03-29-2024, 10:02 AM | #1 |
Rep 21
Strange break pad corrosion
I was replacing my OEM front break pads when I noticed the edges are shaved down and the top of pad has holes on top. Have anyone seen this before? First time changing pads - only did one track day on them (huge mistake).
03-30-2024, 06:46 PM | #2 |
1097
Rep 923
That's called pad taper which is not unusual. There are several possible causes. In your case, it's likely OEM pads being overheated. It could also be a sticky piston or even incorrectly installed calipers or pad tension clip. Did the other front brake pad experience the same taper?
The pockmarks are nothing to worry about. Next time try a more suitable pad. PFC, ferodo, etc. |
2sporty243.50 |
03-31-2024, 01:12 PM | #3 |
2300
Rep 5,742
That’s the most severe pad taper I’ve ever seen from a stock caliper! I don’t know if it’s the angle of the picture but the pad material looks like it’s really thick. How do the other front and rear pads look? Yeah, stock pads don’t do well on track. It’s best if you have dedicated sets of street and track pads. There are several track pad options for the stock blue calipers. It’s hard to recommend a pad to someone because we all brake differently and prioritize pad characteristics differently but getting a track pad that’s rotor friendly is one most people will agree on, unless you have a brake sponsor
03-31-2024, 11:11 PM | #4 |
222
Rep 320
The edges are not worn down. It is manufactured this way to reduce the noise of the pads. Pads that are not angled on the edges will have a tendency to make a bit of noise while braking. Well more than one without the edges angled.
04-04-2024, 10:27 AM | #5 |
Dont listen to me
802
Rep 572
Your pads look like they have been overheated due to the race track excursion. When I overheat even dedicated track pads, I will get little chunks or pock marks in the pads (like yours). Other than than that, I dont see any issues with your pads.
The extreme edges of your pads that have that strong taper are completely normal. See first picture below of new pads; you can see the taper. I dont see any actual irregular wear from your pictures, but it's also hard to see exactly without you putting a digital caliper up to them and measuring the thickness of the left side versus the right. Second picture shows what I mean by pad taper.
Instagram: @thatwhitem4
04-05-2024, 06:50 AM | #6 | |
2300
Rep 5,742
