F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Most miles on B58 engine
ARMA SPEED
      01-09-2022, 11:00 AM   #45
ATL_Nak-Muay
ATL_Nak-Muay's Avatar
35
Drives: BMW 340i Msport
2016 39k. No issues as of yet, Mhd stg 2 on e30. In love.
      01-10-2022, 08:12 AM   #46
colin2211
44
Drives: 2016 BMW 340 xdrive , 2008 M3
Originally Posted by StannisBaratheon View Post
Have you replaced the fluids in the transfer case, differentials, and transmission?
I'm still on the stock clutch ....have not done the fluids in the transfer case or the transmission
had the rear diff flushed around 170k
its been in for all regular maintenance over the course of its life ....filters , spark plugs , brake fluid flush etc
the suspension is starting to show its age....rear shocks are weeping a bit and the front thrust arm bushing need to be replaced
Appreciate 2
G.Newt810.00
      01-10-2022, 08:35 AM   #47
aardate
aardate's Avatar
No_Country
194
Drives: X4MC
That is impressive, what are your plans for the car? are you keeping it longer?
      01-10-2022, 05:33 PM   #48
G.Newt
810
Drives: CT4-V Blackwing 6MT
So the only repair you've needed was the wastegate and the suspension finally showing wear? That's insane. Here I've done tranny fluid every 30k, diff/xfer case every 40k and I thought I was late on maintenance lmao. That's a great testament to the B58. Injectors holding up okay as well? Thanks.
2022 CT4-V Blackwing 6-speed
SOLD: 2016 340i xDrive 6-speed
DAW v2.5 turbo E40 | Dorch S2 | VRSF DP | MST intake | AWE catback | 335is clutch | CSF heat exchanger | RK Autowerks intake manifold | Orange M Perf Brake Kit | KW Street Comfort coilovers | GTS taillights V2
      01-11-2022, 10:30 AM   #49
Nickski06
53
Drives: 2016 340i M-Sport
I’ve had my 2016 340xi M-sport for coming up on 3 years here soon. I’m at 68k and been running the JB4 for about 2 years and 18k miles. I changed the plugs at 50k when I added the JB4 just because, no issues with them at the time. The only other maintenance besides oil changes have been tires, the rear brake pads and cabin air filter. Been an awesome car for me so far.
      01-11-2022, 01:09 PM   #50
colin2211
44
yep all is well....the b58 is bullet proof....prob just gonna hang onto it as a daily beater because its pretty much worthless with the miles. And its in great shape cosmetically inside and out.
no known fueling issues....the car does get 44k fuel treatment when in for service
If you are in the CT area German Auto in Watertown is the best place to go to.
I dont count this one but....
Early on I did have the issue with the pebbles going through the intercooler making the a/c not work ....but since the oem rock guard was installed it has not happened since. This was a fight w/ bmw as 2017+ all came from the factory with rock guards on the intercoolers as far as i know
      01-11-2022, 01:11 PM   #51
G.Newt
810
This is a testament to the motor. Original water pump and gaskets too? Sir you might have a unicorn: an exception to the rule 😂 I pray I have your luck lol. Thanks for sharing with us man.
      01-11-2022, 07:01 PM   #52
blacksapphire440i
Novice
blacksapphire440i's Avatar
312
Drives: 2018 440i Gran Coupe
When would you change the valve cover gasket for our engines along with the water pump? What other gaskets do we need to worry about
dmanb2b2131.00
      01-12-2022, 07:35 AM   #53
SimSimmaF30
SimSimmaF30's Avatar
24
Drives: F30 340i Msport
Originally Posted by gdgraph View Post
Who's got the most miles on their B58 engine? Post your mileage!
I'm 47500. 2018 340i msport. One and only upgrade thus far is the Eventuri Intake. Plan on keeping her for a bit so mods are coming slowly but surely.
Shawn
      01-13-2022, 03:26 AM   #54
Stels7s7
Ukraine
Drives: BMW F30 B58
161k km
      02-22-2022, 12:56 PM   #55
colin2211
44
over 200k miles now....200235 to be exact haha
Appreciate 3
G.Newt810.00
Morry1.50
      02-23-2022, 07:18 AM   #56
MoeTE87
OHIO STATE
MoeTE87's Avatar
686
Drives: 2021 BMW M340i
2018 340i msport with only 14k miles. Bought it in 10/2020 and have only put on 4k miles since owning the car. I installed the MPPSK last March and its been a blast ever since!
Present: 2021 BMW M340i Mineral White
Past: 2018 BMW X5 Mineral White, 2018 BMW 340i Alpine White, 2016 BMW F15 X5 xDrive / Glacier Silver, 2011 BMW 335xi / Alpine White, 2008 BMW 135i Sedona Red
      02-23-2022, 09:32 AM   #57
JezB58
16
Drives: F31 340i
Amazing!
You are blazing a trail for the rest of us.
My 340i has just passed 90k miles.
Been running BM3 stage 2+ with VRSF sports cat and TU pump for the last 10k.
I changed the plugs and oil around the same time so will be doing oil again soon.
      02-23-2022, 02:08 PM   #58
G.Newt
810
Originally Posted by JezB58 View Post
Amazing!
Is that 10k km? That's about 6,200 miles. I'd get an oil analysis done to see if you need to shorten that interval. Otherwise I recommend shortening that to 6000-8000km
      02-25-2022, 10:40 AM   #59
hellogoodbye44
Drives: F36
2018 440i stock b58 with mppsk
im at 64k miles, so far did filter changes, oil changes, spark plugs and coils.
      02-25-2022, 10:49 AM   #60
Jnat
DisplacementReplacement
Jnat's Avatar
430
Drives: 2020 X3M
49k miles and stage 2+ for half of that. drive hard but not abusive... 5k oil and filter intervals, plugs at 40k, filters, brakes ect::: fingers crossed...
2020 X3M /// MHD Tune
Prior Bimmers
2017 240XI Hybrid / FBO / MHD E40
2015 235XI FBO / MHD E30
2009 335XI FBO / COBB / E30
      02-25-2022, 11:35 AM   #61
JezB58
16
Drives: F31 340i
10,000 miles so yes, I definitely need to get it done !
      02-25-2022, 11:39 AM   #62
G.Newt
810
Yeah I'd cut your oil change interval to about half (5k miles) until you get an oil analysis done.
      03-03-2022, 03:06 PM   #63
2013mingrey335i
21
Drives: 2016 340i
I just hit 110,000 with my 2016 340 tuned since 60k running MHD stage 2 with high flow DP
Just basic maintenance and thrust bushings were done last time oil every 5-6k most miles are highway and nyc was thinking of trading in for either M3 or m550 but not sure
Appreciate 2
      03-06-2022, 03:23 AM   #64
alpinweiss340
alpinweiss340's Avatar
88
Drives: 340i
Damn. And I thought I was late getting a oil change done after 5k miles.
Currently sitting at 64k miles
      03-06-2022, 03:46 AM   #65
G.Newt
810
Yeah I'm shortening my intervals to 3,000 - 4,000 miles, especially now that I'm on E50 fuel and upgraded turbo. Also switching to Redline 0W-40 from Castrol on the next oil change as it has a higher viscosity and actually comes with BMW LL-01 cert. Oil analysis said Castrol was just a bit under spec viscosity after 4,500 miles.
      03-06-2022, 09:21 AM   #66
dmanb2b
2131
Drives: G07, F97, F30, E90, E46, E30
When they start leaking :>)
f30post
