Bimmerpost
4 Series
Technical Topics iDrive, Nav, Phone, Audio, Video, Cameras, Electronics H/K Bass and Audio Failure ‘20 / ‘21? READ HERE
      12-23-2022, 11:57 AM   #67
Technic
Technic's Avatar
2307
Drives: 2021 i3S, 2024 i4 M50
Originally Posted by tester2011 View Post
Can someone point me to where the amp is actually located?
Thank you
      01-23-2023, 11:46 PM   #68
sidearm1911
sidearm1911's Avatar
South Korea
Drives: 2021 BMW M440i
Resolution
I've had this issue since car pickup (2021 M440i) in Dec of 2020. Dealerships here in Korea have not been helpful at all, and say there's nothing they can do. It seems to happen more in the summer than winters. Is the RAM the problem for sure? or the amp? or the booster? Thanks, trying to solve this on my own if need be.
      01-26-2023, 09:37 AM   #69
Technic
Technic's Avatar
2307
Audio issue or bass issue (HiFi) = RAM
Bass issue (HK) = Booster
      01-30-2023, 08:55 PM   #70
sidearm1911
South Korea
Thank you!!!
Current: Tanzanite II Blue 2021 M440i
Ex's: Schwarzblau 2002 M3 Cabrio
Dakargelb 1997 M3
Black 1990 535i
      03-09-2023, 09:27 PM   #71
m340ixxx
Drives: BMW M340i
Ordered new amp with correct index and still not working?? Do I need to reprogram? Thinking about just bringing it into service but it’s out of warranty and not trying to pay ridiculous amounts of money for something I might be able to fix. Car had HK system
      03-16-2023, 01:51 PM   #72
Steadyhand
52
Drives: E90, E70, F30, F97/G01 X3M
In the Technic harness "add a sub" for the HK system, does anyone know what music frequencies are coming through to the two-channel Wavtech LOC?
Are they low frequencies only?
Huge thanks
      03-19-2023, 09:02 AM   #73
Technic
Technic's Avatar
2307
Huge thanks
The HK system RAM powers the mid/tweeters, the Booster powers the woofers - Booster output low frequencies only (woofers).
      06-01-2023, 12:42 PM   #74
heylenM340
Drives: m340
Same story here, did u fix it?
      08-16-2023, 11:57 AM   #75
m340ixxx
Drives: BMW M340i
Anyone fix?
      09-25-2023, 11:56 PM   #76
Liotta Soda
Liotta Soda's Avatar
Drives: Bmw 340i
These are on back order
      10-06-2023, 05:29 AM   #77
MHL
MHL's Avatar
13
Drives: '20 BMW G22 and '22 Volvo S60
Just sharing my experience. I had the same issue with my '20 G22. Idrive 7 pro with HK. Went to the dealership and they performed a firmware upgrade. (which took more them two hours, but ok...)
I don't drive the car on a daily basis, but the problem hasn't returned yet. Fingers crossed.
      10-07-2023, 08:29 PM   #78
Liotta Soda
Drives: Bmw 340i
New booster amp installed now
Sounds better
But still sux
      10-09-2023, 09:33 PM   #79
m340ixxx
Drives: BMW M340i
Can you provide picture of the new one installed? Also did they reprogram ?
      11-08-2023, 07:29 AM   #80
TuukkaJK
TuukkaJK's Avatar
38
Drives: BMW 330e G20
Anyone fix?
I had the same problem. Total loss of bass. I changed the booster but it didn't help. After some diagnosing i found out that the dying booster also killed both of the subwoofers!
So i now have new booster amp and new aftermarket subwoofers and everything works again and the sound is better than before..
      11-15-2023, 05:51 AM   #81
short24nc
Drives: 2021 X3 M40i
Did you ever get this resolved? I have an aftermarket amp and subwoofer installed and don't feel like taking everything out and going to the dealer so I may just buy a used amp and install myself. Did you have to get it reprogramed?
Thanks
      12-13-2023, 05:28 AM   #82
SoundHound75
Drives: BMW 535i
pinout
does anyone have the pinout of this booster amp?
HV5A38AB802
Thank you
      01-04-2024, 03:47 AM   #83
Liotta Soda
Drives: Bmw 340i
Didnt take one got it back all closed up from dealer
I think they reprogrammed
Sound is way better
But still not as good as my jeep
      02-08-2024, 07:59 AM   #84
nil98
nil98's Avatar
No_Country
125
Drives: BMW M3 Competition G81 Touring
Has anyone fixed this themselves? Mine is just out of warranty and displaying exactly these symptoms on the drive home last night. Grrr
      02-20-2024, 12:14 PM   #85
g20exaudinoob
21
Drives: 21' M340i sDrive
I have had the exact issue on my 21MY M340. My car's software is also stuck on the 2021 version for some reason. My car is currently at the dealer and they verified both of my concerns citing 'faults left in the system' and are replacing the Amp and performing a software update, 0 out of pocket. Will see if my issue is truly corrected after picking the car up.
Also, this might be frivolous but does anyone else notice the Harmon/Kardon label not showing up on the volume adjustment? The 2024 M340i loaner provided to me does have that label.
      03-25-2024, 12:49 PM   #86
driverg01
Drives: BMW X3 xdrive 30e
Went to the dealer, they did Booster flash in Ista.
Its fixed!
So no booster replaced. Running for a month without issues now.
g20
