06-25-2018, 07:46 AM | #45 |
1920
Rep 3,906
@zaynn786
What year is your car and what exactly are the problems you experience with the navigation? What orientation does it show (normally you can select north-up or track-up) I have also just enabled compass, but have not driven the car yet. If you describe how to reproduce the issue I will try to see if it is the same on mine?
"Large increases in cost with questionable increases in performance can be tolerated only in cars and women."
06-25-2018, 01:00 PM | #46 | |
1920
Rep 3,906
Maybe something else needs to be enabled as well? Has anyone succeeded enabling this? I'd find it very useful!
07-11-2018, 05:31 PM | #47 |
175
Rep 742
I had to recode my dkombi and cleared my FDL codings. I can't seem to find, unless I missed the interpretation, to re-enable the navi on the center of 6wb display.
Any help would be appreciated it! EDIT: Never mind, checked the "DKOMBI => NAVI_NBT_ENABLE = kein_nbt" and was set to something else.
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) Last edited by jkwhar; 07-11-2018 at 07:32 PM.. |
07-12-2018, 01:06 PM | #48 |
Rep 26
This might sound like a daft question, but I currently have the 6WA installed, do I need to remove that from my VO before adding 6 WB or can I keep both in for when I need to swap back when going back to the dealers.
Will it throw any errors leaving 6WA in? |
07-12-2018, 05:22 PM | #49 | |
4495
Rep 10,473
Likewise, if you take to Dealership and they connect to ISTA to update istep etc, it will need 6WA AND OLD PANEL in place. If you have 6WB in the VO, ISTA will not update istep correctly. |
07-14-2018, 11:52 PM | #50 |
175
Rep 742
Also to add, if they update the car (guessing that kombi is one of them but not exactly sure which ECU) it will wipe the needed code and will have to be recoded. source=bimmer-tech.
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
07-19-2018, 10:14 AM | #51 |
Rep 26
Excellent, thank you for that.
Has anyone experienced any issues with navigation having the right hand side of arrows and roundabouts being cut off? Has anyone a definitive list of options you can use on 6wb to get the most out of it? I've got digital speedometer, compass and trying for bhp bar but can't get that working |
07-19-2018, 01:00 PM | #52 |
1920
Rep 3,906
That's as far as I am as well (except that I intentionally did not code digital speedometer - feel it is enough on 2 places to add a third). Basically compass only in my case and wish the engine power bar was possible to activate...
Anything else missing?
07-19-2018, 01:53 PM | #53 |
Rep 26
Which two places do you have the digital speedometer ?
I wish I could make use of that space in the middle all the time as I don't use the navigation that much, seems a bit of a waste of space. Have you come across the issue with the right side of the navigation being cut off? I'll post some pics when I get to a computer, can't do it on the mobile site |
07-19-2018, 02:00 PM | #54 |
Rep 26
Managed to upload them. Notice the arrow missing on the right of the roundabout and the sharp left turn arrow practically missing.
Can't imagine it's a faulty unit, the background and everything shows okay, so not like dead pixels, probably just dodgy coding |
07-19-2018, 11:08 PM | #55 | |
175
Rep 742
Who coded your 6WB?
07-20-2018, 02:12 PM | #56 | |
1920
Rep 3,906
I agree, I wish the middle part could be sued for something, like digital map (similar to Virtual Cockpit on Audi). The Compass is a neat feature, but I wish there was more. I have not noticed any cut offs... That said, I have not driven much with navigation yet and usually barely look at the digital cluster when I do.
07-21-2018, 12:57 PM | #57 | |
175
Rep 742
View post on imgur.com
07-21-2018, 01:07 PM | #59 |
175
Rep 742
There really aren't alot of round about in NJ but when I do go around one, I will post a pic!
08-14-2018, 11:15 AM | #60 |
35
Rep 277
A question. I have a 2014 328i with 6wa, and am thinking about upgrading to 6wb. Do i just have to vo code the 6wb, add cafd for dkombi and vo code dkombi and nbt or will i have to change the production date also?
08-14-2018, 02:46 PM | #63 |
35
Rep 277
08-25-2018, 05:24 PM | #65 |
35
Rep 277
I retrofitet a 6wb in my f34 from 2014 with 6wa and nbt. Everything seems to work except the navi indication in the center.
I removed 6wb and put 6wa back and gor copie from cafd then put 6wb back and compared everything and there are 2 things different. - Kombi_Cic was set to mid with 6wa and when coded 6wb it was set to low. I changed it to High - setting_info_display was set to aktiv in 6wa and to nicht aktiv on 6wb so i set it back to aktiv Now i got the info display back in my nbt So annyone an dea why i don't have the indication on my D_kombi. With my 6wa i had the arrow on the cluster but now i get nothing. So what do you have to code for this? And in D_kombi Navi nbt_enable is set on nbt_aanzeige Annyone know what the problem is? |
08-25-2018, 07:49 PM | #66 | |
10535
Rep 41,166
Drives: 2018 Alpina B6 650ix GC
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE Last edited by shawnsheridan; 08-26-2018 at 09:42 AM.. |
polinesiano1.50 |
