Walnut blast - my experience and pics
01-06-2019, 07:41 PM | #89 | |
Rep 11
I have that book and skip barbers too, I learned to race with those manuals! |
12-03-2023, 11:21 PM | #90 |
Major nutz
86
Rep 1,489
Drives: '09 n54 e92xi, 6mt, kw v3
Nearly 10 years and 70k miles later (car now has ~108k miles total) I am doing it again because I am replacing the HPFP.. I'll take some pics and post up soon. I do have an oil catch can. I last emptied it about 2 years ago, but I don't drive as much any more - about 5k a year. Just emptied it and it had about 30mL of oil. So about 10-15 mL per 5000 miles. 15mL is a about a tablespoon.
I had my HPFP replaced by warranty in first 5k back in 09, almost exactly 100k later, the replacement went bad. From what I have read, it's like right on schedule. Ha ha. They seem to last 100k miles. https://www.e90post.com/forums/showt...7#post30710207
12-27-2023, 05:11 PM | #91 |
Rep 29
@IN54NITY I see from an earlier post that you are/were in Louisville, are you still there? If you haven't done yours yet, I could help you do yours, and then we work on mine ?
I'm in Louisville, too. Last edited by earlster; 12-27-2023 at 08:01 PM.. Reason: Added mention |
01-01-2024, 10:47 PM | #92 | |
Major nutz
86
Rep 1,489
StradaRedlands4998.50 |
01-01-2024, 10:52 PM | #93 |
Major nutz
86
Rep 1,489
Hi. Yep, still in Louisville. Give me a text or WhatsApp.... Seven two oh - three four three-0340.
01-02-2024, 05:04 PM | #94 |
48
Rep 139
Wow that is a great improvement.
I just completed walnut blasting on an N55 engine (while replacing the HPFP) and even after 130,000 miles, it wasn't that bad. Seems the N55 has a better PCV system which carbons the valve less than the N54. After the work, I kept researching valve cleaning and found this video to be informative: It compares scraping to soaking in brake fluid to even starting with zip-ties in a drill. Based on that video, if I were to do it again, I would start with zip-ties, proceed to scraping with hooked tools and then blasting. There are several videos showing how useless the products are which you spray into the intake while the engine is running. Several take pictures of the valves before, reassemble the engine, do the spraying and then disassemble to show the result. In short, it takes a microscope to notice any difference. I do wonder if the better products might be useful to use e.g. every 3000 miles after a thorough physical cleaning. Here is one video showing how useless they are:
2017 M3 DTC * 2013 M3 Manual
2017 330i (Winter beater) 1981 Camaro Z28 - 427 LS3 - 10.94 @126mph 2006 Corvette (streetable track car) 1986 535i "24 Hours of Lemons" also streetable |
04-16-2024, 06:31 PM | #96 |
Major nutz
86
Rep 1,489
05-08-2024, 09:50 PM | #97 |
64
Rep 522
05-12-2024, 05:17 PM | #98 |
Major nutz
86
Rep 1,489
The DIY I mentioned in post #1 is really good and please reread that post - because I did. You would be bored to tears watching someone else scrub away... Ha ha. BTW, another tool I added to this job is my 9mm gun cleaning kit.... Get a bunch of 9mm brass brushes (that you will absolutely crud up) and corresponding handle and rod and use it to scrub. Worked perfectly and cut down on time.
Tags |
walnut blasting |
