      08-10-2008, 07:55 PM   #23
wnta135
wnta135's Avatar
Drives: 2008 Sedona Red 135i
8mm Request List
Who wants to buy 8mm spacers with hub extenders?
1. mikeo - black RAD bolts
2. wnta135
3.
4.
5.
      08-11-2008, 07:54 AM   #24
vmcllc
12
Drives: Faster Than The Speed Limit
Keep the list growing...I would need at least 20 guaranteed buyers to get you good prices...and depending on how many is on the list I may even be able to throw in a discount on top of the future set price of these..kinda an introductory price... As far as what the price will be...I will just have to wait and see how many jump in on this...I do have some prices that I want to obtain, but this is dependent on how many takes there are...so the more of you the better the price...
Also since I provide these with RAD bolts...I'm curious to what most of you guys want with respect to bolt finish...do you want Silver or Black???
Chad Cutter
Velocity Motorcars
713-589-2222
      08-11-2008, 06:18 PM   #25
vmcllc
12
Hey guys....here are some pics of our spacers installed on my car...
You will definitely like our exclusive never before seen "Spacer Lock Down" Feature. They hold the spacer, 10mm and up, onto the hub without it falling off, nor rotating around when you mount your tire...so lining up bolts holes is a snap..also you don't have to worry about it popping off when you take the wheels off...again securely mounted....
It a simple but very effective feature that only we have provided....
They fit like a glove and work like a champ...
Chad Cutter
Velocity Motorcars
713-589-2222
      08-12-2008, 06:01 PM   #26
WhiteOne
28
Drives: 2008 AW 135i
Chad...Thanks for the pix
      08-13-2008, 08:41 AM   #27
vmcllc
12
Orders were shipped yesterday...enjoy guys...
Also still let me know if you guys really want 8mm's...
Chad Cutter
Velocity Motorcars
713-589-2222
      08-13-2008, 09:09 AM   #28
mikeo
Santa Fe Concorso
mikeo's Avatar
103
Drives: '11 M-sport 328i, '13 X1 28i
I'm still on for 8mm to use with the 18x8.5 Breyton GTS-R rears on the front.
Santa Fe Concorso - The Southwest's Premier Automotive Gathering.
      08-13-2008, 09:12 AM   #29
vmcllc
12
Lets' get them motivated....:biggrin:
Chad Cutter
Velocity Motorcars
713-589-2222
      08-14-2008, 09:17 AM   #30
Squidbilly
Squidbilly's Avatar
Drives: 2008 135i
Just a note to those 1Addicts that want a non-staggered wheel setup. Grab yourself a set of Chad's 12mm spacers and a pair of used OE 264 rear 18x8.5 and you are ready for front tires up to 245, depending on ride height.
Mike, Thanks for the tip:thumbup:...I've been looking for some solid info on putting a set of rears up front. With stock ride height and no other mods, will there be any rubbing with this setup? I won't need to roll the lip, right? Just have to make sure before I do this:biggrin:.
Thanks!
      08-14-2008, 09:46 AM   #31
mikeo
Santa Fe Concorso
mikeo's Avatar
103
Having not done this I can't categorically state that there will be no rubbing for your proposed setup. But Fred Su has stated that 18x8.5 et40 with 245s is about max and everything I've read agrees with that. I think we are going to see people going with this front setup pretty soon and we will know for sure then.
      08-20-2008, 01:45 PM   #32
vmcllc
12
Orders...have been shipped...
There have been quite a few guys that have bought the 12mm from us that came from this site...so hopefully they can shed some insight to the rubbing issue...
Chad Cutter
Velocity Motorcars
713-589-2222
      08-26-2008, 12:02 PM   #33
vmcllc
12
Only two people interested in the 8mm???
Chad Cutter
Velocity Motorcars
713-589-2222
      08-26-2008, 12:11 PM   #34
mikeo
Santa Fe Concorso
mikeo's Avatar
103
I know...
      09-01-2008, 06:37 PM   #35
WhiteOne
28
Do they need to be anodized? Does it make them stronger?
8.5 inch 264's might look better on the front with silver 12mm spacers. Will the anodized spacers be noticable? Can you see them? I ask because the front hubs are more rounded off then the back ones are.
      09-01-2008, 07:56 PM   #36
Red135
La Flama Blanca
Red135's Avatar
27
Drives: 1-series
8mm Request List
2. wnta135
3. Red135
4.
5.
AMS, Berk Technology, aFe, ER
      09-01-2008, 09:43 PM   #37
mikeo
Santa Fe Concorso
mikeo's Avatar
103
OK, the list is growing!
      09-02-2008, 08:08 AM   #38
vmcllc
12
They do if you want the best... Anodizing them prevents the aluminum from corrosion... Anodizing does not in any way improve the material properties of aluminum, it does however improve abrasion resistance because the anodizing itself is harder...
No you will not be able to see the spacers...the black anodizing masks the spacer behind the wheel...whereas non-anodized would stand-out especially with open faced rims.
Chad Cutter
Velocity Motorcars
713-589-2222
      09-05-2008, 12:21 PM   #39
vmcllc
12
Orders...are out....thanks...
Chad Cutter
Velocity Motorcars
713-589-2222
      09-10-2008, 12:52 PM   #40
mikeo
Santa Fe Concorso
mikeo's Avatar
103
TC Kline uses a 5mm spacer on the front for the Breyton GTS-R 18x8.5 fitment with no reported issues, so I'm putting my 5mm order in instead of waiting for an 8mm.
      09-24-2008, 01:00 PM   #41
vmcllc
12
Okay guys....We've been without power nor internet for the past 2 weeks almost as the hurricane shut us down for awhile and we are remotely located till we get power and internet up....so we will be getting orders out soon...we are running a day behind on getting orders out as we can't get our orders till the next day...
Chad Cutter
Velocity Motorcars
713-589-2222
      09-26-2008, 04:54 PM   #42
vmcllc
12
Mike...how did the 5's work for your car??
Chad Cutter
Velocity Motorcars
713-589-2222
      09-26-2008, 05:29 PM   #43
mikeo
Santa Fe Concorso
mikeo's Avatar
103
They work fine giving just enough front strut clearance for the Breyton GTS-R 18x8.5 et48 wheel and for tires up to 245x35, but nothing wider or taller. I'm now running 225x40-18 front Dunlop Z1s on the 8.5" wide Breytons with absolutely no issues.
      09-26-2008, 05:33 PM   #44
vmcllc
12
Glad to hear that...
Chad Cutter
Velocity Motorcars
713-589-2222
1addicts
