Turbo Failure
06-15-2009, 09:26 AM | #1 |
128
Rep 641
Turbo Failure
I've been reading a fair few posts lately on the internet regarding turbo failure on BMW turbo diesels, mainly the early E46 320D models. I'm sure most of us are aware that it is important to let the engine idle for a while to let the turbo spool down before killing the oil supply to it.
As you all know, most of the new cars now have ED fitted. I was wondering, and I'm sure someone on here will know the answer. How does the ED system guard against shutting down the engine whilst the turbo is still whistling away? I'm sure BMW must have taken care of this, if not the ED cars must eat turbos. Just a thought Last edited by CraigUK; 06-15-2009 at 10:25 AM.. |
06-15-2009, 09:30 AM | #2 |
244
Rep 2,811
Drives: Jaguar XE P250 HSE
The engine won't switch off until the revs return to tickover.
06-15-2009, 09:40 AM | #3 |
128
Rep 641
Alan, I thought that would be the case but even when engine revs have just reached tickover the turbo can still be spinning at a several thousand RPM. Hence the reason some cars are fitted with turbo timers.
06-15-2009, 11:39 AM | #4 | |
The Tarmac Terrorist
949
Rep 29,345
Drives: 997.2 GT3
bit im sure in this day and age all BMW turbos will have some sort of oil supply even after shutdown.
997.2 GT3
06-15-2009, 12:51 PM | #5 | |
128
Rep 641
I'm not questioning whether or not BMW have considered this, they must have. It's more a case of how have they done this. |
06-15-2009, 01:22 PM | #6 |
19
Rep 732
What's ED?
Anyway GraigUK is right, you need an electric pump. There is an alternative, the pressure accumulator. Basically a closed reservoir that slowly gets filled with pressurized oil from say the turbo oil feed line, and whenever the oil pressure drops below reservoir pressure it feeds the engine. Thus on shutdown too. Never understood why that hasn't caught on, as it also acts a bit like a the dry sump idea. And BMW has already a clutch delay valve they could use to fill it slowly and drain quickly... |
06-15-2009, 01:30 PM | #7 |
128
Rep 641
ED = Efficient Dynamics
In essence it's a way of making the cars greener and more economical. Amongst other things it will turn your engine off when you stop at a junction or at traffic lights and then restart when you dip the clutch to go back into gear. I don't have an ED car but I'm sure someone that has can give a better description of what it does. |
06-15-2009, 01:49 PM | #8 | |
148
Rep 5,080
Drives: 530d
I believe that one of the features of ED is that pretty much every pump is electric so that they can be used on demand and don't carry the overhead of a mechanical pump working to overcome a "worst case" scenario at all times.
Therefore they could continue to run if required. Quote:
Gone: Fiesta - Focus - E46 320dSE - E91 330dMSport - E82 135iMSport - R55 JCW Clubman - M135i Now: 530d |
06-15-2009, 03:39 PM | #9 |
Rep 448
I asked the same question off topic in another thread It comes down to two things which were mentioned diesels generally run cooler so less likely to fry the turbo and the ED will only kick in if the engine is up to temperature so I would expect the same would happen if the coolant/oil temps were high preventing the turbo from frying.
Could be wrong tho! Slightly o/t (I like doing this!) have you noticed whether or not stop start saves much fuel, I don't have a commute in traffic but when it does auto stop its for a minute or two at lights, it becomes a pain at roundabouts where the traffic is moving but slowly, I end up with the clutch in to stop the engine stopping!
Now - E90 320d M Sport, Le Mans Blue, sun protection glass, Auto lights and wipers, 193M, a big grin Previous - Seat Leon FR, Golf Gttdi (x2), Mk3 Fiesta SI, E30 318i Peugeot 205 Roland Garros, Mk2 Fiesta Ghia (it had a rev counter!!!!) |
06-15-2009, 04:58 PM | #10 | |
75
Rep 2,937
06-16-2009, 03:00 AM | #11 |
1545
Rep 8,972
From a loaner 116d ED I had in the winter, i noticed the Start / stop doesn't operate if the outside temp is 3degC or below.
So that rules out half of Europe for 4 months a year... |
06-16-2009, 02:00 PM | #12 |
19
Rep 732
Now i understand "ED" - my car has it but is not "E" or "D", i'm in discussion with the importer after 3 dealer visits (to me it is simply a bad battery)
ED is: 1) stop/start. very doubtful what we paid for it will ever result in fuel savings, it is there for BMW to hit CO emissions on the test cycle. And yes there are factors as per the manual which could prevent it from operating. 2) electric power steering - again expensive but does result in less power losses thru a permantly driven hydraulic pump 3) electric water pump on petrols, same thing as 2) above 4) NO electric oil pump. If a water pump fails you have plenty of time to react. If an oil pump fails you could be too late by the time you see the warning light... 5) Micro hybrid technoloy: the IBS (Bosch intelligent battery sensor - the black bit on the negative battery pole - has actually "Bosch IBS" on it). It tries to keep your battery at i believe 70% and use any brake/coast event to charge it to 100%. On acceleration it cuts out the alternator All in all a pretty good approach to improved fuel economy. |
06-16-2009, 03:05 PM | #13 |
128
Rep 641
I agree with you 100%, I'm happy to have an older non ED car as I would have concerns over some of the technology being used. I supose only time will tell whether or not my concerns are founded. Hopefully for ED buyers they won't be.
