BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > F30 Golf tee mod, Clamp alternative to Wire.
Extreme Powerhouse
      03-19-2013, 07:11 PM   #1
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Drives: 2018 Audi S3
Its winter, Im bored and I sort of came up with this alternative way to do your golf tee mod on your F30.
Why you ask? Dosent the wire work just fine. Yes. It does. In fact Its still on my M Performance muffler. Ill put the clamp on it later on. But alot of people dont like the idea of putting cheap wire on their expensive cars, so this looks much better and neater I think.
So since I did my own muffler upgrade, I got to keep my oem muffler. So Ill be demonstrating on it.
I just used a simple clamp. Its best if you have a dremmel tool to cut with.
Tools needed,
Dremmel
8mm socket and ratchet (to tighten clamp)
Caliper (not really reqired) use a ruler.
Let the pictures do the talking.
FBO-PS1 and stuff
      03-20-2013, 04:28 AM   #2
UhhItsANT
77
Drives: 2013 BMW 335i
2013 BMW 335i  [0.00]
Very nice idea... I shall go do this instead. More secured than wires. Haha.
      03-20-2013, 04:32 AM   #3
UhhItsANT
77
Can I just buy that piece from you? Haha.
      03-20-2013, 01:31 PM   #4
Jadar
Dejan
Jadar's Avatar
Serbia
1753
I mean yeah I can make you one. I can't guarantee it won't break if you over tighten it, it becomes very fragile where the 3.1mm of the clamp remain. It's still better then wire as my wire snapped once. Well see how this holds up.
FBO-PS1 and stuff
      03-20-2013, 02:31 PM   #5
UhhItsANT
77
can you make me one? how much do you want for it? i don't have a dremmel
      03-20-2013, 07:31 PM   #6
Jadar
Dejan
Jadar's Avatar
Serbia
1753
I dont want any money for my labor its super simple. Ill buy a clamp cut it up for ya, and if youre serious, PM me. Just pay for clamp cost and shipping . Prob run you under $5 bucks.
In all honesty, if you wanted to try and cut the clamp with some shears it may work for you as well. You dont necessarily need a dremel. Just putting that out there.
FBO-PS1 and stuff
      03-20-2013, 08:25 PM   #7
1clean335i
Perf BMW mag issue 147, 159
1clean335i's Avatar
Vietnam
414
Drives: Project Estoril
I simply removed the spring clamp and tack welded the flap in the open position. No worries of anything ever coming loose
'13 Estoril Blue 335i M-sport
*Don't PM me!* Message me here- http://www.facebook.com/ProjectEstoril
      03-20-2013, 09:13 PM   #8
Jadar
Dejan
Jadar's Avatar
Serbia
1753
That's even better! Clean no wire/clamp. Only thing is reversing it, it be a little tougher to get the weld back off, but with the right tool anything is possible
FBO-PS1 and stuff
      10-21-2017, 12:12 PM   #9
MZHammer
MZHammer's Avatar
45
Drives: E85 Z4M, F82 M4
2016 M4  [0.00]
2006 BMW Z4M Roadster  [0.00]
Tent Peg Alternative
Sorry to revive and ancient thread, but I found this and intended to replicate it. I don't have a Dremmel, so I had difficulty cutting the clamp properly. Then I found a small tent peg (actually may be from a holiday lawn inflatable) in my garage......no cutting required.
Name:  Golf Tee Peg.png
      10-21-2017, 12:15 PM   #10
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Attachment 1709043
I dont use it anymore but it worked like a charm when I did. I got tired of the chicken wire dusting out and breaking.
If I can find my clamp and if you want it, it's yours just pay the shipping to yourself. I don't need it.
EDIT: Nevermind just saw your photos and what yuu did looks solid stick with that
FBO-PS1 and stuff
      10-21-2017, 12:18 PM   #11
Dinan_Rated
DINAN SELLER
Dinan_Rated's Avatar
170
Drives: BMW X3MC X3M40i, DINAN M5 V10
if you unplug the connector when its open, it will remain open no clamp needed. why the mod
      10-21-2017, 12:23 PM   #12
MZHammer
MZHammer's Avatar
45
2016 M4  [0.00]
Apparently it throws a code when unplugged and in my case the original spring broke and fell off, so it seemed like the mod was the easiest solution for the "kill two birds" solution. Valve rattled like hell without the spring.
      10-21-2017, 12:27 PM   #13
MZHammer
MZHammer's Avatar
45
2016 M4  [0.00]
Thanks. Agreed on the chicken wire being a temporary solution. The wire I originally used lasted about 5 months. I am sure others used better wire, resulting in better results.
      10-21-2017, 01:21 PM   #14
Dinan_Rated
DINAN SELLER
170
interesting, haven't seen a code from this connector being unplugged.
      10-21-2017, 07:30 PM   #15
MZHammer
MZHammer's Avatar
45
2016 M4  [0.00]
who knows.....just something I read around here, so it must be true.
