09-01-2017, 10:55 PM | #1 |
674
Rep 413
For New Owners - What I wish I knew when I first bought my E9X M3:
1. The best info on M3Post is found in the less traveled E90/E92 M3 "Technical Topics" subsections - Engine, Wheels, Suspension, Cosmetic, Coding, DIY, Maintenance, Detail and Track. Notice how this "wish I knew list" is posted in the General Forum section? Caveat emptor. Technical Topics Subsections 2. The E9X M3 has a hidden software setting to tweak the M Dynamic Mode (MDM) feature. Hire one of the many remote coders on this website to adjust the software settings in yours to the "Euro" MDM settings. This really livens up the car by making the traction control way less intrusive without being completely turned off for those extreme mistakes. This is one of the areas where the BMWs of this era really shine vs the Mercs. Euro MDM 3. The E9X M3 S65 motors tick and click, it's normal. S65 Motor Ticking 4. Some brands of oil are less noisy than others when used in the S65 engine. The ridiculously named "BMW M TwinTurbo Power 10W-60" oil and Shell Helix Ultra Racing 10W-60 oil (which may be one in the same, just with different labels) are two of the quietest options. Shell Helix Ultra Racing 10W-60 Sound Test 5. The E9X M3's DCT transmissions shift clunky at low speeds and switch between drive and reverse slowly, it's normal. They make up for laggy slow speed performance higher in the RPM range and at higher speeds. Place the transmission shifting selection mode to 5 "bars" and it will improve dramatically. If you want faster shifting, tuners sell a DCT software tune (usually called the GTS DCT tune), but keep in mind it will come at the expense of reduced 0-60 mph acceleration. DCT Slow Speed Behavior M3 0-60 Times More M3 0-60 Times Discussion 6. The E9X M3's DCT transmission is nearly bullet proof. BMW made amends for the absymal reliability of the SMG transmission before it. Most of them will eventually "weep" a little bit of DCT fluid, but they can do that safely for 10's of thousands of miles before seal replacements are really needed. The main culprit for the slow weeping is a simple O-ring at the top of the DCT transmission where the wiring harness connects to the DCT, but is often misdiagnosed as a leaking DCT side cover gasket or bottom DCT pan gasket as gravity pulls the fluid downwards and over them. Not surprisingly, many people who replace their side cover gaskets and bottom DCT pans find their weeping returns, probably because they were never leaking in the first place. This simple O-ring is very difficult to reach, but does not require special skills, nor expensive parts. DIY: Fix the DCT Fluid Weeping Problem Common DCT "Weeping" 7. The water pump on the S65 is bullet proof for at least 10 years, even with a plastic propeller. BMW got this one right. This is another area where BMW made amends for one of the previous generation model's shortcomings. Have You Experienced a Water Pump Failure in Your E9X M3? 8. The E9X M3's two throttle actuators will eventually fail you and very often the second one will fail shortly after the first. There was a "hidden warranty" of sorts where failing throttle actuators could be replaced free of charge if they failed in the first 7 years or 70k miles for cars registered in California Emissions states which include: California, Connecticut, Maine, Maryland, Massachusetts, New Jersey, New Mexico, Oregon, Pennsylvania, Rhode Island, Vermont or Washington. As nearly all E9X M3's are older than 7 years past their original sale date, you may want to prioritize preventive maintenance for the throttle actuators. The best preventive measure you can take now is to clean the eight throttle bodies so that the throttle actuators encounter the least amount of resistance when opening and closing the throttle body valves. We shouldn't be surprised throttle actuators that have to open and close 8 dirty throttle body (butterfly) valves covered in carbon build-up repeatedly might not last as long as throttle actuators that only have to open clean throttle body valves with a fraction of the resistance. This may be the most commonly overlooked