10-22-2012, 10:55 PM | #23 |
Rep 273
10-23-2012, 06:11 PM | #24 | |
M = Midlife Crisis
65
Rep 2,006
2006 Z4MC - #LL93158
SS Race Cans, RE X Pipe, DKF Sec 1, Fabspeed Headers, OE STB, AS Shifter, Dave Z CDV, GC Coil Overs, Stoptech lines, Hawk DTC Pads, RE Clutch Stop, RE Transmission Mounts, Vibra-Technics Engine Mounts, Poly FCAB & RTAB, LeatherZ M Shift Boot, Tekarbon Rear Spoiler, CF Grills, Advan RS DGM |
10-24-2012, 06:55 PM | #25 |
76
Rep 987
I'm eventually going to add my input for the Lithium Pro L925. I'm still running some tests. The car alarm draws some amperage (not sure how much)... so should we be testing how many days the car will last and still start with the alarm activated or inactivated or both? Bad news is my battery failed the 5 days test with the alarm activated. =( I was hoping to last a week with this battery.
10-25-2012, 04:04 PM | #26 |
76
Rep 987
Really bad news! Just melted my expensive lithium battery. It did NOT like my trickle charger. Probably user error on my part. Oh well, I'll call the company. Glad my car didn't burn down... which might have happened had my brother not smelled it.
Edit...pretty sure my trickle charger was not compatible with my battery. Expensive lesson but that's how it goes. Last edited by Jumbosock; 10-25-2012 at 04:36 PM.. |
10-26-2012, 09:39 AM | #28 | |
2432
Rep 11,667
...details on the charger you used?
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
10-26-2012, 12:17 PM | #29 | |
Dog Listener
704
Rep 7,850
Man, really sorry to hear that. |
10-26-2012, 02:05 PM | #30 |
76
Rep 987
I'm an idiot. Even though there is voltage protection they plainly say not to use a trickle charger on their batteries. I am just glad I didn't burn my car down. I am not sure if I will buy another one. After further reading there are too many limitations with the battery as far as charging and jump starting. Here is info from their site:
Can you jump start a dead lithium ion battery? No. Lithium ion batteries are especially susceptible to cell damage when they are empty. A good lithium ion charger will actually “soft start” and roll the output current back when it detects a lithium ion battery at a very low SOC. This being the case, jump starting would send an uncontrolled amperage into a very low lithium ion battery. Bad idea. Don’t do that. Use a lithium ion battery charger or a 12V AGM charger at its lowest setting (1~2A) and slow charge the Lithium Pros battery back to 20% SOC. After that it can be charged like normal. Do I have to buy a special charger? Not really. 12V Lithium Pros batteries can be charged with any voltage regulated battery charger without a desulfation mode. Trickle chargers should not be used. AGM type battery chargers are highly recommended since the finishing voltage is regulated and typically lower than for a flooded lead acid battery. At no time should the battery charger exceed the max amperage and voltage rating on the battery. Last edited by Jumbosock; 10-26-2012 at 02:12 PM.. |
10-26-2012, 04:47 PM | #32 |
Rep 273
Look forward to seeing the pictures, and thanks for posting the limitations. If I'm ever caught away from home with a dead battery, the ability to jumpstart is a necessity for me. Not very practical in a grocery store parking lot to find a low amperage charger (and available power), then wait for the battery to charge back up so you can carry on ...
10-26-2012, 05:34 PM | #34 |
Dog Listener
704
Rep 7,850
Wow. Scary stuff indeed!
I agree, it's lucky this is all that happened. Could have been much worse. Crossing "lithium battery" off my list! |
10-28-2012, 01:20 PM | #35 |
Rep 273
I'd have a word with the battery manufacturer if I were you. Yes, they have a mild warning on their FAQ that 'Trickle Chargers should not be used'. However, they also state:
Second, every lithium ion battery has (or should have ;D ) a battery management system. This system checks for high voltage, low voltage, over current, short circuit, or over temperature. If these conditions exist the BMS literally disconnects the battery from its load and turns off the output terminals. This mini-computer inside a battery adds cost especially if it is sized to handle your starter! For this reason larger lithium ion battery packs are usually less expensive per watt-hour than smaller ones. I'd say the 'battery management system' in your battery failed rather spectacularly - looking at your pictures, I'd say it's a safe bet that at some point yours was 'over temperature'? |
11-24-2012, 08:45 AM | #36 |
2432
Rep 11,667
Updatess? I know there are more of you out there
11-24-2012, 03:17 PM | #37 |
366
Rep 1,373
I am running the Odyssey PC680 along with a custom mount i fabbed up from some aluminum. The battery weighs about 15lbs and the mount can't be more then a pound. I don't keep it on a trickle charger but it will hold a charge for at least two weeks in a none heated garage.
07 Z4 M Coupe AW/IR |
11-24-2012, 08:11 PM | #38 |
2432
Rep 11,667
Nice
Ill likely do something similar. I don't really need trunk space so I'll leave it in the OE location.
11-24-2012, 08:26 PM | #39 |
366
Rep 1,373
Yeah I didn't need the trunk place either so I just stuck with the stock mounting location. The mount I made is rock solid for the little bit of aluminum I used. I can grab the battery with my hand and rock the car.
11-25-2012, 09:04 PM | #40 | |
2432
Rep 11,667
11-25-2012, 10:21 PM | #41 |
55
Rep 1,224
F360C, can you be specific on what submodel Odyssey PC680 you used? There appears to be several variations. Thanks
If you can't take the time to teach a kid something good, someone will take the time to teach them something bad.
11-26-2012, 03:40 AM | #42 |
Stupid as shit
26
Rep 367
Great list, good job guys!
I had to replace my battery back in August, because the original OEM battery started to "grow" and acid was pouring out of it, I'll add the battery I replaced it with next weekend when I'm in my winter-sleep-garage. |
11-26-2012, 12:33 PM | #43 |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
I went with Autozone's Duralast H6 AGM for $159.99 for my 3.0si
http://www.autozone.com/autozone/par...er=319460_0_0_ Last edited by 3002 tii; 11-26-2012 at 12:40 PM.. |
Tags |
battery |
