M2 Technical Topics > Suspension | Brakes | Chassis > BMW M3/M4 F8X Carbon Fiber Strut Mod on the BMW M2
      07-08-2019, 07:46 PM   #89
M1500Z
M1500Z's Avatar
423
Drives: a white BMW
Originally Posted by Bee Pee View Post
If adding ohlins and then intending to retrofit m4 alloy brace part in the future - you will need to buy camber plates that can accommodate both OG m2 brace - single bolt fixing - and m4 brace - 3 bolt fixings.
This might limit yr choice of camber plate. IIRC Ground Control M2 CP's are compatible for both OGM2 and M2Comp.
What sounds like the best course of action [for me] is to collect all the parts outside of the carbon brace, and install the aluminum brace concurrently with the suspension and an M3/M4 camber plate. Cheers.
      07-08-2019, 11:00 PM   #90
Anthony1s
756
Drives: 2018 Mineral Grey M2
Yea, I'm considering doing everything except the carbon brace as well. It's too expensive for me for now. Also gonna do the Meister-K rear brace. Mainly to stop my laundry basket from flying forward cause I have my rear seats removed lol.
      07-09-2019, 02:44 PM   #91
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Good plan
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
      07-09-2019, 04:02 PM   #92
M Fifty
844
Drives: M2 & 330CI
Ebay.co.uk has several instances ATM of the major parts for less than £500. In a market the size of the US, I would like to hope that more of same are available.
HTH
      07-09-2019, 07:32 PM   #93
PilotxERAU
214
Drives: 2018 F87 M2
Anthony I am looking at that brace too. Are you doing both?
dtmurf481.50
      07-09-2019, 07:55 PM   #94
Anthony1s
756
Hmm, I never saw the bottom one before. Kinda doubt it'd make a difference if I have the top already. Are there holes already for it?
      07-09-2019, 09:51 PM   #95
PilotxERAU
214
Drives: 2018 F87 M2
I was the opposite I never knew the top one existed or if I needed it. The bottom goes at the stock mounting points in the trunk. Where the net would connect.
      07-10-2019, 01:00 PM   #96
M Fifty
844
Drives: M2 & 330CI
Ebay is your friend if you want the lot for not a lot. I think I paid around 1/3rd for the retail price.
The aluminium needed a bit of a scrub, but the carbon was perfect.
      07-10-2019, 03:47 PM   #97
Anthony1s
756
Are you talking about ebay for the Meister-K rear bars?
      07-10-2019, 05:18 PM   #98
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Lower brace being bolted to the net tie down rings - not sure those bolt holes are structural to improve lateral stiffness !!
      07-10-2019, 07:25 PM   #99
Anthony1s
756
Where do you buy the lower bar? All I see is the top bar on Rakuten.
      07-10-2019, 08:17 PM   #100
PilotxERAU
214
Drives: 2018 F87 M2
I was pointed to this link. I plan on emailing them and verifying both top and bottom bars.
https://global.rakuten.com/en/store/...item/10002592/
Anthony1s755.50
      07-10-2019, 08:30 PM   #101
Anthony1s
756
Tano has the top bar. He has a build thread where I found it. https://f87.bimmerpost.com/forums/sh...1428520&page=7
      07-11-2019, 05:46 AM   #102
PilotxERAU
214
Drives: 2018 F87 M2
Nice. They also have the front axle brace.
https://global.rakuten.com/en/store/unionproduce-ra/item/cpm-cfmb-b101-sh01/
      07-11-2019, 12:39 PM   #103
M Fifty
844
Drives: M2 & 330CI
No - the full front set up.
Those rear items would look more tempting if they were a single x-brace.
      07-11-2019, 09:51 PM   #104
PilotxERAU
214
Drives: 2018 F87 M2
Bee Pee1779.00
      07-18-2019, 12:31 AM   #105
M1500Z
M1500Z's Avatar
423
Drives: a white BMW
I'm trying to piece together a complete parts list for this. Having a little trouble confirming 100% what is needed to swap this over to an OEM state. Would someone mind taking a look at this list? My guess is I'm duplicating some hardware that's already on the car. Also, Tischer is stating 31106859809 is no longer available.
dtmurf481.50
      07-18-2019, 03:07 AM   #106
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
If using oem top mounts you need to add part # 31307853702 x 2
If using re-inforcement plates then longer 10 off M8 bolts required, part no 31307855400
If not using re-inforcement plates then you either re-use 10 off M8 bolts or buy new, part # 31306869931
Most bolts/nuts fasteners are single use so you may want to ensure you have extra section for part no for them ie M14 strut top nut part no 34339806226
dtmurf481.50
      07-27-2019, 06:49 AM   #107
3t3p
New Zealand
455
Drives: M2
Please can anyone help, what bolts do I have here and what more in terms of bolts/fixings do I need for the retrofit?
Also what has snapped off from the alu brace, the black bit? It seems to be metal
      07-27-2019, 08:03 AM   #108
M Fifty
844
Drives: M2 & 330CI
Okay, you'll probably need to consider replacing most of the bolts with new, as many of them are very definitely single use. The two big bolts at the bottom of the first picture for example - they fit in the two holes in the centre of the aluminium brace up against the windscreen.
The black bit on the aluminium is the remains of the cover that goes over the top - just pull the centre pin out of the plastic fitting and the whole lot will lift away.
Realoem will help identify the rest:
https://www.realoem.com/bmw/enUS/sho...diagId=51_9769
https://www.realoem.com/bmw/enUS/sho...diagId=31_1124
      07-28-2019, 11:12 AM   #109
3t3p
New Zealand
455
Drives: M2
Thanks M Fifty.
From reading around I thought single use bolts were used in critical parts that are highly loaded like a cylinder head. Not a brace which will largely be sheer forces and some tension well within limits of the bolts themselves.
Good to know the snapped part isn't critical too!
      07-28-2019, 11:37 AM   #110
M Fifty
844
Drives: M2 & 330CI
For whatever reason, BMW claim they're all single use - even the ones that are only 28Nm and used to bolt the carbon brace in place. So maybe there is something about the sheer forces.
Some of the other bolts use quite a high initial torque followed by a further 45 or 90 degrees (on the M46 the brace between the front subframe and the body shell specifies two further tightening steps after the initial torque, applied in a specific sequence, which is reminiscent of a cylinder head).
I would be happy to retighten any of those that specify an extra tightening step to the initial torque, but no further.
Separately, if you have a look at the two links to realoem above, you'll realise you haven't been sent the full set, so you may as well just order new. Plus, I don't recognise some of those fixings as having anything to do with the brace or strut tops.
HTH
Tags
bmw m3, bmw m4, carbon fiber strut conversion
m2
