2010 2011 BMW 5 Series Forum F10 Need help plzzzzzz I beg |
01-19-2024, 10:17 PM | #1 |
Rep 12
So pretty much I start the car and dies, noticed that the charge pipe does a suction type of thing. Feels like the car has no air 🥲
All started when I replace the air filter |
01-19-2024, 10:34 PM | #3 |
1778
Rep 441
Drives: 2016 F10 BMW 535i M Sport
Clean your Sensor, check your install for leaks.
01-19-2024, 10:36 PM | #4 |
Rep 12
But why the charge pipe does a suction everytime I start the car plus the boost pipe is deformed ( under side)
ChiltiCoatl891778.00 |
01-19-2024, 10:55 PM | #5 |
1778
Rep 441
Check all your plumbing for air leaks. was that an aftermarket air filter? or an OEM? Make sure everything you removed and reinstalled is properly seated.
Hornet-01163.50 |
01-19-2024, 11:01 PM | #7 |
1778
Rep 441
Check all your plastic Air connections that you removed, also, clear your fault codes after you run through your connections, then try again, and see which codes may possibly pop up again. The First code you have indicates an air leak. If you have something that is deformed or broken, you may have to replace that.
01-19-2024, 11:10 PM | #8 |
Rep 12
Later today I’ll clean the intercooler to see if something is clogged
01-19-2024, 11:35 PM | #9 |
1778
Rep 441
Broken Plastic Piping is normal eventually as the car ages, and even more so if it is under the weather or parked outside.
02-08-2024, 04:20 AM | #10 |
1778
Rep 441
Any update on this?
03-19-2024, 03:19 AM | #11 |
Rep 12
Went to an Indy shop he told me the turbo is bad just because the wastegate was open when the car was off and he told me it supposed to be closed 😭
Can someone verify this? |
03-19-2024, 08:53 PM | #12 |
1778
Rep 441
What year is your 5er? they do have rebuild kits, also, if you have an PWG, it is common for them to fail due to the mechanical part that opens and closes the wastegate, starts to rattle and then fails, common issue with the earlier N55 Turbos.
03-19-2024, 08:56 PM | #13 |
1778
Rep 441
03-19-2024, 09:06 PM | #14 |
1778
Rep 441
Please verify fitment by providing your vin number. For a smooth order process, if you want a second opinion I would take it to another to make sure, however, he may be spot on on your diagnosis.
03-21-2024, 11:23 AM | #15 | |
226
Rep 554
The cart is way before the horse on this one. The fact you unplugged the MAP sensor and it ran means it's not seeing the discrepancy in air caused by a leak somewhere, and allowing it to run. A pipe or vacuum hose is loose or unplugged, probably when you changed the filter. If you pulled up on the airbox lid enough when changing the filter it could have loosened the intake tubing to the turbo. Make sure it's still connected to the turbo. You've got unmetered air going in somewhere. |
Hornet-01163.50 |
03-21-2024, 07:25 PM | #16 |
1778
Rep 441
Did you get that Air Leak fixed? you said you had something broken/deformed a few months ago.
04-10-2024, 06:20 AM | #17 |
164
Rep 129
Drives: BMW 550 xdrive
the best way to look for an air leak is to use smoke
04-19-2024, 04:16 PM | #18 |
Rep 12
So pretty much it was the wastegate actuator, got a oem used one but it came open, I put pressure and closes but idk if they came like that or is supposed to be all the way closed
