DIY - M5 SMG Shift Knob Wiring Retrofit Kit
02-18-2009, 08:29 PM | #1 |
72
Rep 929
Drives: E90 2007 328xi
by a l l an based on ironic's initial design DISCLAIMER It's your car, not mine. CREDITS Thanks to ironic for creating ver 1.0 of this kit. PARTS Total Kit Cost $240 to $320 (incl shift knob, wiring parts, shift boot, and heat shrink tubing) plus your own time Where to buy Tischer BMW / getbmwparts.com Not in any way affiliated with Tischer but the parts were bought from them. Part #1 - M5 shift knob Shift knob "buy" link (Tischer) http://www.trademotion.com/partlocat...logid=4462&tab Note: The knob on this picture has the E9x auto shift boot pre-sewn. The actual knob you'll be getting will have a different shift boot that you'll have to replace with your E9x boot. Part #2 - Harness components Part #3 - Shift boot (either you use your existing or buy a new one) Part #4 - Heat shrink tubing (optional) TOOLS 1. Scissor or wire cutter 2. Wire stripper (for 20 and 16 AWG) 3. Hair dryer (if you will be using heat shrink tubing) 4. Electrical tape (if you won't be using heat shrink tubing) TIME REQUIRED A few fun hours PIN ASSIGNMENTS, HARNESS CONNECTIONS, and WIRING SKETCH M5 shift knob pin assignments 1 = Zone Reverse (GND) 2 = Zone Neutral (GND) 3 = Zone Drive A/S (GND) 4 = Night Illumination (GND) 5 = Switched +12v for Night Illumination 6 = Switched/Constant +12v for zone lighting Pin connections M5 pin 1 -> White connector pin 2 (or 3 if you look at it as a 6-pin connector) (R) M5 pin 2 -> White connector pin 3 (or 4 if you look at it as a 6-pin connector) (N) M5 pin 3 -> Blue connector pin 4 (M/S) M5 pin 6 -> Blue connector pin 5 (Zone illum) M5 pin 4 -> Power connector pin 1 (Night illum - ground) M5 pin 5 -> Power connector pin 2 (Night illum - +12V) Sketch KIT ASSEMBLY The wiring sketch is all you need really to build this kit. Here are a few guidelines/tips that can help you out.
INSTALLATION Step 1 - Disconnect the stock shift knob wiring connections (blue, white and power connectors) Detached female stock connectors Step 2a - Connect the wiring kit female connectors to stock male connectors Get your badass wiring kit and make these connections. The male/female pairs can only be hooked up one way so there is zero chance to mess up the orientation. You'll here a "click" when the connectors snap and lock into place. Tip: Be careful still inserting the connectors to avoid bending the male pins. Step 2b - Connect the wiring kit male connectors to stock female connectors Step 3 - Neatly tuck in the wires and install the M5 shift knob Tip: Route your wires to the top of the center console so they don't get in the way of the shifter. Tip: Don't permanently close your center console yet as you still need to test the knob and gear functionality. I just can't wait to show you how awesome it looks right now. Step 4 - Test your super knob Check that the knob illuminates the selected gear and make sure the gears are working properly. Now it's time to celebrate!
E90 2007 / Step / Montego Blue / Black Dakota Leather / Premium / Cold Weather
MODS: Exterior: Blacklines, debadged, HO ceramic 35% tint, Hoen yellow fogs, matte black grille, OEM style splitters, Halogen-to-Xenon Interior: Alum pedals, CF wrapped trim, V1 and Nuvi hardwire, M-Tech tri-stitched wheel, SMG M5 shift knob Performance: AluFelgen CSL 19" 8.5 ET33/9.5 ET30 with 5mm rear spacers | GY Eagle F1 Asym 235/265, KW V3, BMW Perf exhaust+intake Last edited by a l l a n; 02-21-2009 at 09:10 PM.. |
02-18-2009, 08:29 PM | #2 |
72
Rep 929
Reserved
MODS: Exterior: Blacklines, debadged, HO ceramic 35% tint, Hoen yellow fogs, matte black grille, OEM style splitters, Halogen-to-Xenon Interior: Alum pedals, CF wrapped trim, V1 and Nuvi hardwire, M-Tech tri-stitched wheel, SMG M5 shift knob Performance: AluFelgen CSL 19" 8.5 ET33/9.5 ET30 with 5mm rear spacers | GY Eagle F1 Asym 235/265, KW V3, BMW Perf exhaust+intake |
02-18-2009, 09:58 PM | #4 |
Rep 272
some on should create a wiring harness!!!
twinscrolled38.50 |
02-19-2009, 05:29 AM | #8 |
Mu mu muh muli, maikouuu!
86
Rep 1,286
THUMBS UP!!!!!!!
02-21-2009, 10:02 AM | #9 |
72
Rep 929
Updated the DIY but it's still not done yet.
02-21-2009, 05:42 PM | #10 |
30
Rep 949
You're the man - thanks for another great D.I.Y.
2008 e92 335i Step | Is Gone - It was fun but not meant to be | M3 - Cancelled | 135 Ordered
02-21-2009, 06:53 PM | #11 |
Mr. Nice Says Hello
638
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
very nice subscribed
02-21-2009, 08:51 PM | #12 |
72
Rep 929
Finally done guys!
02-22-2009, 09:24 AM | #14 | |
72
Rep 929
Sorry, I don't have an extra kit. This is an easy DIY so give it a try.
02-22-2009, 09:39 AM | #15 | |
180
Rep 5,822
02-22-2009, 09:43 AM | #16 |
72
Rep 929
02-22-2009, 10:31 AM | #18 |
180
Rep 5,822
02-22-2009, 10:55 AM | #19 |
72
Rep 929
02-22-2009, 08:38 PM | #20 |
Gixxer Man
14
Rep 599
Nice bro!
Stable: 2008 E90 335i JB3 etc..., 2006 Range Rover HSE, K7 GSX-R 600
Former Stable: 2008 MB C300, 2007 Chevy Avalanche, 2006 Evo IX (544awhp), 2005 Sti, 2003 Evo... |
02-25-2009, 09:22 PM | #21 |
BK Employee of the month! / Moderator
640
Rep 15,795
Great work Allan! Didn't even know you were working on this.
Sponsored by: Pics of the ---> Barbera Beast <--- Martino Auto Concepts (Like them on Facebook MAC) Factory Trained & Authorized by BMW of North America Matt@Camber-Toe (Like them on Facebook Camber-Toe) LuxAngelEyes (Like them on Facebook LuxAngelEyes) LTBMW (Like them on Facebook LTBMW) OEMconcepts (Like them on Facebook OEMconcepts) |
02-25-2009, 11:13 PM | #22 |
72
Rep 929
Thanks Scott!
