03-17-2022, 10:58 AM | #45 |
Rep 13
If anyone in the market for an upgrade to a CS then you are in luck. A lot of CS's are becoming available due to lease turn-ins.
https://www.carfax.com/Used-BMW-M3-CS_t14170 |
03-17-2022, 11:23 AM | #46 | |
7609
Rep 3,608
Current: F80
Prior: F82, F32 |
03-17-2022, 11:26 AM | #47 | |
21131
Rep 20,742
Drives: 2021 911 turbo
His track reviews moved to Roadshow. He recently did the G80 and the 992TT-S (the latter here, but interesting to me ).
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 03-17-2022 at 01:22 PM.. |
03-17-2022, 12:51 PM | #48 | |
2756
Rep 3,361
One thing Andy might not be aware of is that the BMW * version of the PS4S developed specifically for the G8x is a *lot* different than the normal replacement market PS4S. I think it was the Tyre Reviews guy who did the comparison testing not too long ago. The G8x specific PS4S* performs more like a Cup2 240.
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 |
03-17-2022, 01:14 PM | #49 | |
21131
Rep 20,742
As to comparing them to the 240TW PSC2, it is more complex. From everything that I have read, the "new gen" 240TW PSC2 is actually a better track tire than the "old gen" 180TW PSC2. Which leads me to believe that 240TW PSC2 is still slightly better than the G8X spec PS4S, but that the G8X spec PS4S is likely equivalent or even better than the old 180TW star spec PSC2. If I would have kept my M4cs, the G8X spec PS4S are the tire I would have installed on it. BMW definitely got something right on the G8X by speccing proper tires. The OE tires on the F8X were its weak point, the OE tire on the G8X are one of its strongest assets.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 03-17-2022 at 03:07 PM.. |
03-17-2022, 05:15 PM | #50 |
Rookie
54
Rep 213
To add to this thread, just for reference. I replaced the oem PSS tires on my m3cs today with a set of 265/35-19(98Y) and 285/30-20(99y) pilot sport 4S and couldn't be happier. I was afraid the larger fronts would mess with the razor sharp front end but it feels great and these tires are leaps and bounds better than the oem PSS.
2018 M3CS SMB
03-17-2022, 07:08 PM | #51 | |
21131
Rep 20,742
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
03-17-2022, 07:10 PM | #52 |
771
Rep 957
IMHO PSS are garbage tires on this car, easily overwhelmed. I went to PSC2 265 F/285 R and the grip is phenomenal and once CCB's are warmed up, dang.. It's like dropping an anchor behind you, I'm not sure why mags/reviews shit on the CS but its one heck of a car once you learn its quirkiness. DSC always off, MDM in the rain.
M4CS Frozen Blue
ARM DP's/Resonated Mid-pipe | SPL links | Hotchkis bars | JRZ RS2/camber plates | K&N | Koyorad HX | Powerflex purple | Rouge | Spiegler | Speed Eng. snorkel | Vargas CBC/hub | Wagner IC | xHP | Xpel stealth ppf |
03-17-2022, 07:25 PM | #53 | |
1863
Rep 893
Instagram: slcook54
03-17-2022, 10:42 PM | #54 | ||
Rookie
54
Rep 213
2018 M3CS SMB
slcook541863.00 |
03-17-2022, 10:54 PM | #55 | |||
1863
Rep 893
Instagram: slcook54
03-17-2022, 11:03 PM | #56 | ||
168
Rep 823
03-18-2022, 04:43 AM | #57 |
21131
Rep 20,742
According to Michelin, the 9” wide wheel is within the acceptable range for the 275/35R19 PS4S. I ran the rear star spec 275/35R19 PSS, which has a wider thread than the PS4S*, on the front of my M4 for a period without rubbing issues.
GB///M167.50 |
03-18-2022, 05:29 AM | #58 |
2756
Rep 3,361
Was it your car that had the mismatched rear tires too? Toyos or something back there? Don't underestimate the directional stability impact of running two dramatically different tires front vs rear, especially when the junkier tire (tire that requires higher slip angle for equivalent grip and/or has a lower spring rate sidewall) is on the rear. If so, the car will be completely transformed with proper matched tires on it.
Current Stable:
Wanted_M771.00 |
03-18-2022, 09:48 AM | #59 | |
1863
Rep 893
Instagram: slcook54
CSBM52756.00 |
03-18-2022, 08:53 PM | #60 |
771
Rep 957
^^ I suggest get new tires first before removing parts to see how it changes the vehicle dynamic. I have Dinan HAS and have zero of the issues you keep bringing up with aftermarket sway bars and end links and its tight (soft setting right now f/r).
When I had stock suspension, I found the rear of car loose/wobbly on entry and especially when the road had undulations or ripples. Gone now, no rubbing or pushing. Any who, that's my experience so far. I just received my BAF rear K brace to tighten it a bit more. I did it in the meantime till I fork over $$ for a set of coils.
M4CS Frozen Blue
CSBM52756.00 |
03-20-2022, 10:54 AM | #62 | |
197
Rep 319
If you live in a once you can ride low can’t go wrong w EMDs |
03-20-2022, 11:43 AM | #63 | |
7609
Rep 3,608
Just my 2-cents based on experience with lowering stock shocks.
Current: F80
Prior: F82, F32 |
03-20-2022, 12:19 PM | #64 |
14
Rep 90
Beautiful cars , congrats to all of you.I was going to pull the trigger on a Grey cs but I ended up with a YMB . I really like the door trim on these too (cs) maybe ill do a swap later down the road
03-20-2022, 12:23 PM | #65 |
21131
Rep 20,742
MP-HAS
03-20-2022, 12:25 PM | #66 | |
21131
Rep 20,742
