BMW E60 5-Series Forum | 5Post.com
Go Back   BMW E60 5-Series Forum | 5Post.com > BMW 5-Series (E60) Forums (2004 - 2009) > General 5-series and M5 (E60) Forum
      04-18-2024, 11:36 PM   #1
iskoT
iskoT
Drives: BMW 5.30XI
Keyfob Doesn't work Unless Using Physical Key first! Help
Hi Guys.
I have E60 2007 5.30xi. I had Battery Issue. I bought a new battery but It gave me a lot of problem. Car was not cranking. During that time, I tried to CAS syncrnaziton. It didn't happen.
Then I replaced battery again and now Car starting and driving well.
But, keyfob doesn't works. I pull out physical key and open the door,and then Keyfob start working but after a couple minutes Car forget the keyfob again. I have spare key. it's same problem.
and IDRIVE screen does not turn on.
HELP PLEASE!
THANKS.
      05-11-2024, 07:20 AM   #2
TOGA
Drives: BMW E61 2008 525d
First that comes to mind when keyfob don`t work are the universal antenna. But since you have an E60 you`re not cursed with notorious cable braking and moisture in the box. But worth checking it out by swapping. Don`t recall the location.
Tags
idrive, keyfob
5post