maintenance item for E9X M3's. DIY Throttle Body Cleaning Throttle Actuators Covered by California Emissions Warranty 9. The E9X M3 deflection pulley (aka idler pulley) fails early. It's a low cost replacement part (by BMW standards) and easy to DIY if you want. A squeal from the engine bay of an S65 is almost always this part self destructing. Details Example A Example B 10. Nearly all BWM E9X M3 maintenance parts are purchased by BMW from another company, placed in a BMW branded cardboard box, marked up 25-100% and then sold to you as the official BMW replacement part. Surprisingly, most of those exact parts BMW buys can be bought by you for a lot less. Check out this link for all of the exact factory matched parts ID'd so far. E9X M3 Exact Original Equipment (OE) Equivalent Parts 11. All E9X M3's are, will be or were part of the Takata airbag recall. Many E9X M3s now are part of the main positive battery cable recall for the cable that runs from the trunk mounted battery to the fuse panel behind the glove box. 2013 model year E9X M3s have an extended warranty for the idle control valve for 10 years or 120,000 miles. Some E9X M3's (e90 M3's built 8/31/2009 to 10/28/2011, E92 M3's built 7/27/2009 to 6/28/2013, E93 M3's built 8/29/2009 to 10/1/2013) have a hidden reimbursement warranty, to include past repairs, for the Footwell (FRM) Module (controls lights and windows) if it fails within 10 years or 156,000 miles under BMW SI B01 20 16. Takata Airbag Recall Battery Cable Recall Idle Control Valve Hidden Extended Warranty Footwell (FRM) Module Hidden Extended Warranty 12. The E9X M3's original batteries were Absorbed Glass Mat (AGM) group 49 type battery, 900 Cold Cranking Amps (CCA) and 90 Amp Hours (Ah). You can't buy those exact specs anymore. Instead the BMW batteries for the E9X M3 now offer AGM "group 49", 850 CCA and 92 Ah, which are the same specs as the Sears DieHard Gold AGM and nearly the same for the Bosch 49-850BAGM with 850 CCA and 90 AH. The Autozone Duralast AGM "group 49" and Advance Auto Parts AutoCraft Gold AGM "group 49" models offer 900 CCA and 92 AH. Replacement Battery Options 13. If your E9X M3's A/C is low on freon its most likely the evaporator failing. It is built of especially low quality. Good news is the replacement part is not too expensive. The bad news is your dealer will likely charge you for a full day or two of labor. If you have any warranty remaining, have someone take a close look at the condition of this part before it expires. This A/C Component Will Fail First 14. The E9X M3's came standard from the factory with orange peel paint and some ever so slightly misaligned body panels. Just call it Bavarian character. BMW Orange Peel Paint Gap Between Hood and Front Bumper Rear Bumper Alignment 15. The E9X M3's S65 motors respond really well to early replacement of the spark plugs (the car's manual calls for 37,000 mile service intervals). You can feel a difference, even if the spark plugs coming out of the car only had 10,000 miles on them. This is a great afternoon project if you are eager to improve the performance of your new to you M3. Consider doing this inexpensive upgrade instead of breaking out that black Krylon to tint those rear tailights. Some have also theorized worn spark plugs on S65 motors may be a contributing factor to rod bearing failure. Early Spark Plug Replacement Theory Discussed - Worn S65 Spark Plugs May Increase Rod Bearing Failure Risk 16. E9X M3's wear through motor mounts really fast, as within 30,000 miles they can start to fall apart. Changing them out earlier than you would for another model car makes for a measurable and immediate improvement in the shifting of your car. Don't bother with the transmission mounts unless you are over 100k as they hold up very well. Fast Wearing Motor Mounts 17. Code readers, either a stand alone unit or a cell phone app type with a bluetooth/wifi OBDII port adapter, are great for this car. Buy one asap. Code Readers 18. The engine is extremely impressive. M3 V8 An Inside Look 19. E9X M3's are much more fun to drive than to look at. Experienced E9X M3 owners, feel free to add to the list.
