05-08-2024, 08:48 PM | #1 |
287
Rep 1,150
1M Conversion Complete
Hey Guys,
I just finished my 1 M conversion and I went with the stock m3 18 setup, but I'm noticing some rubbing. I'm currently running 245/40/18 & 265/40/18. Should i drop down to a 245/40/18 in the front and a 265/35/18 in the rear? This is how it looks now The front is perfect, its only the rear right side that rubs. |
05-08-2024, 09:00 PM | #2 |
2428
Rep 5,896
Have you had your alignment checked? Rubbing on only one side suggests the rear camber and toe settings are different. Also, if it’s slightly rubbing, you could try increasing the rear camber by an additional 0.25-“.5 deg of negative camber. As long as your negative camber is not more than 2.5 deg (2.25 deg or less would be better) you should be fine with putting the power to the ground.
05-08-2024, 09:16 PM | #4 | |
287
Rep 1,150
Do you think the 265/35/18 is not a good idea ? |
05-08-2024, 10:00 PM | #5 |
197
Rep 573
I have 265/35/18 front and 295/30/18 and lowered in HR springs. Front passenger has a slight rub but worked fender liner and it’s good now, rear has no rub unless I bottom out suspension going quick on a dip in road.
05-08-2024, 10:04 PM | #6 |
2428
Rep 5,896
That’ll throw off your speedometer, affect ABS and DSC, and affect your gearing (equivalent to installing a diff with lower gearing, higher FD). The last one is not always a bad thing. Have you calculated the % diff in rolling diameters of the 265/40 and 265/35, and the 245/40 and 265/35? If it’s < +/-2% then you’re fine.
Car assembly tolerances and tolerance stackups can result in final assembled cars having fenders, etc. off by 1/8-1/4” or more. This could be the case with your car. What’s rubbing (e.g., fender liner, rear bumper, rolled metal lip, etc.) and where (e.g., 1 o’clock, 12 o’clock, etc. from the fender being 3 o’clock on the left side, 9 o’clock on the right side)? % diff of 265/40 and 265/35 is 4%, 245/40 and 265/35 is 1.9%, and 245/40 and 265/35 is 2.0%. The 2% diff between the 245/40 and 265/35 is ok but the %diff of 265/40 and 265/35 is not. Your speedometer will be 4% off which is not insignificant as well as wheel speed sensors so SBS, traction control and DSC may all potentially be affected. % diff of 265/35 and 295/30 is 1.6%. The 265/35 and 295/30 at 2% diff is ok Last edited by M3SQRD; 05-08-2024 at 10:23 PM.. |
Ajolives922.00 |
05-09-2024, 01:45 AM | #7 |
287
Rep 1,150
05-09-2024, 09:01 AM | #10 |
922
Rep 936
Drives: E90 M3
Thought I heard the left side of the M3’s suspension are ever so slightly higher to compensate for driver weight? Is it the same for 1M if true?
It’s odd that only ones side is rubbing. M3SQRD brought up a good point about tolerance stackup; what suspension parts were converted? If wheels are aligned I would think chassis/body asymmetry is a bit off. |
05-09-2024, 09:12 AM | #11 | |
2428
Rep 5,896
I’ve had aftermarket suspensions (MCS and JRZ) and both have been corner balanced and lowered with wider more aggressive wheels and tires without rubbing. |
