ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Navigation, Audio, Bluetooth, Stereo, Electronics Talk
  TireRack
      11-02-2020, 10:50 AM   #1
cbecker33
56
Drives: Z4 M Coupe
Returning to a factory head unit
When I purchased my car it had an aftermarket head unit installed as well as an amplifier and (I assume) aftermarket speakers.
I have never been satisfied with the appearance of the head unit nor the features (they are already outdated). I have not found an aftermarket solution that both looks and functions as I would like. I think my best bet is to return to the stock radio, add Bluetooth capability and compatibility with my aftermarket amp. I would then use Android Auto on my phone for display and control (I rarely listen to AM/FM radio).
I do not know what factory radio was in my car. I assume (but am not positive) that it had navigation from the factory. Currently the aftermarket radio is connected to the rear-mounted amplifier via two RCA cables. I also have an aftermarket mic and antenna.
My questions are:
1. Which factory BMW radio should I purchase?
2. Is BlueBus my best option for Bluetooth with Android Auto?
3. What is the best way to connect a factory head unit to my aftermaket amp?
Really, any advice/opinion is much appreciated.
      11-02-2020, 02:24 PM   #2
Clearancediver
90
Drives: 2004 Z4
You need to run your VIN through a vin decoder to figure out what radio option was the original install.
That said... given the description you have provided it's likely you had the high ending DSP version...aka as the "Carver" high end system due to the complete replacement you describe.... amp and speakers.
Replacing head with a BMW business radio may not be an option at this point.
You can check to see what business radio was originally installed and the suggested replacement radio via realoem.com if you were to pursue a OEM head replacement.
Sent from my smart phone...
      11-02-2020, 02:43 PM   #3
cbecker33
56
Drives: Z4 M Coupe
I have not found a vin decoder that shows the radio option. Can you recommend one?
      11-02-2020, 11:17 PM   #4
t3ddftw
11
Drives: E46 M3
https://www.mdecoder.com/
If it errors out, try http://bimmer.work
The BlueBus doesn't really do anything with Android Auto, but it would certainly route audio from Android auto through to the car.
-Ted
      11-03-2020, 09:04 AM   #5
cbecker33
56
Drives: Z4 M Coupe
Originally Posted by t3ddftw View Post
This shows:
609 Navigation System Professional Navigations system Professional
677 Hifi System Professional Hifi System Professional
Fair enough, I guess I just wanted to ensure there are no know quirks or issues with the devices and Android Auto
Real OEM seems to show 3 head unit options. So I'm still a bit confused as to what I can throw in there. The nav screen is long gone and I have no desire to try to put it back in. Assuming that I did have a factory amp - it, too, is long gone.
My goal is to buy a stock head unit and connect it to the stock wiring harness in every regard (hopefully) except for the speaker outs. For the speaker outs I will need (I assume) a line-out adapter to the F/R RCAs that lead to the aftermarket amp. Somewhere I need to hook up a bluetooth adapter that plays nice with Android Auto.
Can I slap in any business CD radio?
      11-04-2020, 10:55 AM   #6
Clearancediver
90
Drives: 2004 Z4
I would think that since your car system has been modified.... a complete delete of the high end system, that a business radio would work as long as it was for a 10 speaker system. No guarantee, but the radios are cheap enough if you want to spend the money to find out.
The trick would be to identify what radios fall within this definition. That I can't help you with.
Realoem will show you the original radio installed, plus radios that are compatible from later model cars.
Once you revert to a business radio you lose all the advantages of the existing radio. Bluetooth, hands free etc and it isn't easily replaceable.
      11-10-2020, 10:45 AM   #7
cbecker33
56
Drives: Z4 M Coupe
Anybody have a spare radio laying around?
      11-11-2020, 12:30 PM   #8
KevinC
your average JAMF
KevinC's Avatar
3101
Drives: '21 M2 Comp, '19 Golf R
Check Ebay - these radios turn up all the time, at reasonable prices.
'21 M2 Comp
'19 Golf R
      02-12-2021, 07:12 AM   #9
Vanne
Down Under!!
Vanne's Avatar
United Arab Emirates
1621
Drives: 2007 Z4MC
id say if you dont want to put the nav screen back (and i dont blame you, as its rubbish) you need the radio that came with the non nav equiped cars. I have one lying around for the nav equiped car, but that will be useless to you as its got no screen itself and used the nav screen to navigate the radio options. good luck.
2007 EuroSpec Z4///MC - Building/Developing Z4 GT3
Powered by
      02-12-2021, 11:46 AM   #10
cbecker33
56
Drives: Z4 M Coupe
Thanks! The space where the Nav screen was is no occupied by a gauge pod - no hope of putting it back in.
      02-12-2021, 04:15 PM   #11
Vanne
Down Under!!
Vanne's Avatar
1621
Drives: 2007 Z4MC
Show us some pics pls of the gauge pod I mean
Powered by
      02-16-2021, 12:22 PM   #12
cbecker33
56
Drives: Z4 M Coupe
      02-18-2021, 08:55 AM   #13
kaybat
kaybat's Avatar
126
Drives: '06 Z4MR, '14 Cayman S
'06 Z4M  [0.00]
like the pod. that came with bluetooth, pull the rear panel(trunk) and the head unit out to see what previous owner did.
Ken B.(BMWCCA/PCA/ZSCCA/SCCA)
      02-18-2021, 08:57 AM   #14
cbecker33
56
Drives: Z4 M Coupe
The pod is fine, though the gauges could use an update.
I've had the radio out and the back panel off - it looks like the wiring is intact but I'm not 100% (the hardware is long gone). Car is in storage for the winter but I'll get after it again come spring.
      03-18-2021, 11:53 AM   #15
cbecker33
56
Drives: Z4 M Coupe
I've decided to go with a Joying 8.8" unit. I assume that I will not need to purchase another harness/adapter (other than what comes with the unit) as I already have an aftermarket stereo in there !?
      05-05-2021, 07:04 AM   #16
mothy5000
mothy5000's Avatar
Drives: '08 BMW Z4 3.0si E85
Let us know how the installation goes. I've always been curious about these.
BTW - Your original setup may have had the BMW BT unit. There was no such thing as streaming music back then so it is for calls only. I used mine quite often.
      05-05-2021, 07:54 AM   #17
cbecker33
56
Drives: Z4 M Coupe
Will do. I just got my car back from the shop (getting ready for the season). Hopefully I can start the install soon.
      10-29-2022, 07:41 AM   #18
blufc3s
blufc3s's Avatar
12
Drives: 2003 Z4 3.0i
I will try that as well.
zpost
