02-05-2024, 03:45 PM | #1 |
Petrolhead
441
Rep 810
Drives: 24 X3 M40i/14 550i/08 Z4 3.0si
N63/tu V8 Oil Consumption Settlement
Has anyone here actually gone through the replacement process of their N63 or N63tu engine? I put off dealing with it last year because I was too busy with a new house but I now think my 550i is definitely going through more oil. I have a monthly reminder to check and refill as needed but was shocked to find it in the red for the first time (same timeframe, same rough mileage, same driving pattern).
I really [really] don't want to give this car up anytime soon, so if I can get a new engine with BMW covering 50%, I'll definitely take it. Just looking for any tips or insights before starting the process with the dealership.
2024 X3 M40i 2014 550i 2008 Z4 3.0si 6MT 2011 Z4 35si (sold) |
02-05-2024, 05:23 PM | #2 |
Rep 3
Drives: E81 123D MSPORT, F06 M6 GC.
LONG POST
Have just had my 52000 mile 2013 M6 S63tuV8 replaced by BMW as it was using more oil than it should. Started to use oil about 8 months ago, no smoke at first, went to dealership for oil comsumption test and decided that it needed new head covers, and others bits replaced under warranty. (I had taken BMW extended comp. warr. when I purchased the car from a non bmw dealership). Got car back after about 2 weeks it asked for 1 litre of oil again. Contacted dealership and they said to top it up but keep an eye on it. It then started to have the dreaded puffs of blue smoke when sitting at lights. Back to the dealership it went , did compression test and No.8 cylinder was low, bore scope found scoring on same. They went back and forth with technical as they didnt know why bore was scored,that was last October. They eventually agreed to replace engine rather than rebuild on advice of BMW. My car was covered by warranty upto the price I had paid per claim,which was just shy of £30,000. However , as they had already paid out around £6000 for the replacement of head covers/bits before , they deemed that this was still the same claim and would only pay £23,000 toward the new engine which was coming in at £43,000 , leaving me to find £20,000 . I obviously said I couldnt pay that, a bit of arguing and begging the dealer was able to get goodwill from bmw and they reduced their costs which ended up with me having to pay £9000. I am willing to do this as, at the end of the day, I will have a car which I was keeping anyhow only now with a 0 mile engine, rest of car is immaculate. |
spielnicht440.50 ///M TOWN20126.00 |
02-06-2024, 07:52 AM | #3 | |
Petrolhead
441
Rep 810
Thank you for the input and sharing your experience. That's my worry - is that the cost of the new engine (even if I'm paying ~50%) will be as much as the car is worth (without all the mods/add-ons). Will, only one way to find out. Dropping her off tomorrow at the dealer to begin the process. I was planning on getting ~$2,500 worth of parts to address maintenance and other issues - guess I'll put that on hold for now.
02-06-2024, 05:16 PM | #4 |
1158
Rep 1,364
02-06-2024, 05:44 PM | #5 | |
2091
Rep 3,007
When I briefly considering a N63 M car, I happened to meet a fellow that had a N63/N63TU (I forget which one) M5. He told me that he carried a case of oil in the trunk. |
///M TOWN20126.00 |
02-06-2024, 05:53 PM | #6 |
your average JAMF
3157
Rep 4,101
Drives: '21 M2 Comp, '19 Golf R
The problem is the stupid "hot vee" design - they put the turbochargers in the valley between the cylinder banks - which is already a hot area - and created hell under your hood, and all the ancillary problems that go with excessive heat. Horrendous design.
'21 M2 Comp
'19 Golf R |
02-06-2024, 06:31 PM | #8 |
276
Rep 653
02-07-2024, 11:45 AM | #10 | |
3851
Rep 4,181
sticking with the 550 (which i got for a song) and on a wing and a prayer every day mind you, dealer found metal shavings in the diff of my 340 which had next to no miles, so these cars aren't exactly built to last 25 years but i these are the last pure ICE cars and i want them in my garage! ... to F90 or not to F90 ... |
02-08-2024, 07:42 PM | #11 |
Petrolhead
441
Rep 810
Well car is back from the dealership. They had to perform an oil change and started logging oil level. I have to go back after clocking 1k miles for them to check the level or sooner if the oil level gets too low.
I'll keep this thread updated as progress is made.
02-28-2024, 02:20 PM | #12 | |
498
Rep 579
It is also cheaper to repair them here, ofc, so that helps. That said, the N63 will never be a reliable engine, no matter how many folks want to claim it. The hot-v might be good for efficiency in various respects, but it certainly isn't good for daily-driver cars that need to start on a regular basis. |
02-28-2024, 02:47 PM | #13 |
1220
Rep 418
I had several turbo projects where I was concerned about under hood heat. I sent my headers, turbo hot side and hot side exhaust exiting engine bay to Swaintech for coating. I wonder if anyone tried that or header wrapping and hot side blankets to mitigate heat transfer into the heads. If I was spending the coin, you guys had to, it wouldn't be going back in stock to rinse and repeat. I suppose guys were trying all sorts of things like increasing oil capacity and cooling to boot. And dumping the engine cover. Good luck OP!
