Dyno Results
05-11-2016, 12:45 AM | #1 |
374
Rep 1,392
Dyno Results
I put my car on the Mainline dyno at RealDyno Performance today to measure the power and torque output. Results were 383.5KW (514HP) and 1007.7Nm. Considering I do not have PI or 100% E85, I am very pleased with the results. It appears the old RB Turbos can still produce an acceptable amount of power and torque. Now it is time to produce some decent times at the drags.
05-11-2016, 01:09 AM | #2 |
162
Rep 1,175
Hey mate
Good results especially for a mainline dyno. Power delivery looks nice and smooth with great torque numbers. AFRs look tidy. What PSI is it peaking at? Are you running JB4 with a backend flash? Time to hit the drag strip again |
05-11-2016, 02:22 AM | #3 |
830
Rep 3,189
Thats higher torque then vtt gcs turbos at 30+psi.
What size is mainline roller 273 or 219? I would take 24.6% off torque no.s, it looks like torque no.s of a 273 roller. At 23 ish psi you are making very good power and torque. Should be quick at the1/4 |
05-11-2016, 02:41 AM | #4 |
4547
Rep 11,905
Nice results Coops .... who did your tuning??
05-11-2016, 03:00 AM | #5 |
596
Rep 1,693
My local mainline does the same thing. Weird. Both my last 2L turbo engines making 300kw - 800nm. My brother's 300kw 4L N/A V8 - 700nm. My 335i with 250kw - 1000nm. All unrealistically high torque.
05-11-2016, 03:26 AM | #7 |
1496
Rep 3,148
Haha 1007Nm at the wheels? Wildly optimistic
05-11-2016, 04:09 AM | #10 | |
327
Rep 960
probably a third gear pull or fourth gear isn't quite 1:1. 383kw at 6k rpm is around 600nm. Edit: Looks like you're putting around 650Nm of torque based on power graphs - Solid result Last edited by titium; 05-11-2016 at 04:19 AM.. |
05-11-2016, 04:17 AM | #11 |
374
Rep 1,392
Yes, the PTF tune appears to be working quite well looking at the power curve. The AFR is a little on the lean side but not too bad. Boost pressure is reaching 26psi. I am just running Cobb with an E60 custom tune from PTF. Nothing fancy. Hopefully, I may be at the drag strip next Wednesday night, if conditions suit.
05-11-2016, 04:27 AM | #12 |
374
Rep 1,392
Hi Brule. Not sure what size roller the dyno has but I will find out tomorrow. I agree with your assessment that the torque is too high. I was getting around 800NM of torque using the E30 Cobb Generic tune on a Dyno Dynamics dyno. This fits in the range if you reduce the 1007 by 24.6%. As I am getting 125mph at the strip, I believe the power is correct.
05-11-2016, 04:35 AM | #14 | |
162
Rep 1,175
Okay so its flash only tune. Looking good |
05-11-2016, 04:40 AM | #15 |
374
Rep 1,392
I believe maybe 11.3s is achievable if I can get my 60' times down into the 1.6s as I did a 11.6s with a 1.9s 60'. I will also try a 2nd gear launch as I am loosing 0.14s on the 1st to 2nd gear change. It is interesting when I compare my previous G6E turbo power/weight ratio with my Beemer. The G6ET put out 430rwkw and weighed 1,900kg (P/W = 0.23) while the Beemer puts out 383.5rwkw and weighs 1,600kg (P/W = 0.24). The G6ET did a 11.08s @ 126mph. Yes the graph of the Manifold Pressure shows 26-27psi at around 5,000rpm.
05-11-2016, 04:41 AM | #16 |
Jedi samurai ninja turtle
619
Rep 3,021
Drives: X3 M40i 2018
awesome number coupes!!
05-11-2016, 04:42 AM | #17 |
374
Rep 1,392
05-11-2016, 04:46 AM | #18 |
374
Rep 1,392
05-11-2016, 05:04 AM | #19 | |
374
Rep 1,392
05-11-2016, 05:27 AM | #20 |
11 second stock turbo club. 11.6@120mph
115
Rep 1,181
Great numbers mate, car seems to be dialed in pretty well on the dyno. Just need to get it down the track quicker now! Nothing wrong with old style Rb's, as long as they dont smoke then happy days.
When i finally get around to soughting my car car out we should go for a run at willowbank, the weather is cooling right down at night now!! : )
JB4 ISO - 3" Catless Downpipes - RB Inlets to be fitted - BMS DCI - VRSF 7" intercooler - Charge pipe & Raceport BOV - BMW PE exhaust - Stage 2 fuel pump - BMS E85 Flash/ E50 mix, running map7 - NGK Plugs - BMS Catchcan - RB pcv valve - Quaife LSD - 19'' Beyern wheels - Msport suspension - M3 rep sideskirts - Aero front lip - Lux V5's - Mid kick rear spoiler - Dark tint - Msport steering wheel with M3 paddles & trim
05-11-2016, 05:37 AM | #21 | |
281
Rep 1,808
05-11-2016, 05:39 AM | #22 | ||
327
Rep 960
