10-19-2020, 04:31 PM | #1 |
2099
Rep 1,864
Tire Pressure
My M235i came with Pirelli Cinturato P7 P225/40 R18 all season run flat tires . The door jam sticker states the recommended tire pressure is 39lbs. My prior 4 series and my wife's X3 with the same tires recommends 35 lbs. The ride is a bit rough. I assume the door jam sticker is correct. Is anyone running 39lbs in their tires? Thanks.
10-19-2020, 11:20 PM | #2 |
95
Rep 61
IDrive will show you the recommended pressure if you have the tpms setup based on your tyre and loading. My 218 with its 235/35r19 p zero 4 non-rft’s the recommended pressures are 37psi front 32psi rear
10-20-2020, 05:24 AM | #3 |
2099
Rep 1,864
