10-31-2020, 09:55 PM | #1 |
23
Rep 32
belly pan question
Hi Everyone,
I have a question for you concerning the height of the OEM felt belly pan. I know this pictures aren't the greatest, but hopefully good enough to get a decent visual. My pan is somewhat beat up, but still usable. I have a Turner pan that I'll install once this thing is completely trashed. Or I scrap/rip it off someday It seems like I'm scraping it more than usual. Maybe it's because I don't drive it as much as I used to Based on these pictures can you tell, if it's hanging lower than it should be? |
10-31-2020, 10:08 PM | #3 |
11593
Rep 12,738
it looks about where it should be. if its connected to the rear fender liners, its where it should be.
Instagram; @roastbeefmike
11-01-2020, 12:32 AM | #8 |
23
Rep 32
Thanks much for the replies. I appreciate your insight.
For you guys that have the Turner pan, do you really like it? Was it fairly easy to install? |
11-01-2020, 01:58 AM | #9 |
1093
Rep 950
Easy install, be very careful with the screws. I believe this pan has save me several times from road debris from tires , metal parts, etc. Mines has quite a few "battle scars".
11-01-2020, 01:11 PM | #10 |
54
Rep 121
Yes it was fairly easy to install. I was able to perform it with just having the front end on ramps and having myself on a creeper. Although I was a bit limited on space, I managed to get it done. If you have the ability to raise your car a bit then it'll be a lot easier. Also, if you watch their install video, it helps out quite a bit. Make sure you don't tighten up the screws too much as you're aligning the pieces. Go back at the end to tighten everything. Don't over tighten the screws, they can strip easily.
I really love this skid plate. There were times on the highway I could not avoid certain debris and provided protection to the car. I replaced the oem one because it was destroyed from hitting something on the freeway. |
05-06-2024, 07:22 PM | #11 |
894
Rep 9,034
Anyone try this belly pan? https://cmpautoengineering.com/colle...nium-belly-pan
Any other pans worthy looking at now? There seem to be a few options available now .
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
05-07-2024, 09:34 PM | #12 |
134
Rep 210
I had the turner belly pan on my previous e92 M3
- it’s too heavy - inspite if using anti seize the hex bolts still rust/get stuck when you need to remove the pan for service needs - yes, it’s pretty solid but too heavy, in my opinion. I am considering Mporium belly pan.. not sure if it’s solid enough but definitely lighter. All aftermarket belly pans improve ground clearance as they are flat or almost flat, unlike OEM felt pan. |
05-07-2024, 09:50 PM | #13 |
2468
Rep 5,933
The drop down “boxes” are there for a purpose and it’s to control the airflow from mixing with the wheel well to minimize lift on the front end. Turner completely replaces them with a flat aluminum panel. Turner definitely could’ve used a thinner gauge and it would’ve provided the same protection.
I’m not familiar with the Mporium under belly but I believe it eliminates the “boxes” completely just like the Turner tray. |
