04-15-2022, 11:22 AM | #68 |
423
Rep 443
Drives: 1M
Was so seized that it started to bend when pressing it out 😐. Fixed!
2011 BMW VO 1M (Currently in pieces for New Build!)
==OLD SETUP== ViE 3884 | PR | JB4 | EOS Billet Fuel / Manifold | Seibon Hood | Spec Twin | 900IC | Slek Lip / Diffuser | EC7 Wheels | KW HAS | Maddad + GTHaus | P3 | ViE Can |
04-15-2022, 01:06 PM | #69 |
3087
Rep 2,747
Glad you found one! When I looked recently for love nor $ were they available.
9ers
04-15-2022, 01:38 PM | #70 |
308
Rep 438
04-15-2022, 01:41 PM | #71 |
423
Rep 443
Drives: 1M
Not sure what is meant by fish story. I had a shop press them out after I tried that method 😑
04-15-2022, 08:22 PM | #72 |
308
Rep 438
The end of that axle is pretty well destroyed… you clearly left out some details for a better carnage story. I’ve not actually heard someone say they had to press an axle out before. I probably would’ve tried pulling the hub instead. Glad you got it fixed, but they definitely doubled the price on axles a while back.
balloonsalesman47.50 |
04-26-2022, 10:07 PM | #73 |
423
Rep 443
Drives: 1M
Very close to start up, chasing a MRS ignition error that is blocking injectors
For those who were wondering about cooling here is the final solution. The M3 crash bar , oil cooler brackets , and M3 structure support are fused together. We drilled out the 4 rivets and then used the 1M structure , M3 cooler brackets and M3 CF crash bar! We were also able to retain the ducting channel for the air to extract out of the bottom Mporium plate :-)
04-27-2022, 03:15 AM | #74 |
553
Rep 522
well damn, that is looking pretty nice now that you are almost there. Good luck with the injector issues.
Mods to date: The list grows...
04-27-2022, 08:41 PM | #76 | |
423
Rep 443
Drives: 1M
It fits fine minus the ducts as the M3 ducts are slightly narrower and wider than the 1M ducts. Hurts to dremel my CF ducts but must be done.
04-28-2022, 10:01 PM | #78 |
423
Rep 443
Drives: 1M
She lives!
05-04-2022, 11:36 PM | #80 |
423
Rep 443
Drives: 1M
Think we are close. All cooling systems ready to go, lines bleed to validate M3 line merge was solid as it all had to be relocated.
Investigating a small sensor issue… I think 🤔. It seems I didn't tighten the oil filter pipes tight enough and saw a small drip but no other leaky bits. Pardon the brake shield, hoping to get all alignment work done next week. They are going to hate me lol.
05-09-2022, 06:46 PM | #81 |
423
Rep 443
Drives: 1M
All small issues sorted. All modules in place and all the RPMs on tap!
05-09-2022, 08:00 PM | #82 |
2619
Rep 2,819
Drives: e82 1M, f87 M2cs
Damn!!!
1M track toy mods: BMS chargepipe, BMS OCC, ADE FMIC, ADE motor mounts, MadDad/Lightweight Ti exhaust, ADE custom oil thermostat/cooler, custom MHD tune, F10 550i clutch, Ohlins R+T, Vorschlag camber plates, M3 'vert FSB with Turner endlinks, Stoptech Trophy BBK.
05-12-2022, 03:21 PM | #85 |
505
Rep 649
It doesn't fit. You need to cut up the carbon unit, the weight savings is negligible, and the tow hook bung doesn't line up. I tried really hard, unsuccessfully, to get it to work.
05-12-2022, 05:09 PM | #86 |
238
Rep 259
05-12-2022, 06:21 PM | #87 |
423
Rep 443
Drives: 1M
From what I can tell is if we don't use the foam and trim the ducts it seems it will clear. Guess I'll find out soon enough 😂
05-21-2022, 04:00 PM | #88 |
423
Rep 443
Drives: 1M
For those who think you can't use the M3 crash bar, you can easily fit it minus a little trimming. Tow hook placement works just fine!
