F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > Front left suspension noise problem-active steering
Studio RSR
      12-17-2012, 12:01 AM   #45
RPM90
890
Drives: 340i M-sport AT
Originally Posted by claykin View Post
FWIW, I have not noticed any vibration/wobble in my November build.
Did you get to test drive some 3's with the "old" rack?
If so, do you detect and steering "feel" differences such as firmer steering effort, better road feel for what the tires are doing, etc..?
I believe you also posted that there will yet another new rack coming early next year, yes?
      12-17-2012, 12:07 AM   #46
RPM90
890
Originally Posted by OCcaraholic View Post
I picked up a new 2012 328i on November 17th, and it has VSS. I have the dreaded thunk especially over rough roads. Sounds like something is hitting something under the dash, but it's just noise from the steering gear (my thinking it is) coming through the steering shaft.
I also had someone move the steering wheel while I looked under the hood. The noise is definitely coming from the steering rack and steering shaft. If I'm stopped and shake the steering wheel left to right quickly, I get the same thunky clunky noise inside the car. I hope there is a fix soon and will follow these posts until there is. I don't really want to take my car in until I know where to tell the dealer to look.
I have that same sound when moving the wheel while stationary, but I don't get any thunk while driving.
Maybe things haven't loosened up as much as yours, because when I first got my 3 it didn't have this thunk while turning the wheel with parking lot big movements. Mine started about 2 months ago.
The thing I did have from day one was the discovery that AT F30's don't have a locking steering wheel. One day when my steering wheel was moved left to right quickly, as my nephew was playing with the wheel, I heard soft thunks.
Car was parked not running.
I then repeated the motion and it's there all the time.
Posted on other threads and some people have this noise and others don't.
To me that indicates that it's not normal, but my dealer says there is no problem, of course they would.
      12-17-2012, 12:08 AM   #47
RPM90
890
Originally Posted by shahramghs View Post
That is normal for all shocks.
Yeah, I have this on my left front, with M adaptive.
      12-17-2012, 07:31 AM   #48
claykin
1588
Drives: various BMW
I did drive a few others F30s with older racks (Sport and other lines). All exhibited some level of steering wobble. Some were very noticeable, others were not really detectable unless you let go of the wheel. None had the DHP package. Back in October I couldn't find a dealer car to drive with DHP.
Steering definitely tightens up a bit when in Sport+ (I think Sport mode as well). Haven't driven enough to report back on handling. Will do so in coming days.
www.realoem.com indicates the current November+ rack will be EOL after June 2013 production. Of course this could change. I suppose if it works, why change it? Unless BMW has something else up their sleeve (which I'm sure they do).
      12-26-2012, 05:47 AM   #49
Johnja
Johnja's Avatar
Norway
Drives: Bmw f30 335i
2012 BMW 335I  [0.00]
I have the same noise front løft in my 335i with adaptive drive and h&r.
The dealer think it is the stabelizer, so theywil try this in january
      01-02-2013, 07:01 PM   #50
onehungevo
64
Drives:
Originally Posted by Johnja
I have the same noise front lft in my 335i with adaptive drive and h&r.
I can't believe they are willing to fix with aftermarket springs.
      01-02-2013, 07:05 PM   #51
onehungevo
64
Drives:
Does tightening the bolts under the hood to the spring help? Mine sounds like there is a washer or something missing where the spring and body of the car meet.
      01-07-2013, 03:15 PM   #52
SamGh
The Mechanic
31
Drives: 2016 F30, 340 MSport
I took my car in, as expected, they say its normal. Drove the loaner around, and it has the same issue. We all need to stop being picky
Drive Fast Not Furious
      01-07-2013, 03:15 PM   #53
SamGh
The Mechanic
31
yeah, this is a really cool dealer!
      01-22-2013, 10:20 PM   #54
rosscartlidge
Drives: F30 328i manual
I took it to the dealer and they are investigating. When its resolved either way I will post here.
      01-23-2013, 08:58 PM   #55
rosscartlidge
They did find a fault in my car and a kit is being sent from Germany to fix. They told me my car is the only one they have seen at that dealer. My build data is 1st March, 2012.