130
WAKman413.50 dozaiya236.00 GVIFlyer294.50 loveskiing970.50 BanjoPaterson160.50 rockstar93321.00 Not Sure223.00 bobllama1.50 ONEOF40 FS M3111.50 Yeru211.50 KawBoy154.50 Banana Hammock3771.00 obe100232.00 inTgr8r2434.50 ToddinTN504.00 Obi Wong Kenobi34.50 roastbeef11593.00 aus893.50 Jonzny92.50 DeltaFX194257.00 BimmerRookie471.00 MachinesWithSouls4849.00 Yoddha251.00 ///MPower15505.50 thetastelingers4172.50 Law6389.00 deseroner77.50 baseking24.00 b4hand661.00 K-M390.50 Megabrode335.00 reece1461.50 bluescoupe58.00 M3CRZY20.00 Transfer5260.00 AKD75.50 Ggeezer252.50 |
09-02-2017, 04:19 AM | #8 |
971
Rep 1,612
Great post Theodore...
Just wondering how you got my crazy driving video? Of course I was taking it easy because it was DCT... |
Theodore673.50 Whyte Dynamyte29.00 |
09-02-2017, 06:25 AM | #10 |
29
Rep 101
Really appreciate creating this post Theodore..
I have seen half of the threads you have listed so need to go check out the ones that I have not yet gone through.
2009 E92 Jarez Black M3
2018 G01 X3 xDrive20d |
Theodore673.50 |
09-02-2017, 06:43 AM | #11 |
4-6-8
234
Rep 990
E9X M3 *Greatest Hits* MegaThread (Press/Media/Reviews) 100+ Videos
http://www.m3post.com/forums/showthread.php?t=1383761 Its a great thread for those just starting ownership. The E9X M3 was the benchmark in this class.
M3 E46 PY/Black
S2000 AP2 GPW/Tan |
09-02-2017, 06:52 AM | #12 |
223
Rep 286
amazing thread. thx OP!!
Theodore673.50 kerancollier0.00 |
09-02-2017, 08:15 AM | #14 | |
956
Rep 940
Drives: 2022 X3M
Great f^ thread! Thank you!
2022 X3M
2017 Cayman (Ret) 2019 X3 M40i (Ret.) 2015 F82 ///M4 (Ret.) 2011 E92 ///M3 (Ret.) |
09-02-2017, 12:02 PM | #17 |
Beefcake
3771
Rep 711
Awesome thread!
There was another thread about strange noises the car makes that are totally normal. You should include those as well! Here it is: http://www.m3post.com/forums/showthread.php?t=512258 |
Theodore673.50 |
09-02-2017, 12:52 PM | #19 |
358
Rep 3,035
Drives: BMW/MERCEDES/PORSCHE
great thread!
BMW E93 M3 / Mercedes Benz W209 CLK500
BMW E64 650I(sold) / BMW E92 328I(sold) / BMW E46 M3(sold) / BMW E92 335I(sold) Porsche 996 911 C2(sold) / BMW E46 325CI(totaled) |
Theodore673.50 |
09-02-2017, 02:44 PM | #20 |
550
Rep 1,148
Drives: 2008 BMW M3 Coupe
Garage List 2015 Jaguar XJ [0.00]
2015 Jaguar XF [0.00] 2014 VW GTI [0.00] 2008 BMW M3 Coupe [0.00] 2007 VW Passat 2.0T [0.00] |
+1. Great post that covers a lot of the need-to-know points!
09-03-2017, 12:52 AM | #21 |
249
Rep 177
Great post, really helpful for someone like myself who is currently looking for the M3 for me.
09-03-2017, 03:27 AM | #22 |
34
Rep 92
How about... When changing the battery, don't shut the boot/trunk as it's a PITA to open again without a battery/hooking up the front charge points. Unless you have an older model that opens with a key but normally the lock is seized since it's never used.
