M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Charge pipe- Action class lawsuit against BMW
      03-28-2019, 12:33 PM   #1
JeffM2PRDallas
JeffM2PRDallas's Avatar
Puerto Rico
48
Drives: BMW M2 F87
Hello Fellows BMW owners.
Do you know if there is any action class lawsuit against BMW related to the charge pipe issue?
It has been proven that it will withstand stock boost pressures initially. But after age and repetitive heat cycles, the plastic becomes brittle and is prone to failure right where it connects to the throttle body.
I had to replace at approximately 17,000 miles, due to failure right where it connects to the throttle body.
Do you know how many people have gone through this! Just praying for an Action class lawsuit against BMW.
      03-28-2019, 01:42 PM   #2
nioh_lbbm2
nioh_lbbm2's Avatar
1717
Drives: M2
And then what? a few years down the road you get a check for 50 cents in the mail and the lawyers pocket the rest?
Just spend 200-300 now and get an aftermarket charge pipe chalk it up as preventative maintenance. They're so cheap it's not even worth the hassle
Appreciate 3
VisualEcho6636.50
M2Pilot278.50
      03-28-2019, 01:56 PM   #3
JeffM2PRDallas
Puerto Rico
48
Drives: BMW M2 F87
Unfortunately, that was not the case with one of my buddies. When the charge pipe exploded the car suctioned a piece of debris and injure one cylinder. For the people that are not in to car’s this is something that they don’t look at all.
My issue is that my car was only 17K miles when it happened. If I change my charge pipe they will void my warranty.
      03-28-2019, 02:04 PM   #4
Aualexa2
Drives: ‘18 M2 Alpine White
Is the repair/replacement not covered under warranty? I understand your friend's situation, but if they replace yours with a new one, it would hopefully last until you are out of warranty and then you can go aftermarket.
      03-28-2019, 04:27 PM   #5
F87source
F87source's Avatar
7254
Drives: Bmw M2
If you're under warranty then you shouldn't have to worry about the charge pipe at all, if it blows and takes your motor with it then they'll replace everything for you.
My opinion is just wait out the factory warranty till like the last month and then swap out to an aftermarket charge pipe.
Like others have said a class action law suit would probably net you zero money since it has happened to so many people.
Click on the link below to see a compiled list of every review I have ever written:
https://f87.bimmerpost.com/forums/sh...2#post30368242
      03-29-2019, 08:16 PM   #6
FalconUSAF
FalconUSAF's Avatar
42
Drives: 2019 M2C, LBB, all options.
I don't understand how an improvement like an after-market charge pipe voids the warranty?!?! Do we know that for sure?
      03-29-2019, 09:04 PM   #7
F87source
F87source's Avatar
7254
Drives: Bmw M2
Well that is a big grey area. In the USA you guys have the magneson moss law that in essence says you cannot lose warranty due to a mod unless proven the mod caused the failure.
So if you get an engine failure maybe the dealer can pin it on your charge pipe leaking boost, interfering with the sensor idk. Like I said this is a big grey area subjected to alot of interpretation and arguing.
      03-29-2019, 09:10 PM   #8
FalconUSAF
FalconUSAF's Avatar
42
Good info -- thx!
      03-30-2019, 04:12 AM   #9
F87source
F87source's Avatar
7254
Drives: Bmw M2
Good info -- thx!
np.
      03-31-2019, 11:33 AM   #10
pz619
3279
Drives: F87 M2C 6MT, Tesla 3
Adamantly against any sort of class action. It won’t actually change anything and as pointed out earlier, that 50 cent check that goes to you and the million dollars that goes to a lawyer isn’t my idea of solving the problem.
      04-01-2019, 11:15 AM   #11
GoneIn4Secs
1287
Drives: BSM F87 LCI (DCT)
Do you own bmw stock? Why would you be adamantly against it, if it forces the company to uograde their charge pipes on future builds thats a good thing no?
      04-01-2019, 11:35 AM   #12
detroitm2
detroitm2's Avatar
2429
Drives: 2018 M2
2018 BMW M2  [0.00]
Given that its likely the majority of the N55 chargepipe failures occurred on either modified cars or track-driven cars, I doubt there is a large enough base to even consider a class action suit. And I'm sure the BMW lawyers will bring up this fact in court. If they can prove the majority of the plaintiffs were using the vehicles in extreme conditions (track), or have modifications, the class action lawyer will have no chance of winning. Theres just no money in it for anyone involved.
So you have a couple options here. Ride it on the stock chargepipe until it fails, and replace it under warranty. Or replace it now for a couple hundred bucks and call it a day.
