BMW X5
      11-12-2019, 09:19 PM   #23
Stealthall
17
Drives: BMW X5 40i
Originally Posted by LexxM3 View Post
I can confirm that BimmerLink (from the maker of BimmerCode) does open the flap. The car needs to be engine-running, however. I did use this technique to open the flap and pull the cable to have it stick open.
And what about using the system to open the flap and then pulling the fuse?
      11-12-2019, 09:21 PM   #24
LexxM3
LexxM3's Avatar
1703
Drives: E46M3, G05X5
2019 X5  [0.00]
Haven't tried that specifically, but I don't see any reason it would not work the same.
G05 X5 x40i (04/2019 mfg, Canada) on S18A-19-11-540
      11-13-2019, 06:23 AM   #25
Stealthall
17
Drives: BMW X5 40i
Well...I will let you know tonight.
      11-13-2019, 10:26 AM   #26
six
393
Drives: G05 X5 50e
That will be interesting! I’ve got the adaptor for Bimmercode, had no idea there was a BimmerLink app offering the same capability as Carly so nearly ended up buying a Carly adaptor! If the BimmerLink app works and the the valve stays open with the fuse removed it will be a result
      11-13-2019, 10:43 AM   #27
G050i
12
Drives: BMW X5 (G05) 50i w/ M-Sport
Do you have a 40i or 50i? I really want to know if its worth to keep the flap open on the 50i. The cold start up is amazing coming from the V8 but it dies down a lot. I'm also surprised that there's not much crackles or burps on a down shift with high rev RPMs. Unless I'm doing something wrong.
The video of the guy who used Carly and had the 40i even got some better sounds exhaust tones than my 50i
      11-13-2019, 01:17 PM   #28
Stealthall
17
Drives: BMW X5 40i
Mine is a 40i
      11-13-2019, 02:00 PM   #29
Stealthall
17
Drives: BMW X5 40i
Well...I was able to slip home for a minute...
Plugged in the Carly...went to features...exhaust flap...and opened the flap. You can hear it opening and closing...left it open...went into the trunk and pulled fuse #203...I believe that worked.
The only thing I am not sure about...is I forgot (after plugging in the Carly and restarting the car) to move the drive mode to Sport Plus. I am not sure if that matters or not. Either way I believe this method does work.
I will mess around with it more this evening.
      11-13-2019, 04:50 PM   #30
KrisV
KrisV's Avatar
210
Drives: 2023 BMW X5 M Competition
yes, let us know!
      11-13-2019, 04:59 PM   #31
Stealthall
17
Drives: BMW X5 40i
Originally Posted by KrisV View Post
yes, let us know!
Update: it worked. I even went through the process of putting it all back to stock, and redid it with the car in Sport Plus.
Good to go.
KrisV209.50
      11-13-2019, 05:57 PM   #32
KrisV
KrisV's Avatar
210
yes, let us know!
Good to go.
how can you tell if it's open or not? i can't hear anything when pressing the button. Also it reverts back to "Auto" after I hit the "Open" button...
      11-13-2019, 06:02 PM   #33
Stealthall
17
Drives: BMW X5 40i
If you stand at the back of the car you can hear it opening and closing.
      11-13-2019, 06:24 PM   #34
KrisV
KrisV's Avatar
210
i don't hear anything when hitting either button
      11-13-2019, 06:48 PM   #35
Stealthall
17
Drives: BMW X5 40i
What are you using? Carly? Is the fuse in or out?
      11-13-2019, 06:51 PM   #36
KrisV
KrisV's Avatar
210
i'm using OBDLink MX+. Fuse is in right now
      11-13-2019, 07:12 PM   #37
KrisV
KrisV's Avatar
210
what adaptor are you using? i'm using OBDLink MX+ with BimmerLink and can't hear it opening or closing at all. Also when i hit "Open" it goes right back to "Auto"...
      11-13-2019, 08:02 PM   #38
Stealthall
17
Drives: BMW X5 40i
I’m using Carly. Very simple, tap open....hear noise, tap close....hear noise.
      11-13-2019, 08:14 PM   #39
homerrr
homerrr's Avatar
134
Drives: BMW G05
Try this in the settings. I remember having something similar be the problem but that was half a year ago.
Type: Electric
Timeout: No
Slave: No
Good luck
LexxM31703.00
      11-13-2019, 08:50 PM   #40
LexxM3
LexxM3's Avatar
1703
2019 X5  [0.00]
Same adaptor. Try what homerrr suggests — in the meantime I'll check my settings to see if they match his suggestion.
      11-14-2019, 07:31 AM   #41
KrisV
KrisV's Avatar
210
Type: Electric
Timeout: No
Slave: No
Good luck
ok i'll try this thanks
      11-14-2019, 07:32 AM   #42
KrisV
KrisV's Avatar
210
yeah lmk your settings when you get a chance. thanks
      11-14-2019, 11:49 PM   #43
LexxM3
LexxM3's Avatar
1703
2019 X5  [0.00]
My settings are similar to homerrr:
Type: electric
Timeout: no
Slave present: Automatic
Definitely seems to work.
      11-15-2019, 08:49 AM   #44
six
393
Drives: G05 X5 50e
Just done mine using BimmerLink with the above settings. I could open and close the valve with the engine off. Pulled the fuse and now to live with it a bit and see how it is
Would be nice to have some way to manually control the value without needing to connect the ODB adaptor and use my iPhone which is a pain.
Are there any downsides to leaving the ODB adaptor connected all the time? I notice it’s able to draw power through the port when the car is shut down. I wouldn’t want to have it draining the battery when the car isn’t in use or does the port power down at some point after the car is locked?
xbimmers
