The Tire Rack
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Serpentine belt changes speed at idle.
      06-29-2015, 09:40 AM   #1
jgoens
jgoens's Avatar
3788
Drives: 2013 335i msport
Just noticed today after cold start a sound like the fan is running fast then slow. I usually just go after starting the car in the morning but today I was idling for a couple minutes in the driveway. I opened the hood and noticed the belt would speed up and slow down. I think I have heard this a few times before after cold start when I was stopped at a nearby signal. Is that normal? The rpm does not change...in fact nothing seems off..it's just a sound.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP
      06-29-2015, 10:33 AM   #2
jwzimm
jwzimm's Avatar
687
Drives: '16 M3
That is physically impossible. The belt is driven off the crank. You may be hearing the A/C compressor cycle on and off which would cause a change in sound.
The fan, btw, is electric and will vary in speed depending on what the DME tells it to run at.
2008 Honda S2000 - Current
2016 F80 M3 - SOLD!!
2011 e92 X-Drive Coupe - SOLD!!
      06-29-2015, 10:43 AM   #3
jgoens
jgoens's Avatar
3788
The ac is off. I was kind,of thinking that the belt can only run faster if rpm change. Just from looking it is hard to tell. Maybe the dme is sending signal to the fan to speed up and slow down...probably not normal.
      06-29-2015, 10:57 AM   #4
jwzimm
jwzimm's Avatar
687
Drives: '16 M3
No, it sounds perfectly normal. It sounds like you are looking for a problem that does not exist. As I said, the belt is driven off the engine and only changes RPM based on engine speed. The fan will do its thing to control engine coolant temp.
Stop worrying.
      06-29-2015, 11:04 AM   #5
jgoens
jgoens's Avatar
3788
Stop worrying.
I'm looking for reassurance that I don't have a problem..you think it is fine so that is good. I just have not seen that in any other car I have owned.
thanks.
      06-29-2015, 11:11 AM   #6
jwzimm
jwzimm's Avatar
687
Drives: '16 M3
thanks.
No prob. Enjoy the car. They are a ton of fun!!
      06-29-2015, 11:42 AM   #7
Spacecpe
44
Drives: E90 335i Msport
If you suspect something, take it to the dealer.. i wouldn't take my chances with the serpentine belt...
      06-29-2015, 01:41 PM   #8
jwzimm
jwzimm's Avatar
687
Drives: '16 M3
Why, so they can charge him $175 diagnostic fee to say everything id fine? If he were still in warranty I would agree with you but I doubt he is.
      06-29-2015, 01:42 PM   #9
jwzimm
jwzimm's Avatar
687
Drives: '16 M3
Why, so they can charge him $175 diagnostic fee to say everything is fine? What does it being the serpentine belt have to do with it? If it snaps he would lose the alternator, A/C compressor and power steering. All of which are not required to safely control the vehicle.
      06-29-2015, 02:11 PM   #10
jgoens
jgoens's Avatar
3788
I do still have a little over a month of warranty and then it is cpo. I don't think it is with the actual belt and like you said it probably is not the car making the belt go faster..which I probably misdiagnosed...it is the fan going faster then slower and it only happens intermittently upon cold start. Might be hard going to the dealer since I cannot replicate it easily and by the time I drove there everything would look fine. My car has 26k miles on it..not even close to a belt change.
      06-29-2015, 03:22 PM   #11
Antetokounmpo
Antetokounmpo's Avatar
1552
Drives: E90 6MT FBO; '18 F150 Platinum
If you're auxiliary fan is running faster than normal it's a good sign the waterpump is on it's way out.
2008 335xi 6MT | VRSF Catless DP | VRSF 7" FMIC | VRSF CP | TIAL BOV | DCI | MHD 2+
BC Racing BR | Stoptech 600 | Firehawk Indy 500 255 Square | Atric Altimax 225 Sq.
2018 F-150 Platinum 701A | FX4 | 3.5 EcoBeast
      06-29-2015, 06:43 PM   #12
jgoens
jgoens's Avatar
3788
Even if it happens upon startup and not at operating temp?
