Follow up on DME Failure-Win for the good guys!
11-09-2013, 11:44 AM | #1 |
WILL
30
Rep 496
Ok so to start of with ill let you know what happened then follow it up with what I did to fix all the issues. This will include what I call fails on my part and fails on BMWs part.
About 3 weeks ago I left a DYNO that I was working but did not dyno. On the way home I stopped to get Gas at a local gas station. Apparently the fuel that I got which said 93 octane was a little weaker than displayed. 10 minutes later and 3rd gear pull I get a miss fire and then limp mode. I try to clear all my codes using my COBB V3 like any other sane person. but no use lost all throttle control basically the car was useless and I pulled these following codes. 29D0 misfirings, cylinder 4 29D1 misfirings, cylinder 5 29D2 misfirings, cylinder 6 29CC misfirings, several cylinders 29D9 misfirings in case of tank filling level too low 30BB DME digital motor electronics, internal failure So after getting the my car towed I ran some tests, switching coil packs around to make sure that it wasn't the coil packs going bad, still same codes. Got new spark plugs to make sure it wasn't the plugs, still same codes. Got new coil packs, still same codes.. Got new injectors cylinder 4,5,6 still same codes... So I looked up 30BB code and stumbled upon someone with the same issues. Come to find out Our DMEs have a transistor for each cylinder and I blew cylinder 4,5,6. So I sent it out to http://www.n54dme.com/product/n54-dme-repair-service and 4 days after sending my DME out to TEXAS for repairs I get it back and clear all the codes off the DME using INPA and undoing my battery and getting a lil jump start from my GFs WRX, the car starts right up. So my fails- buying Coil Packs, Plugs, Injectors and then finding out that it was my DME. BMW fails- Making Faulty DMEs and having Faulty Injectors... Do to N54DME.com Thanks for the help and well worth the money considering a new DME is $2500ish. If you guys come up with these issues PM me and I will help you with any issues you guys since ive done my water pump, injectors, coding, oil gaskets, and every other shenanigan you can think of. |
09-16-2014, 01:18 PM | #3 |
299
Rep 2,015
Good for you bro.
By the way the link is not working. http://www.n54dme.com/ The above is what I tried. DN |
09-16-2014, 07:40 PM | #4 |
58
Rep 665
Not sure how many miles you had on your car when your DME failed, but in the US, the DME is covered by the Federal Emissions Warranty for 8 years / 80K miles.
2010 535i M Sport - Platinum Gray/Dakota Black/Anthracite Bamboo
2016 Jaguar F-Type S AWD - Polar White/Cirrus |
09-17-2014, 12:26 AM | #5 |
16
Rep 154
Holy cow, you, sir, are amongst the 0.001% capable of doing that. I thought I was a genius, replacing my OFH gasket. You put me to shame. Congrats, and money will saved!! Too bad you can't return those plugs and injectors and coilpacks!! But, I commend your persistence and skill.
Tags |
dme, fault codes engine problem, injector misfire |
