06-09-2017, 02:12 PM | #1 |
336
Rep 522
Hybrid Pads
I know the topic of hybrid pads for the track has been discussed before, but here's my situation. Moderately experienced track driver. Likely doing 3-6 track days per year. Won't be swapping to/from track/stock pads. Here's my current options:
1. Hybrid pad. Ferodo DS2500 were recommended by HP Auto as the go-to. But my local shop advised going with Endless MX72s ($800 for front/rears = $350 more expensive than the Ferodos...ouch) 2. (Less optimal choice) Run a track pad full time (RS29). Some people say the noise is unbearable, others live with it. Would appreciate some input from those experienced track drivers. Especially anyone who can comment on DS2500 vs. Endless MX72s. Cheers Last edited by LBBDrew; 06-09-2017 at 02:25 PM.. |
06-09-2017, 02:58 PM | #2 |
2052
Rep 3,714
Street pad for street, track pad for track otherwise it's a compromise. You'll likely destroy a hybrid pad and/or get brake fade unless you're not a very fast driver or are running a rock hard tire and track pads on the street are noisy and wear rotors.
It takes 20 mins to change pads on a M2. Tie up the brake sensors. |
rjn43.50 |
06-09-2017, 05:02 PM | #3 |
44
Rep 123
06-15-2017, 11:38 PM | #4 |
BimmerPost Supporting Vendor
3885
Rep 54,494
Drives: F80 M3
Yes, with the proper mechanical know how, tools and garage/working space pads can be done in 20 minutes or so.
07-17-2017, 10:48 AM | #6 |
Rep 1
I'm very interested in this as well. I would like to do a few more track days this year but the stock setup is shocking. I however cannot live with squealing brakes. Saying that if it takes someone 20mins to swap out i could potentially do this for each day. I am looking for some middle ground tho.
07-17-2017, 12:15 PM | #9 |
3885
Rep 54,494
Drives: F80 M3
07-18-2017, 11:10 AM | #10 |
440
Rep 492
07-18-2017, 04:40 PM | #11 |
80
Rep 270
I used MX72s on my GT-R. And i was pretty happy with them.
I might give them a try after RS29s are worn. The RS29 makes a lot of noise if its a daily driver. Turning up the volume helps. 20 minutes to change all 4 brake pads? Thats optimistic. unless you have a hydraulic lift and an air gun... i'd say about 1 hour.
07-21-2017, 09:30 AM | #12 |
538
Rep 624
What I consider not so dusty could possibly be seen as very dusty by someone else. It's all about reference. But I do think the RS29 generate very little dust compared to for example older PFC pad compounds.
08-04-2017, 09:58 AM | #13 |
560
Rep 570
The Hawk Street/Track pad look interesting - w/useful capability above 1,000F. Probably not a bad compromise but won't give you the performance of an all-out race pad (hawk HT60, Pagid RS29, PFC08) but maybe your calipers won't turn green, either
09-05-2017, 06:24 AM | #14 |
48
Rep 63
At this stage I'm going to put on the Ferodo DS 2500, from what I understand these seem to be a good compromise pad. Just want a pad that won't smear all over the rotor when undertaking a bit of spirited track driving.
09-05-2017, 07:58 AM | #15 |
560
Rep 570
If you're an intermediate/advanced driver for HPDE, a hybrid pad will not likely give you the braking performance or durability you're looking for. The pads get outside their friction temp range and begin to fade/wear quickly.
I just changed to Hawk HPS pads for the street (big improvement, if just a bit noisy) and will run either Pagid RS29 or PFC08 for the track. +1 on the pad changes. Really easy and basic. |
09-06-2017, 04:28 PM | #17 | |
861
Rep 923
