10-15-2015, 08:40 PM | #67 |
9167
Rep 14,521
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
10-22-2015, 12:05 PM | #68 |
15
Rep 28
Please correct me if I'm wrong. I have never purchased custom wheels before, so I've been racking my brain trying to figure out the best offsets. I do not plan to lower my car and do not want the wheels to "poke".
Looking at this thread, it seems like most people running 19" VMRs are using the following: (F) 19x8.5 ET35 | 225/35/19 (R) 19x9.5 ET45 | 255/30/19 The staggered OEM wheels are the following: (F) 18x7.5 ET45 | 225/40/18 (R) 18x8.0 ET52 | 245/35/18 For the OEM wheels to reach the offset of the above VMR setup, wouldn't it be the same as adding a 22mm or 23mm spacer in the front and a 26mm spacer in the rear? That seems like quite a lot when many on this board are using spacers betwen 10mm - 15mm. |
10-22-2015, 12:16 PM | #69 | |
///MBajan
31
Rep 203
Bottom line, if you want a flush OEM look I recommend 15mm all round
2015 M235i Sapphire BLK/ Black; MPE/MP trim/MPE/MP splitter/MP diffuser/ LSD/6SP/TP/PP
2014 M5/CP Sapphire BLK |
10-22-2015, 12:28 PM | #70 | |
15
Rep 28
10-22-2015, 12:47 PM | #71 |
///MBajan
31
Rep 203
Yes Sir. My set up is identical to the first car posted by VMR on page 1. EXCEPT I'm on Dinan springs not H & R.
10-22-2015, 03:12 PM | #72 | |
2051
Rep 25,989
Depending on which wheel you are interested in, they may be available in more conservative offsets. For example, the VB3 is available in an ET40 for the front, however the rears would still be ET45. Let me know if you have any other questions!
VMR|Wheels | 714.442.7916 |
10-23-2015, 01:53 AM | #73 | |
15
Rep 28
10-23-2015, 01:21 PM | #74 |
2051
Rep 25,989
18mm in the front and 26mm in the rear.
12-22-2015, 07:23 AM | #75 |
266
Rep 1,091
The rear wheels camber looks definitely not stock though....
previous: 2003 E46 330i SMG
just sold: 2013 F10 528i xDrive my AWD beater: 2015 Golf R mk7 DSG my RWD pirate & long-distance cruiser: 2015 M235i AT8, LSD |
12-22-2015, 09:10 AM | #76 |
266
Rep 1,091
A very important question for Brandon:
With an extreme setup (you know what I mean by that*), does the answer to the all-important question: "will it or will it not rub" depend also on a VMR model chosen? Or - if I'd like to follow one of the examples in this thread - I can safely do it with a different wheel model, as well? (In fact, any wheel model of the given specs)? Thanks, Piotr * my definition of "extreme" is: - tires: definitely wider than OEM (meaning 235/35R19 front, 255/30R19 rear), as IMHO, all the 18->19" wheel conversion w/o wider tires is a futile exercise only serving aesthetic purposes - the M235i needs wider tires!!!) - wheels: ET low enough to show at least some concavity, but high enough to avoid poking out (even if poking would not mean rubbing) - all the above with 10-15 mm drop (like on the H&R springs)
12-22-2015, 11:37 AM | #77 | |
2051
Rep 25,989
12-22-2015, 01:54 PM | #78 |
266
Rep 1,091
Thanks Brandon.
One more question: do VMR have plans for the "Brushed" type of finish a la BC Forged wheels? I'm sure it would be welcome by buyers - with those ultra-low profile tires the wide rims are very susceptible to surface damage. I'm not talking about serious damage that involves bends, cracks etc., but stone chipping or even slight curb rushes. A "Brushed" finish can be repaired by simply sanding it slightly and perhaps spraying with clear coat - no need of entire wheel painting for most small "usage traces"...
