BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
European Auto Source (EAS)
      01-13-2014, 03:08 PM   #23
regular guy
427
Drives: Sprint car
2b64 - P0073
2B64 - P0073
2B64 - P0073
Information saved inDME
Fault code2B64 - P0073
Fault textAmbient-temperature sensor
Fault descriptionAmbient Air Temperature Sensor Circuit 'A' High
Condition for fault identificationTest condition: Error message from CAN I-cluster message
.Terminal condition: B_ZUST_ML && B_EMPF_ATEMP
.Voltage condition: none
Condition for fault memory entry10000 ms
Action in service1. Check plug and wiring harness.
.2. Check stored error codes logged in I-cluster.
.3. Replace ambient temperature sensor.
Fault effect and breakdown warningMIL on after engine runs 2x
Driver informationWarning light: MIL
Service instructionnone
      01-13-2014, 03:08 PM   #24
signes
signes's Avatar
202
Drives: 991 GT3 RS
Needs to be a sticky. Thanks for compiling this.
GT3 RS | Desperately seeking the next great M car...
      01-13-2014, 04:04 PM   #25
tmntmn
///M
161
Drives: e92 M3/M-DCT
i got a check light engine the other night was wondering if you can help me.
i pull the code and it show P2096
THANKS TO:~<RPM>~ ~<SONICMS>~ ~<MODECARBON>~ ~<McKennaPerformance>~
MODS: MODECARBON V2 GTS FRONT LIP & REAR DIFFUSER, AA GREEN FILTER, RPI SCOOPS, PSW, Verstraβe Extended DCT Shifter, ZCP WHEELS (SEMI-GLOSS), OHLINS R&T, Megan Exhaust, AKRA XPIPE, BMW LED INTERIOR, BLACKOUT W/ORION V4 LED AE, OSRAM CBI
      01-13-2014, 04:08 PM   #26
regular guy
427
Drives: Sprint car
27c6 - P2096
27C6 - P2096
27C6 - P2096
Fault code27C6 - P2096
Fault textOxygen sensor, adaptation, trim control, bank 1
Fault descriptionPost Catalyst Fuel Trim System Too Lean (Bank 1)
Condition for fault identificationTest condition: Adaptation value reaches MIN limit and hangs in this position
.Terminal condition: Engine running
.Voltage condition: Battery voltage > 9.8V (k_diag_tr_ub_min)
Condition for fault memory entryCounter for recognition at adaptation limit >= (2x) K_LA_TRIM_DIAG_I_AD_MAX_SCHW
Action in service1. Check the fuel system and the exhaust system for leaks
.2. Check pre-cat and post-cat sensors and replace as indicated
      01-13-2014, 05:08 PM   #27
geneatals
Ninja
geneatals's Avatar
390
Drives: 2019 530e
how has this not been made a sticky yet....admins/mods?
2019 AW G30 530e l ZPP l ZMP l ZDH
Retired: 2016 F80 M3, 2012 E90 M3, 2008 535i
      01-15-2014, 02:22 PM   #28
MTM
83
Drives: 2009 M3
"regular guy" for President! Great info. Thanks for taking the time to share.
      01-16-2014, 09:13 PM   #29
regular guy
427
Drives: Sprint car
2b41 - P0300
2B41 - P0300
2B41 - P0300
Fault code2B41 - P0300
Fault textMisfire with cutout, several cylinders
Fault descriptionRandom/Multiple Cylinder Misfire Detected
Condition for fault identificationTest condition: Miss capable of damaging cat on multiple cylinders
Terminal condition: Terminal 15
Condition for fault memory entryVaries according to load and rpm
Action in serviceNote selective logged error codes related to individual cylinders
Fault effect and breakdown warningCC message
Engine speed limited
Reduced power
MIL after engine runs 2x
Rough idle
Driver informationWarning light: MIL, EML, CC message, backup program
Service instructionNone
      01-16-2014, 09:18 PM   #30
regular guy
427
Drives: Sprint car
2b36 - P0302
2B36 - P0302
2B36 - P0302
Fault code2B36 - P0302
Fault textMisfire with cutoff, cyl. 2
Fault descriptionCylinder 2 Misfire Detected
Condition for fault identificationTest condition: 3.3V in miss window for at least 5 ms (K_AUSS_NS_TIME_MAX) or for entire miss window
Action in service1. Check spark plug, interchange with other plug or replace to localize malfunction.