Poochie9104.50
      04-01-2019, 10:10 PM   #13
pz619
3279
No, I don’t own BMW stock.
Frankly I think it’s ineffective. If anything, warranty claims will be what sways an upgrade. If the warranty claim costs outweigh a part upgrade, then they’ll likely upgrade a part. If it doesn’t, it indicates there isn’t enough support to start a class action anyways. If I had a problem with a charge pipe that keeps blowing off, I would honestly probably go small claims first. Far more likely to win a judgment that isn’t a complete waste of time. Most class action lawsuits really just results in a win for the lawyers. If this was something more safety oriented that results in injuries or perhaps an issue where BMW was committing fraud I would be more accepting of a class action.
Also I’m not very familiar with the B58 motor, but it might have been already addressed.
      04-02-2019, 04:13 PM   #14
infinitekidM2C
infinitekidM2C's Avatar
4207
Drives: 2019 M2 Competition
Class actions can have a big impact on corporate behavior, just depends. Also remember although they are lucrative for attorneys, in federal court (where this would end up), the attorneys are essentially capped at 25% of the settlement (court needs to approve it). The rest goes to the class members. Also if you dont like your share, you can always "opt out" and do a small claims court. Anyways just giving a little real world info on this.
      04-02-2019, 06:09 PM   #15
F87source
F87source's Avatar
7254
Drives: Bmw M2
I don't think a small court claim would go well against a corporate giant like bmw who probably have a crazy team of lawyers.
IDK imo I really don't think a class action law suit for broken charge pipes will go well, it could be pinned on so many other things. Plus look at subaru's EJ257 it has ring land issues with the piston causing alot of motors to go, but subaru is really good at replacing them to keep complaints down just like what bmw is doing with the charge pipe. Yet no one iirc has taken subaru to court because they probably know that they can pin the issue down to oil change, harsh driving etc.
      04-02-2019, 06:17 PM   #16
PackPride85
1120
Drives: M2
It also doesn't work unless the large group of people either suffer injury or financial loss. As long as BMW pays for it under warranty, and it failing doesn't result in injury, there is no basis for a class action suit.
      04-02-2019, 07:12 PM   #17
F87source
F87source's Avatar
7254
Drives: Bmw M2
It shouldn't cause injury since the car doesn't complete die when it breaks it should enter limp mode to enable safe exit off of a road. And unless you drive your car with your head next to the charge pipe the act if it break shouldn't injury anyone directly.
Financial loss out of warranty wouldn't count since stuff breaks out of warranty all the time. If that was the case everyone with an old car can sue because it broke down...
      04-02-2019, 07:21 PM   #18
infinitekidM2C
4207
i was speaking generally, seems like a tough product liability case yeah
      04-03-2019, 10:08 AM   #19
McPurrs
The deuce gets loose
290
Drives: '17 M2 BSM 6MT
This is crazy. Best case they recall the charge pipe if a known issue comes up.
      09-28-2020, 01:54 PM   #20
AlexAuba
Drives: Bmw M3 e92
First of all, dude the pipes must be included in the warranty. Second of all, in case you get to use any kind of boost, any kind of tune ups, the warranty runs out. In stock they run for at least 100k km. Which is not bad at all actually. And even if you decide that it is a problem from the factory, you must turn to a certain ''great'' court, not to the local judge, you know that? However i do not consider this a great reason to get to the court. As an example, i can tell you a case of a friend of mine. He filled a suit of libel California, against a BMW dealership manager. It was at the local court, the guy lost it and had to pay the manager a pretty insame sum of money. You just don't go against these kind of companies.
      09-28-2020, 02:02 PM   #21
M Fifty
844
Drives: M2 & 330CI
Noting how the intake pipes on previous naturally aspirated M3 used to dry rot, 100km is pretty impressive.
I'm guessing Labour is the main cost in swapping them as it looks a bit fiddly.
      09-29-2020, 05:46 PM   #22
CalAcacian
550
Drives: 2018 M2
As an experienced lemon law litigator (including personal recoveries in excess of $150,000 against BMW under Song-Beverly), I cannot stress just how wrong you are.
Do you know why the N54 charge pipe now has a 10 year / 120,000 mile warranty? It's because of the number of lawsuits BMW had to pay out for part failures.
Same goes for the N54 fuel injectors (10 year / 120,000 miles), the N54 HPFP (10 year / 120,000 miles), and the N54 wastegates (8 years / 82,000 miles).
We want this problem solved, it is going to take lawsuits.
McGary911472.00
m2
