BIMMERPOST Universal Forums Classic BMW (Pre-2005 Models)
      07-30-2021, 07:45 PM   #1
Jacksonavenue
Jacksonavenue's Avatar
Drives: E46 330ci / E32 735i
E32 wheel compatibility with other models
I have a 1988 735i and struggle to find wheels for it. Can I broaden my search to e34 or e38 wheels? Would they fit?
      07-30-2021, 11:25 PM   #2
Monoblock
Monoblock's Avatar
83
Drives: 2021 X3 M40i
Googling yielded:
http://bmwe32.masscom.net/johan/information/wheels.html
      07-31-2021, 07:01 AM   #3
BMWCCA1
BMW Owner Since 1971
2272
Drives: 1964 700 Sport Cabriolet
2013 BMW 128i  [10.00]
Just check the offset. Any E39 wheel will require a 2mm spacer for the hub (inexpensive).
      07-31-2021, 11:36 PM   #4
LOW4LYF
LOW4LYF's Avatar
2164
Drives: E92 M3 & F85 X5M
Originally Posted by BMWCCA1 View Post
Just check the offset. Any E39 wheel will require a 2mm spacer (inexpensive).
E39 will not fit, different center bore.
      08-01-2021, 08:32 AM   #5
BMWCCA1
2272
They will fit just fine if you purchase a cheap set of (aluminum) spacer rings to fit over the hub-centric location. I have E39 wheels on two E28s and have had them for years. I also own two E39s so I understand the issues. Thanks for your contribution.
Appreciate 3
Vivek.1367.50
VisualEcho6642.50
      08-02-2021, 01:13 AM   #6
Jacksonavenue
Originally Posted by Monoblock View Post
Thanks for that link. Very helpful
      08-02-2021, 01:19 AM   #7
LOW4LYF
LOW4LYF's Avatar
2164
I own a E32 and owned one E39, there is really no need to put E39 wheels on the E32 and work with hub rings and spacers. Other wheels are plug & play.
But everyone is different I guess.
      08-02-2021, 04:39 PM   #8
Vivek.
1368
Drives: 335is coupe, e30 vert
This is a very different response than "it will not fit".
OP--I don't know the offset range for e32 specifically, but you can use a variety of options as long as it's a 5x120 and has similar offsets. I have e31 turbines on my e34, it's a 5mm lower offset and looks good.
Edit: looked it up an e32 is typically around a 7" width and 20mm offset. Anything close to that will work. You can use a calculator like willtheyfit.com to visualize the differences between your stock wheels and potential replacements.
Originally Posted by relative4 View Post
My wife would give me so much head if I did that.
2013 335is Mineral/Coral - DR 6466 - DR Mani - PI - Motiv FF - Dodson Clutches - OEM CF Roof - M3 GTS DCT/LSD/DS/Halfshafts/Suspension/Subframe/Brakes/Chassis Bracing F+R - DEFIV Diff Brace - 437M/R888R
2015 X5 35D - 1990 535i [RIP] - 1992 318i Convertible - 2002 540i/6
      08-03-2021, 07:54 PM   #9
LOW4LYF
LOW4LYF's Avatar
2164
E39 will not fit without additional hardware, so what is wrong with that statement?
You can have every wheel technically redrilled but than again... what's the point?
Plenty E34 wheels out there which are plug and play for the E32.
      08-07-2021, 09:08 AM   #10
Bobbyl99
Drives: 2014 BMW M2 F87
I agree with you
I did agree with this point of yours.It ll fit with a set of aluminum spacer rings to fit over the hub-centric location.
      12-26-2023, 07:05 PM   #11
Bishop64
Drives: 2019 G12 740i M-Sport ;'13 M6
2013 BMW M6  [0.00]
I fit a set of X3 wheels to the E32. I did have to put spacers to correct the backspacing, but I think they compliment the car nicely as if they could have come with the car. I don't have any rubbing issues and the car rides nicely as if it were on stock wheels and tires.
      12-27-2023, 07:26 AM   #12
Chihuahua
Chihuahua's Avatar
4110
Drives: E30 329iS, E65 Alpina B7
I agree with you agreeing to the agreement.
      12-27-2023, 09:40 AM   #13
M-technik-3
2108
Drives: E30 M3, E36 M3, 328iT, 335i
1995 M3  [9.00]
2007 E91  [7.25]
1988 M3  [9.50]
Here's a e32 with 16" E38 style 5's, they are cheap and plentiful and tire sizes give a nice ride.