2. Run compression check.
3. Inspect cylinders to determine whether coolant and engine oil are entering.
Reduced power
Rough idle
      01-16-2014, 09:20 PM   #31
regular guy
427
Drives: Sprint car
2b37 - P0303
2B37 - P0303
2B37 - P0303
Fault code2B37 - P0303
Fault textMisfire with cutoff, cyl. 3
Fault descriptionCylinder 3 Misfire Detected
Reduced power
Rough idle
      01-16-2014, 09:22 PM   #32
regular guy
427
Drives: Sprint car
2b3c - P0308
2B3C - P0308
2B3C - P0308
Fault code2B3C - P0308
Fault textMisfire with cutoff, cyl. 8
Fault descriptionCylinder 8 Misfire Detected
Reduced power
Rough idle
      01-21-2014, 06:45 PM   #33
regular guy
427
Drives: Sprint car
2b42 - P0301
2B42 - P0301
2B42 - P0301
Fault code2B42 - P0301
Fault textMisfire impairing exhaust emission, cyl. 1
Fault descriptionCylinder 1 Misfire Detected
Condition for fault identificationTest condition: No spark detected in ionic current signal
Action in service1. Check spark plug, interchange with other plug or replace to localize fault
2. Exchange ignition coil with another coil to localize fault, replace as indicated.
3. Check plug and wiring harness to ignition coil.
Reduced power
Rough idle
      01-25-2014, 08:00 PM   #34
Dannys M3
Dannys M3's Avatar
71
Drives: Jaguar F Type R
2008 M3  [10.00]
Please help
Any help with the following codes would be much appreciated. So far they have been triggered twice as increased emissions check light.
// 1) 27AB Lambda adaption at VKAT stop bank 2
// 2) 27AA Lambda adaption at VKAT stop bank 1
      01-25-2014, 10:17 PM   #35
regular guy
427
Drives: Sprint car
27ab - P0106, 27ab - P0068, 27ab - P2193
27AB - P0106
27AB - P0106
Fault code27AB - P0106
Fault textCharge plausibility, diagnosis hot - bank 2
Fault descriptionManifold Absolute Pressure/Barometric Pressure Sensor Circuit Range/Performance
Condition for fault identificationTest condition: Deviation from mean value (depending on psau, lam, aq) in percent is determined and compared with the max. deviation (in relation to rpm/load factor) KF_FPLAU_OBD_PSAU_DELTA_ML_MAX * expansion factors (K_FPLAU_OBD_TE_F, KL_FPLAU_PSAU_PUMG_F)
Action in service1. Check induction system B1 for leaks
2. Replace intake manifold pressure sensor
27AB - P0068
27AB - P0068
Fault code27AB - P0068
Fault descriptionMAP/MAF - Throttle Position Correlation
Condition for fault identificationTest condition: Deviation from mean value (depending on psau, lam, aq) in percent is determined and compared with the max. deviation (in relation to rpm/load factor) KF_FPLAU_OBD_AQ_DELTA_ML_MAX * expansion factor (K_FPLAU_OBD_TE_F)
27AB - P2193
27AB - P2193
Fault code27AB - P2193
Fault descriptionSystem Too Lean at Higher Load (Bank 2)
      01-25-2014, 11:50 PM   #36
IMG's Avatar
1126
Drives: E36 M3 Track car,Ess E90 M3 DD
OMG
Another win thread !!!
Sticky plzzzzz
      01-26-2014, 12:07 AM   #37
regular guy
427
Drives: Sprint car
27aa - P0106, 27aa - P0068, 27aa - P2191
27AA - P0106
27AA - P0106
Fault code27AA - P0106
Fault textCharge plausibility, diagnosis hot - bank 1
Voltage condition: None
27AA - P0068
27AA - P0068
Fault code27AA - P0068
27AA - P2191
27AA - P2191
Fault code27AA - P2191
Fault descriptionSystem Too Lean at Higher Load (Bank 1)
      01-27-2014, 09:14 AM   #38
regular guy
427
Drives: Sprint car
2b55 - P1689, 2b55 - P1681, 2b55 - P1691, 2b55 - P16b3, 2b55 - P1602
2B55 - P1689
2B55 - P1689
Fault code2B55 - P1689
Fault textControl module, internal fault
Fault descriptionElectronic Throttle Control Monitor Level 2/3 Torque Calculation Error
Condition for fault identificationTest condition: Deviations too large (KF_MD_KUPP_OFF_E2, K_MD_E2_IST_SCHW, ...)
Condition for fault memory entry10 ms/100 ms
Action in service1. Clear fault memory
2. Update DME
3. Replace DME
Reduced power
2B55 - P1681
2B55 - P1681
Fault code2B55 - P1681
Fault descriptionElectronic Throttle Control Monitor Level 2/3 Engine Speed Calculation Error
Condition for fault identificationTest condition: Internal rpm deviation within control module of K_N_E2_DELTA for a period of 0.5 sec. (K_N_E2_T_MAX)
2. Update DME
3. Replace DME
Reduced power
2B55 - P1691
2B55 - P1691
Fault code2B55 - P1691
Fault descriptionElectronic Throttle Control Monitor Level 2/3 Motorised Throttle Control Engine Speed Limitation Error
Condition for fault identificationTest condition: Implausible data
2. Update DME
3. Replace DME
Reduced power
2B55 - P16B3
2B55 - P16B3
Fault code2B55 - P16B3
Fault descriptionControl Module Self-Test, MSR (Engine-Drag-Torque Control) Monitoring
2. Update DME
3. Replace DME
Reduced power
2B55 - P1602
2B55 - P1602
Fault code2B55 - P1602
Fault descriptionControl Module Self-Test, Control Module Defective
Condition for fault memory entry100 ms
2. Update DME
3. Replace DME
Reduced power
      01-27-2014, 09:24 AM   #39
The Automotive Enthusiast
Retired BMW Genius
The Automotive Enthusiast's Avatar
2903
Drives: 2018 Audi S5 Coupe
Sticky!