The parts are:-
buyin sleeve
buyin string column
rmfd.steer.b
and some nuts and bolts...
      01-23-2013, 11:14 PM   #56
elrey21
32
Drives: 2011 X5 xDrive35i
The parts are:-
buyin sleeve
buyin string column
rmfd.steer.b
I think a brand new car shouldnt have any of these problems and its crazy how its been discussed so much on here but my dealer says im the only one complaining about it (Park Ave BMW, NJ) ... with that said dropped it off yesterday for the third time after a short drive with the Service Advisor where he heard the noise himself. I cant deal with that noise and "loose" feel over unsteady roads and bumpy turns.
      02-02-2013, 09:08 AM   #57
OuKEnFoLdMX
OuKEnFoLdMX's Avatar
Mexico
26
Drives: BMW F15
The parts are:-
buyin sleeve
buyin string column
rmfd.steer.b
please con u post the parts you are replacing so i can tell them to change them to my car thats has the same problems , thanks
      02-04-2013, 09:26 AM   #58
Boosted John
Internet Ninja
Boosted John's Avatar
53
Drives: 13 AH3
occasionally I get a thunk out of my right front suspension as i go over the gutter while pulling out of my driveway. It doesn't happen all of the time or very frequently but , i just notice that it does sometimes.
2013 BMW ActiveHybrid 3 /// Msport Pkg. M performance fornt lip, Black Kidney Grills, H&R Sport Springs, BBS CH-R
      02-04-2013, 01:07 PM   #59
SamGh
The Mechanic
31
I get that on the left side. I guess it all depends on the angle you come out. I noticed its usually after the car has been sitting for a while. Perhaps this happens due to the oil in the shock is settled down. after a couple of travels it goes away
      02-28-2013, 02:38 PM   #60
Johnja
Johnja's Avatar
Norway
They are Willing to fix this, the sound was there before the aftermarket springs.
They have tested it many houres, but still havent found the right part
      07-11-2013, 11:23 AM   #61
tonyzale
Drives: 2016' M3, S1000R, R nineT
Same problem
Originally Posted by ex º View Post
Agreed with others that this is probably not the same "clunk" that's on this thread. I changed my shocks to aftermarket and the clunk was still there. My OEM shocks were still in tact... no fluid leak. Now I'm back to my OEM shocks. Clunk still there. So I don't believe it's a shock/strut issue although that's what I initially thought as well.
I have the same issue. Dealer though it was the steering rack. There was a new part number and they put 2 of those in and the created a whole new problem. Put the old part number in (4th rack including original). Gave it back to me and the original problem is not fixed.
Frustrating. Fortunately I am in a 24 month lease and I can order a new one in 6 months and get out of the lease 4 month early.
      07-11-2013, 11:27 AM   #62
tonyzale
same issue here
      07-18-2013, 07:45 AM   #63
Boosted John
Internet Ninja
53
Drives: 13 AH3
Originally Posted by tonyzale View Post
same issue here
Actually, now that my car has 12k miles on it, the noise is gone. I can't rmember the last time I heard it.
      07-18-2013, 04:06 PM   #64
SamGh
The Mechanic
31
I think I heard some similar noise on my friends X6. I guess BMW engineers are noise-agnostics
      11-13-2013, 12:08 PM   #65
OuKEnFoLdMX
Mexico
26
Drives: BMW F15
if there's solution yet with the steering noise cluck issue?
      11-26-2013, 09:04 PM   #66
Racer20
1030
Drives: F80 M3, 228i THP, E46 ZHP
This is very likely.
These types of noises are unfortunately very common and very hard to diagnose and fix. They come and go depending on temperature, road conditions, age/mileage, and useage. Another scenario is on very bumpy roads at high temperatures, the oil can foam, which mean you'll momentarily have no damping. No damping = clunk noise. This can happen within a single stroke if the bump is big enough.
Adaptive dampers have complex oil flow circuits, and finding/eliminating all of these types of hydraulic issues under all conditions is very difficult.
f30post
