The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > 60k service
      10-06-2014, 10:59 AM   #1
335twins
335twins's Avatar
142
Drives: 2020 x3 M40i, 2019 M2Comp
60k service
Hi all,
Just hit 60k and decided to perform major maintenance, let me know if I missed something:
Oil change (this is done every 7k miles)
Transmission fluids flush
Brake fluid
Coolant
Walnut blast
Spark plugs
Thanks
      10-06-2014, 11:58 AM   #2
Fun w/N54
39
Drives: '11 E92 335is AW/CR/DCT
Serp Belt
      10-06-2014, 12:00 PM   #3
fazman
681
Drives: 335 e90
Originally Posted by 335twins View Post
Hi all,
Brake fluid
Coolant
Walnut blast
Spark plugs
Thanks
If you were 6AT, you should have also dropped the transmission pan and swapped out that Mechatronic sleeve which is a common failure point at about 75k miles (Cheap part but annoying failure/leaking).
While you were doing the plugs, should should have taken out the VANOS solenoids and cleaned them.
Keep an eye out on VCG and also your OFHG for oil leaks.
      10-06-2014, 12:05 PM   #4
335twins
335twins's Avatar
142
Hi all,
Brake fluid
Coolant
Walnut blast
Spark plugs
Thanks
Actually i split the service and going this Friday for walnut blast and spark plugs. Will have them check the vanos. Also, during the tranny flush they replaced the pan so i think I'm covered there, right?
      10-06-2014, 12:13 PM   #5
335twins
335twins's Avatar
142
Originally Posted by Fun w/N54
Serp Belt
What is the apx. Cost? Don't want to get bend over?
      10-08-2014, 08:26 PM   #6
335twins
335twins's Avatar
142
Is there a specific way to clean the Vanos solenoids?
      10-08-2014, 08:55 PM   #7
Eat.Sleep.Race
Out Boosting...
243
Drives: F30 335i M-Sport
I would replace or clean Vanos solenoids, check valve cover and oil cooler -oil filter area gaskets.
Alpine White M-Sport F30
      10-08-2014, 09:16 PM   #8
335twins
335twins's Avatar
142
I will tell them to clean the vanos solenoids using compressed air. Will tell them to check valve cover and oil cooler (i have the sport package which has the extra oil cooler).
      10-08-2014, 09:48 PM   #9
Miller335
291
Drives: 2007 E92
I would cycling a can of chf 11s through the PS system to add to the list.
      10-08-2014, 11:56 PM   #10
335twins
335twins's Avatar
142
So basically replace the PS fluid?
      10-09-2014, 02:55 AM   #11
MiniXP
MiniXP's Avatar
69
Drives: 08 335i, 06 X5 3.0
You should get the differential fluid changed as well
http://www.e90post.com/forums/signaturepics/sigpic228641_1.gif
      10-09-2014, 10:29 AM   #12
Agentphish
129
Drives: '08 328i
Do the diff fluid yourself too. It's really easy with a fluid transfer pump and fairly inexpensive.
I'm just 500mi under 60K and the PS fluid is the last fluid I need to change out.
I've seen the turkey baster method on here, but I'd really rather properly drain and fill.
'08 328i | TiAg | 6MT | CDV Mod | RevMotoring Silicon Intake Tube | AG M310 | Cold | Premium | HiFi | V1 Hardwire | AirPlay - FiiO DAC
'15 Golf SE Sport | Pure White
      10-09-2014, 11:02 AM   #13
MiniXP
MiniXP's Avatar
69
I would try to get a vacuum pump that hooks up to a compressor if I did it again.
I used a fluid transfer pump and was not satisfied with how much fluid I got out. Only less than 1 qt fit back in before it started flowing out. I'll most likely do it again soon if I can get a better pump that will pull a continuous vacuum
      10-09-2014, 07:36 PM   #14
335twins
335twins's Avatar
142
Walnut shell blast tomorrow, will make them take before/after pics, want to see how bad it is at 65k.
      10-11-2014, 02:15 AM   #15
335twins
335twins's Avatar
142
Before and after pictures of the intake valves..
      10-15-2014, 11:08 PM   #16
fazman
681
Drives: 335 e90
I think just taking them out and using some kind of electronics cleaner should do the trick. Not sure if brake cleaner is too harsh for the electronics?
      10-15-2014, 11:09 PM   #17
fazman
681
Drives: 335 e90
So fresh and so clean clean!
