extremely similar and any perceived difference in length in the pics looked to be because of the angle that the photo is taken from, the angle of the ball joint or the arms not being lined up together properly.
Also can anyone confirm by measuring that the outer shells on the bushes are the exact same outer diameter (or the inner diameter of the alloy bore)?
      06-12-2014, 04:44 PM   #5
mikex25
mikex25's Avatar
397
Drives: Grey thing
I don't think only the bushing creates a better steering response in which the stock control arms are made of sheet metal thus a greater chance of flexing. While the m3 arms are made of one piece aluminum.
      06-12-2014, 05:23 PM   #6
bradsm87
596
That's the case for the rears but not the fronts.
These are the arms in question (courtesy of robc1976 on BB forum)
[IMG]http://www.german**********/images/imported/2013/02/step12m-1.jpg[/IMG]
Edit: e90post have obviously listed g e r m a n b o o s t as a 'sware word' and will not display the pic. Just replace the stars with '**********'.
      06-13-2014, 11:55 AM   #7
drunkenup
215
I have two photos of the arms lined up for difference. I will post them when I can. When you have one M arm on and a stock arm on the other you will see a noticeable difference in toe.
      06-21-2014, 04:34 AM   #8
bradsm87
596
Still very interested to see some hard evidence on this one. Preferably measurements or at least a photo of both arms with the photo taken nice and square indicating the difference.
      06-21-2014, 07:10 PM   #9
LMB335IS
Sua Sponte
LMB335IS's Avatar
1299
Drives: 2013 LMB 335is
2013 BMW 335is  [8.84]
Scroll through the pics. The difference is fairly obvious between the two. http://www.e90post.com/forums/showth...3+control+arms
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
      06-21-2014, 10:33 PM   #10
bradsm87
596
The comparison photo there doesn't have them lined up properly so it's impossible to judge.
      06-21-2014, 11:19 PM   #11
LMB335IS
Sua Sponte
LMB335IS's Avatar
1299
Dude, I'm telling you there's a difference. I have both in my garage. I don't have the time or the inclination to make a photo essay to illustrate the difference but the OEM and M3 parts aren't even close to the same even with the naked eye.
      06-22-2014, 12:29 AM   #12
bradsm87
596
You're talking about the Tension arms and not the lower control arms yeah?
Bushes aside, what is the difference between the arms? M3 ones shorter?
      06-22-2014, 12:34 AM   #13
bradsm87
596
Also is the outer diameter of the bush shells exactly the same?
      06-22-2014, 01:51 AM   #14
bradsm87
596
Just to be crystal clear, I'm wanting to know if there is a difference between these two arms other than the bushes. I want to press M3 bushes into my arms because there does not appear to be any difference at all between the arms themselves. There isn't even an M badge on the OEM M3 tension arms. The logo that TRW grind off is a BMW logo, not an M logo. I believe they're the exact same forging but haven't had both in my hands to be 100% sure.
      06-23-2014, 05:06 PM   #15
simon
simon's Avatar
65
Drives: E92 Montego Blue 328i
I just did a lot of suspension work this past weekend, including M3 arms, and I can confirm the tension struts are exactly the same, except for bushings
feuer4277.00
DLag30103.50
      06-23-2014, 07:11 PM   #16
bradsm87
596
Excellent. Thanks Simon. Very handy to know.
Since mine has fairly low mileage and the ball joints are still all good, I'll just get a pair of bushes.
      06-23-2014, 07:27 PM   #17
banshee28
Drives: 2006 330i 6MT ZSP
I am interested in the same question. What year did those come off of, maybe that year used different arms? I have a 2006 330i sport and also want to do this same M3 arms/bushings upgrade soon. If my arms are the same and only the bushings are different then maybe I would get some Rogue Engineering bushings and have them pressed in.
      06-23-2014, 08:27 PM   #18
simon
simon's Avatar
65
Came off an '07 E92 328 with sports package. I searched the part number for the right tension strut on realoem.com and sure enough the E90 330i does come up. I'd verify with the last 7 of your VIN on there if you're curious, though. Looks like the tension strut on my car (with hydraulic bushing) is the same for 328, 330, 335, 335is per realoem.
http://www.realoem.com/bmw/partxref....r=&series=E90N
edit: for whatever it's worth, the ball joint at the end was extremely loose compared to new arm. It didn't necessarily have any detectable play, but the difference between the two was shocking. The original arms had 102k miles on them
      06-24-2014, 08:13 PM   #19
banshee28
Thanks, will be looking into this very soon.
      06-30-2014, 10:44 PM   #20
andrey_gta
andrey_gta's Avatar
300
Drives: 130i coupé ;)
2008 BMW 128i  [10.00]
FYI Turner lists the large bushing as an Upgrade, even over the MyeleHD version.
Fortunately Lemforder and TRW sell the bushing separately for very cheap - see ECS tunning for an e9x M3.
Keep in mind these bushings need a pro to change and I've seen one instance here where the bushing hole was deformed.
Originally Posted by banshee28 View Post
... I would get some Rogue Engineering bushings and have them pressed in.
The motivation to do the whole arm is that the small ball joint also wears out
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff
"The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is
      10-16-2017, 09:30 PM   #21
fmorelli
fmorelli's Avatar
162
Drives: Atacama Yellow 35i
I don't know why people use the "upper control arm" terminology. It's confusing. In classic BMW suspension design, the front to back locating arm was called a "thrust arm" on the older cars (e.g. E28/E30) as the arm came from a rear chassis mount to the hub assembly, thus "thrust". When switching to the new design, mounting to the front of the chassis, it is now under "tension" and hence "tension strut".
Filippo
2011 35i MT Atacama ... lots of bits. Full Öhlins TTX custom suspension. Build thread.
Build sheet. Currently finishing suspension, fuel, ignition system with Barry Battle @ 3DMMotorsport.
      10-17-2017, 11:16 AM   #22
The Nightman
Cometh
The Nightman's Avatar
1092
Drives: Boy's Soul
[img]https://lh6.googleusercontent.com/-j...IMG_3519_2.jpg[/img]
Old thread but for future readers I want to confirm that the M3 and non-M tension struts are the exact same dimension. I was able to run M3 tension struts with non-M wishbones.
The M3 tension struts alone yielded better steering response and feel but also more NVH. I'm hesitant to recommend them to everyone, especially if your roads are poor.
Appreciate 4
feuer4277.00
ornicar136.00
DLag30103.50