Originally Posted by LucBroDude View Post
TRAITOR.
TRAITOR.
      01-27-2014, 09:29 AM   #40
regular guy
427
Drives: Sprint car
2737 - P0106, 2737 - P0068, 2737 - P2191
2737 - P0106
2737 - P0106
Fault code2737 - P0106
Fault textCharge plausibility, diagnosis, cold-start strategy, bank 1
Condition for fault identificationTest condition: * Deviation from mean value (depending on psau, lam, aq) in percent is determined and compared with the max. deviation (in relation to rpm/load factor) KF_FPLAU_OBD_LAM/AQ_DELTA_ML_MAX * Expansion factors (1.5 K_FPLAU_OBD_TE_F, KL_FPLAU_OBD_AQ_PSAU_CSS_F)
2737 - P0068
2737 - P0068
Fault code2737 - P0068
2737 - P2191
2737 - P2191
Fault code2737 - P2191
      01-27-2014, 09:33 AM   #41
regular guy
427
Drives: Sprint car
2738 - P0106, 2738 - P0068, 2738 - P2193
2738 - P0106
2738 - P0106
Fault code2738 - P0106
Fault textCharge plausibility, diagnosis, cold-start strategy, bank 2
2738 - P0068
2738 - P0068
Fault code2738 - P0068
2738 - P2193
2738 - P2193
Fault code2738 - P2193
      01-28-2014, 02:47 PM   #42
regular guy
427
Drives: Sprint car
271b - P0015
271B - P0015
271B - P0015
Fault code271B - P0015
Fault textVANOS control, exhaust bank 1
Fault description'B' Camshaft Position - Timing Over-Retarded (Bank 1)
Condition for fault identificationTest condition: Filtered control deviation > 8.0°Crankshaft (K_VAN_XD_FILT_ED)
Voltage condition: Battery voltage > 9V (k_ed_ubmin)
Action in service1. Clear fault memory, VANOS system test
2. Check valves, check adjuster
Fault effect and breakdown warningError display in instrument / power reduction / engine speed governed to 7000 rpm / MIL on after engine runs 2x
      01-29-2014, 10:53 PM   #43
regular guy
427
Drives: Sprint car
2b15 - P0638
2B15 - P0638
2B15 - P0638
Fault code2B15 - P0638
Fault textThrottle-valve actuator, governor monitoring, bank 1
Fault descriptionThrottle Actuator Control Range/Performance (Bank 1)
Condition for fault identificationTest condition: Actuator reports system error
Terminal condition: TERM87
Action in service1. Clear fault memory, conduct EDR electronic throttle valve control system test,
2. Check plug and wiring harness at throttle valve sensor DKG1 and electronic throttle valve control EDR1,
3. Replace DKG1 or EDR for Bank 1
Reduced power
2B15 - P0638
2B15 - P0638
Condition for fault identificationTest condition: Actuator reports regulator error
Action in service1. Clear fault memory, carry out EDR electronic throttle valve control system test,
2. Check plug and wiring harness to throttle valve sensor DKG1 and EDR1,
3. Replace DKG1 or EDR Bank 1,
4. With UMWB engine protection check throttle valve assembly for stiction
Reduced power
      01-31-2014, 03:14 PM   #44
regular guy
427
Drives: Sprint car
2b26 - P155c, 2b26 - P155d, 2b26 - P155e, 2b26 - P155f
2B26 - P155C
2B26 - P155C
Fault code2B26 - P155C
Fault textThrottle-valve monitoring, bank 2
Fault descriptionThrottle Actuator Monitoring Dissimilar Desired Values (Bank 2)
Condition for fault identificationTest condition: Difference too large
Voltage condition: Battery voltage > 6.8V (k_egas_can_ed_ub_min)
Condition for fault memory entry300 ms
Action in service1. Clear fault memory, EDR electronic throttle valve control system test
2. Check plug, wiring harness and power supply to EDR2
3. Replace EDR2
Reduced power
2B26 - P155D
2B26 - P155D
Fault code2B26 - P155D
Fault descriptionThrottle Actuator Monitoring Incorrect Actual Value (Bank 2)
2. Check 2nd plug, wiring harness and power supply for throttle valve DK2, EDR2 and DME,
3. Replace DK2
Reduced power
2B26 - P155E
2B26 - P155E
Fault code2B26 - P155E
Fault descriptionThrottle Actuator Monitoring Actual Value / Desired Value Correlation (Bank 2)
Condition for fault memory entry350 ms
2. Check plug, wiring harness and power supply to throttle valve DK2 and EDR2
3. Check throttle valve assembly B2 for mechanical stiction
4. Replace DK2
5. Replace EDR2
Reduced power
2B26 - P155F
2B26 - P155F
Fault code2B26 - P155F
Fault descriptionThrottle Actuator Monitoring Reset Error (Bank 2)
Condition for fault identificationTest condition: Not identical for too long
Condition for fault memory entry250 ms
3. Replace EDR2
Reduced power
m3post
