BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Need help with offsets
proTUNING Freaks
      10-21-2012, 01:32 PM   #1
RollingLower42
RollingLower42's Avatar
71
Drives: 2012 BMW 335I
Hello, I need help with offsets..
Tried going to LTMW yesterday to put on Rep. rims, Varrstoen es112 19x11 +25 and 19x9.5+20
Needless to say, they told me from the get go it wouldn't work, but I had placed the order before that with Varrstoen. I am planning on returning them Monday (did not mount tires)
From what everyone told me, if I want to run those size rims, I would need the specs to be:
19x11 +44
19x9.5+38
I talked to Varrstoen and they said they do not make offsets that high, (highest offsets they go is +35) so it is looking like I will not be running Varrstoen's anymore..
Can someone tell me if the + 44 and + 38 set up would work? I think I read somewhere the F30 has a minimum +36 and up?
Another Question, I have old rims from another car, but they are different bolt pattern. They are from a 2009 Volvo S80, they are Asanti 19's fronts and backs (I do not know offsets off the top of my head, have to check on that Monday) but the bolt pattern is 5x108 for the volvo and I believe the F30 bolt pattern is 5x120. Do you think there is any way I could get a adapter and possibly be able to use the Volvo rims on the F30? Or is that impossible and not going to work too?
Any info would be appreciated..
      10-21-2012, 03:02 PM   #2
rxander
rxander's Avatar
16
Drives: F30 Alpine White
Have you considered fender rolling? Only way to be sure that they won't rub. I have not seen any f30s run that aggressive offset.
      10-21-2012, 04:11 PM   #3
RollingLower42
71
The lower offsets (+20 and +25) stuck out way too far. I also recommended fender rolling, but it is just plastic, they said rolling the fenders wouldn't work either
      10-22-2012, 09:26 AM   #4
F555
F555's Avatar
Indonesia
37
Drives: F30 - 335i
U gotta order wheels with custom offset.
19x11 +44
19x9.5+38
those offset are almost the same as what I ordered for my Vorsteiner.
Can't be 100% sure they will fit, as my wheel has not yet arrive. Probably a bit of fender rolling might be necessary for the rear & the Front should clear just fine.
Adding adapter on F30 will make the offset even lower, in the end the wheel wont fit,
I've seen wheel Hub being re-drilled on old bimmer, so it can be double PCD 120 & 112(merc PCD), but can't guarantee that is safe.
my suggestion is Order a wheel that can be custom offset, Save u all the trouble.
      10-23-2012, 12:33 AM   #5
RollingLower42
71
19x11 +44
19x9.5+38
Thanks for the info, you got pics of those size and offset of the Vorsteiner? I would love to see what it looks like
      10-23-2012, 05:52 AM   #6
F555
F555's Avatar
Indonesia
37
Drives: F30 - 335i
No Pics yet.
I'm still waiting for the wheel to arrive. was estimated end of this month by the wheel shop, but I doubt it, prob gonna see it at mid November.
btw mine is 20" tho but similar size & offset for the rear.
      10-23-2012, 11:18 PM   #7
RollingLower42
71
No Pics yet.
Nice, good luck, post some pics when they come in..
      10-24-2012, 01:19 PM   #8
jrob
Bimmer God
Drives: 2003 BMW 330i
That is a wide rear wheel....
