ZPOST
Go Back   ZPOST > BMW Z4 Roadster and Coupe > General BMW Z4 Forum
  TireRack
      04-11-2024, 06:45 AM   #1
2one3E90
2one3E90's Avatar
2422
Drives: Bmw 330i and Bmw 328i
2010 BMW 328i  [10.00]
2004 BMW Z4   [9.67]
2006 BMW 330i  [10.00]
Z4 M54
Hi guys, its almost summer in california and is it okay to use a 20 coolant / 80 distilled water mix?
      04-11-2024, 11:10 AM   #2
Clearancediver
97
Drives: 2004 Z4
No… use the proper ratio. What your are proposing will lower the temperature at which the car coolant will begin to boil over…… the opposition of which you think you are going to accomplish.
Sent from my smart phone...
2one3E902422.00
      04-13-2024, 11:57 PM   #3
itsjustascratch21
Drives: BMW Z4 2.5i
If your topping up with that, you'll be fine. Tap water is fine too, adding coolant for a top up is overkill.
If you're performing a drain and fill 80/20 is probably okay depending on how much coolant you have on hand. I wouldn't worry about it too much water under pressure has good heat capacitance.
The heater core hoses and o-rings take a beating in the summer if you run the air conditioning in traffic.
2one3E902422.00
      04-14-2024, 12:06 PM   #4
Clearancediver
97
Drives: 2004 Z4
You should read up on the properties of coolants and proper ratios…
2one3E902422.00
      04-14-2024, 03:47 PM   #5
pungo
pungo's Avatar
886
Drives: Z4MC-X3-35i-525i, Corrado G60
I do not recommend this, especially using "tap water".
Use a 50/50 mix of coolant/distilled water, no matter where you live, no matter the time of the year. There's way more properties to antifreeze than simply preventing freezing, fact...
zpost