just sold: 2013 F10 528i xDrive my AWD beater: 2015 Golf R mk7 DSG my RWD pirate & long-distance cruiser: 2015 M235i AT8, LSD Last edited by moldcad; 12-22-2015 at 03:30 PM.. |
12-23-2015, 04:00 AM | #79 | |
266
Rep 1,091
May I ask you a question on 18" setup? Yeah, I'd prefer 19" but didn't exclude re-using my OEM PSSs, and when they are worn replacing them with 235/35R18 front, 255/30R18 rear - therefore please tell me the specs of say the V810 that I could stretch my current OEM tires on, but would give no rubbing in the future when I replace the tires with 235 f, 255 r. Is the situation with 18" exactly the same as with the 19" - i.e. to make plug&play with wider tires, I'd need ET=45 front, 50 rear? Or is 18" fitment more forgiving, and I could go with ET=35 front, 45 rear and still be able to use 235 mm tire on front, 255mm on rear without rubbing? TIA Piotr
12-23-2015, 04:32 AM | #80 | |
266
Rep 1,091
12-23-2015, 12:34 PM | #81 | |
2051
Rep 25,989
12-23-2015, 01:36 PM | #82 | |
266
Rep 1,091
Piotr
12-23-2015, 02:53 PM | #83 | |
2051
Rep 25,989
12-24-2015, 08:02 AM | #84 | |
266
Rep 1,091
Would an 8.5x18 ET40 wheels - without any spacers - be fine with both: - my current 225/40R18, and after they are finished - some new 235/40R18 tires? Please treat answering my question as a Christmas gift for me . Speaking of which - to all VMR crew, both in the US and here in EU, my sincere Christmas and New Year's Wishes of Health and Prosperity! Piotr
12-24-2015, 11:48 AM | #85 | |
2051
Rep 25,989
Happy Holidays! |
12-24-2015, 12:04 PM | #86 |
384
Rep 548
I just installed 19x8.5 et35 VMR v721 with a 235/30/19 and I'm getting rubbing whenever I go up a driveway or bump. They sit perfectly flush.
I am lowered on H&R springs though. |
12-25-2015, 08:04 AM | #88 | |
266
Rep 1,091
Are you sure the information you gave me in the last couple of posts is accurate? Please don't take any offense - I realize it's Holiday, and all those fitment numbers may get one confused - but: 1. You say you don't have 8.5x18 wheels available with ET=40. Then how about the V703 (I'm basing on VMR EU pages, so here it is: http://www.vmrwheels.eu/wheels_bmw_a...3_vb3.html)??? So my question repeated- if I go with V703 and the following fitment: F: 8.5x18" ET40, 225/40R18 tire I have now and 235/40R18 in the future R: 9x5x18 ET45, 245/35 R18 tire I have now and 255/35R18 in the future - will this work well for me, now and in the future with 10mm wider tires? 2. Another of your posts I don't quite get is #81, recommending (if I am getting you right) that I'd be best off going with your earlier generally recommended fitment: F) 8.5 ET45 + 3 or 5mm spacer > 235/40/18 * Spacer required for appropriate suspensions clearance or (F) 8.5 ET35 (No spacer) > 225/40/18 * 235 tire with this spec may require modification depending on ride height, alignment/camber, and tire brand/model (R) 9.5 ET45 or ET50 > 245/35/18 or 255/35/15 Again, the front is not a solution for me if I would like to get an 8.5x18 wheel, and use it for some 25k km with my current OEM PSS in 225/40R18 size but once worn out, replace the tire with a 235/40R18. It's obvious I'd like to put the 225/40R18 on the 8.5x18 ET 35 (no spacers required), and for 235/40R18 I couldn't reuse this wheel without fender roll-up - do you agree? (I'm dropped on H&R). So- all in all - I still think the fitment as in my Point 1, above, looks like the optimum way to go. For the first period with 225/40R18 tires I have, I could even use 5mm spacers at the front...Please confirm whether you indeed make a mistake, or it's me who is still in error...
just sold: 2013 F10 528i xDrive my AWD beater: 2015 Golf R mk7 DSG my RWD pirate & long-distance cruiser: 2015 M235i AT8, LSD Last edited by moldcad; 12-25-2015 at 09:12 AM.. |
Tags |
9.5, fitment, v703, vmr, wheels |
