03-07-2009, 07:03 AM | #1 |
86
Rep 303
First Aid Kit under Front Seats
Has anyone tried to install the optional first aid kit container under the front seats in a sedan or coupe? This is the first aid kit container that is standard I think in the European E93? I had them under both front seats in my previous M3 and used them as an extra storage space--was very handy (you can get to it from inside the car, and its not visible from the outside, and uses dead *******. Here's the info on the parts from Realoem.
In my previous M3 it was an easy install (tapped the existing holes) and mounted like a charm. |
03-08-2009, 09:09 PM | #2 |
Bored at work....
891
Rep 5,393
Interesting. I might look into this some time in the summer.
Thanks.
Grey Matter:2008 E92 M3:608/425. SG/PS SOLD!
Dark Matter:2015 F80 M3:495/505. SOLD! Anti Matter :2016 F82 M4 GTS What next?!? A 2022 M235i GC- I must be getting old |
03-09-2009, 10:24 PM | #3 |
E90 - the Ultimate family hauler
22
Rep 578
Looks interesting. Can you provide a list of part numbers needed?
2008 AW E90 M3 - current
2002 TIAG E46 M3 - gone 1991 DiamondSchwartz E30 M3 - gone but not forgotten |
03-10-2009, 03:02 AM | #5 |
Rep 90
2) 52 10 6 971 063 (empty)
52 10 7 166 665 (filled) 3) 52 10 8 267 529 4) 07 14 9 169 302 http://www.realoem.com/bmw/showparts...76&hg=52&fg=25 |
03-10-2009, 03:10 AM | #6 |
86
Rep 303
I'm going to try to order the mounting part and empty box from the dealer in Paris...I looked under the seat and there are a number of pre-drilled holes that may match the ones on the mounting points (they are probably the same ones as for the fire extinguisher).
There was a guide for an E46 325i that described how to mount the box (the only semi-tricky thing was that you needed to tap the existing holes to thread them, but its pretty easy if you go slow). I'll try to find it. I'll keep this updated as I go along. |
03-10-2009, 07:31 AM | #7 |
22
Rep 578
Thanks for the part number listing Gelsenpower.
E90M3CDFR, keep us updated on your progress with this as I'd really be interested in adding this box under the passenger seat and a fire extinguisher under the driver seat if possible.
03-10-2009, 09:24 AM | #8 |
145
Rep 409
This is a mod I have on my list too.
The E90 and E92 seats have a larger/different fairing around the front base of the seat. It will either need to come off or be cut in order for the first aid box to fit. I looked at my boss's E93 and I think it's doable, but not a simple bolt-on. There is a slim chance you will need to remove 52106958659 and 52106958660.
Jon Maddux
coupenut.blogspot.com x5nut.blogspot.com 16 X5d | 08 M3 Sedan | 06 M Coupe | 01 M coupe | 99 M coupe |
03-20-2011, 03:34 PM | #9 |
276
Rep 2,216
Drives: 991 GT3, Sold:'11 e92 M3 SG/FR
So did anyone end up installing this on the Coupe? I used the same euro 1st aid cubbies on my e46M3. Great for sunglasses etc. I was thinking storage on one seat and a fire extinguisher on the other.
991 GT3, Sold: '11 e92 M3 SG/FR ZCP|ZCV|ZP2|2MK|494|415|6NR|752
03-20-2011, 04:50 PM | #10 |
definitivecars.com
354
Rep 3,833
Drives: Elsa - 2015 F80 M3 - YMB/SS
Garage List 2011 E90 M3 [6.66]
2009 (Lease up Sept ... [0.00] 2007 (Lease up 6/19 ... [0.00] 2007 (Lease up Octo ... [0.00] |
I would like to know as well. This would be a great add of storage space. I have plenty of things I would put in there.
But I wonder why it looks as if its only for convertibles. Are their seats different? http://parts.bmwofsouthatlanta.com/p...106971063.html D |
03-20-2011, 05:08 PM | #11 |
276
Rep 2,216
It exists because the verts don't carry the 1st Aid kit in trunk like the Coupe & Sedans do. It should work. It looks like it leverages the same holes that would be used to mount a fire extinguisher bracket. I'm just surprised that no one has tried it yet. Great way to reclaim storage space up front.
03-24-2011, 05:39 PM | #13 |
definitivecars.com
354
Rep 3,833
I almost want the fire extinguisher instead. LOL
D |
03-28-2011, 06:43 PM | #14 |
98
Rep 525
Drives: '21 F95 X5 M C, '11.5 E92 M3 C
I tried ordering this but #3 is not available. Would be nice to have extra storage space for sunglasses and misc items without having to reach for the glove box.
Drives: '11.5 Interlagos Blue E92 M3 Comp, '21 F95 X5 M Comp DIYs: Enable Rear Fog | Easy Side Gill Replacement | Front Grill Replacement |
03-28-2011, 08:13 PM | #15 | |
Commander-In-Chief
2175
Rep 8,942
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
03-28-2011, 08:27 PM | #16 | |
98
Rep 525
03-29-2011, 12:28 PM | #18 |
Commander-In-Chief
2175
Rep 8,942
I still have the one from my E46, which looks the same. Hopefully, it will bolt right up with the proper fasteners.
Edit: Forgot I butchered my bracket - was going to mount it in the trunk.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 Last edited by GregW / Oregon; 03-29-2011 at 10:12 PM.. |
03-29-2011, 10:10 PM | #20 |
Commander-In-Chief
2175
Rep 8,942
10"w. x 3-1/4"h. x 3"/4-1/2"d. (stepped, top is deeper than bottom). Caveat: This is the E46 one; the current one may well be different. In the diagram it does not look stepped in profile.
03-29-2011, 10:28 PM | #21 |
Commander-In-Chief
2175
Rep 8,942
Found it!
03-30-2011, 08:38 AM | #22 |
Time is the fire in which we burn.
Rep 176
