04-09-2014, 09:26 AM | #23 | |
2293
Rep 12,567
Drives: Z4 M, X5, GX460
For anyone else thinking about ordering this kit from ECS, I'll add 2 minor notes. One, the incremental cost to add 7 quarts of Official BMW 5w-30 motor oil was was $2 in s/h charges so it might be a good time to buy oil. Their charge only $6.82 per bottle. Two, OP noted that you don't need to buy part p/n 31316769731 (x4) since you can reuse 4 of the 6 you are replacing by the strut tower. With that said, if you wanted black hardware to match your bar, Fastenal sells these quite cheap at $0.50/ea, although shipping ruins the deal. If anyone wants, I can buy a bulk order of these black M8 hex nuts and can ship them out to you via snail mail for the cost of hardware + postage + paypal fees. Just let me know, plan to put my order in by end of week. You would need 4 of these. http://www.fastenal.com/web/products/details/11508216 Last edited by 3002 tii; 04-09-2014 at 09:39 AM.. |
04-09-2014, 10:35 AM | #24 |
13
Rep 83
This will work with the dinan fixed plates. All of the additional camber from the plates occurs on the underside of the strut tower. The top side, where the strut brace mounts, remains unchanged.
04-09-2014, 10:49 AM | #25 |
4338
Rep 6,196
04-09-2014, 10:56 AM | #26 |
2293
Rep 12,567
The Dinan plates (or any camber plate for that matter) plus the strut tower brace will reinforce the strut towers which are known to cave/crack/mushroom on older BMW's so this is another reason to buy these parts.
Thanks again OP, I just put my order through with ECS. My ETA looks similar to yours, expected ship date is May 6th. |
04-09-2014, 02:36 PM | #27 |
88
Rep 824
For you guys piecing this together just order through a vendor on here that works at bmw. U won't have to wait at all. I talked to Phil@reeves and gave me great quote
04-09-2014, 11:42 PM | #29 |
17
Rep 143
04-09-2014, 11:58 PM | #30 |
375
Rep 2,388
Drives: M2 Competition
Thanks for posting! Would save me a lot of time to get these. Definitely going to nab this in the near future!
04-11-2014, 07:32 AM | #31 | |
255
Rep 494
2016 F80 M3 (Mineral/Full SO)
2014 X5 M Sport (Mineral/Mocha) |
04-11-2014, 08:33 AM | #32 |
2293
Rep 12,567
Not yet, still leaving this out there for now since I know the install can be done with the existing nuts. But I check back in a few days and tally up the final count =)
06-03-2014, 06:49 PM | #33 |
2293
Rep 12,567
After waiting 2 months for the parts to arrive I just got around to installing this, the only minor issue I had was when tightening the passenger side brace over then strut, the arm was hitting an electrical cable. Upon tightening one of the nuts I actually saw a blue spark so I immediately stopped. Adding 2 washers over the inner most strut hole closest gave me enough clearance but then I had difficulty tightening down the main plastic cowl because the nuts overt the brace were touching. Not sure if that was exacerbated by the washers or not but no big deal.
2 washers over strut tower gave enough clearance: Bar installed before putting the plastic trim back on: |
06-03-2014, 08:10 PM | #34 |
39
Rep 257
I just did mine today. Everything went smoothly except I broke a clip on the cabin filter housing. Non essential, I'll
Probably replace it down the road though. |
06-03-2014, 09:27 PM | #35 |
2293
Rep 12,567
Interesting you didn't encounter the issue I had where the right side brace was pushing down on that cable
06-03-2014, 10:07 PM | #36 |
39
Rep 257
I never really noticed it. I'll take a another look in the morning see if it's touching it. Shouldn't the cable be insulated anyways? I wouldn't think they would leave a cable that would be conductive to metal parts exposed in the engine bay.
06-03-2014, 10:18 PM | #37 |
2293
Rep 12,567
It is insulated but nonetheless when I began tightening the strut nuts, I heard some crackle and then a blue spark appear from that harness. Didn't want to chance it.
06-04-2014, 09:19 PM | #38 |
39
Rep 257
I doubled check this morning everything cleared fine. No problems....maybe it was a static electricity discharge.
06-04-2014, 10:16 PM | #39 |
2293
Rep 12,567
Maybe but I know for sure without the washers it was definitely pressing down on the cable
06-05-2014, 06:40 AM | #40 |
43
Rep 272
Drives: 2008 128i
Thanks for posting. I have the stock setup with the BMW Performance strut bar, which I don't think really does anything as far as stability. Id swap that for something like this that actually does something for the car. I had to make a special tool to adjust the rebound adjustment on the top of my Koni's, it works but its a pain in the ass.
Afe Scoops and CAI, PBX, BMS Paddleshift upgrade, 261M's Powder Coated Gunmetal, 225/255 Michelin PSS, (BMW Performance: BBK, Illuminated Door Sills, Shifter Knob and Boot, E-Brake Handle, Steering Wheel, Front Strut Bar), E93 FSB, E92 RSB, M3 Rear Subframe Bushings, M3 Front Control Arms, HPA coilover kit (Koni Adjustables and Swift Springs), Steel Brake Hoses, Black Kidneys, Smoked LED side markers, Blacklines, Msport lip spoiler...
06-10-2014, 11:10 AM | #41 |
Rep 3
Hi, I ordered these parts a week ago from Germany.
They have arrived today. (so quick!) In my case, It seems that the top of bolt (connect "Mounting Ring" to "Strut Bar" ) interferes against "Microfilter Cover" a little. In order to make cleaner install I had to cut the top bolt - this modification make the whole install more aesthetically looking. In general - this is great low cost modification to my car. Thank you for posting! |
06-10-2014, 02:28 PM | #43 | |
2293
Rep 12,567
