12-05-2023, 07:35 PM | #23 |
1599
Rep 1,120
Drives: 2009 E92 M3 Dakar Yellow II
I think the real sticking point a lot of us have is the dearth of bank account friendly options when it comes to major services and honing or reboring the S65. Bore score scares the shit outta me. Having watched the H2 motor sports video on the special honing process used to expose the silica gave me insight as to why so few options are out there.
Thank you for documenting your rebuild process. |
DrFerry6731.50 |
12-05-2023, 08:13 PM | #24 | |
205
Rep 204
It’s not that complicated to re expose the silica if the machine shop knows a little about what is required. Porsche, Mercedes and most “Crotch Rocket” motorcycles use Alusil cylinders. Alusil cylinders is almost like Carbon Ceramic Brakes. As long as you don’t let it get physically damaged, it will almost never wear out. Just try to keep everything fresh and in spec and you should be good. |
Theodore243.50 S85 builder53.00 |
12-05-2023, 08:27 PM | #25 |
1599
Rep 1,120
Yeah torque plates are pretty much a standard practice right? Weird. May not be really difficult but the tooling and training still don’t come cheap. I’m always envious of guys that have the space and $$$ to do engine rebuilds on their own. Gonna enjoy living vicariously through you. Sorry you had the problem to begin with.
Looking back through the archives in this site and having had Subarus with valve spring issues in my social circle, I get a little worried. |
charliev68204.50 |
12-05-2023, 09:17 PM | #26 |
Field Marshal
6732
Rep 1,829
Drives: '08 E92 M3
Sub'd.
'08 E92 M3 DCT Melbourne Red/Bamboo Beige Leather/EDC/SSP Spec-R DCT clutch discs/SSP Pro-Gold DCT Fluid/Quaife LSD/3:45 Final Drive by Diffs Online/BE Bearings & ARP Bolts/Vibra Technics Engine Mounts/M3 World HFC X-Pipe/LUX H8 180/BPM Sport DCT Tune/PFC Z-Rated Pads/ECS Brass Brake Caliper Bushings/Alex Shop Solid Sub-frame Bushings/Motul 600/Tint
///M Power-Belgium63981.00 |
12-25-2023, 04:00 PM | #29 |
205
Rep 204
Time to order new main bearings! Will definitely send it out to WPC.
I believe Main Bearings are definitely a maintenance wear item on these engines. It seems to wear slightly slower than the RB, but definitely wears. The front of the engine, at the timing chains, takes most of the fatigue! |
01-02-2024, 10:12 AM | #31 |
Field Marshal
6732
Rep 1,829
Drives: '08 E92 M3
I don't think the 'mains' look too bad at all for a 130K miles S65, and 8300RPM capable. What does everyone else think?
01-02-2024, 12:46 PM | #32 |
2318
Rep 5,770
They’re not terrible but more wear than a typical main bearing at 130k miles. 1st main bearing sure takes a beating. Just like rod bearings, main bearings are definitely a wear item but unfortunately there’s no preventative maintenance for mains. Ay least the main wear rate is considerably lower than the rod wear rate.
01-02-2024, 02:12 PM | #33 |
53
Rep 36
There's a bit more wear on the lower thrust bearing than what I'd expect. Pulling the crank was the right move. Visually the wear on #2 lower seems to dispute the theory of excessive chain tension as the actual cause, but we also know nothing about contribution to crank bore concentricity and clearances either.
charliev68204.50 DrFerry6731.50 |
01-02-2024, 02:24 PM | #34 | |
53
Rep 36
DrFerry6731.50 |
01-02-2024, 06:49 PM | #37 |
205
Rep 204
I believe out of three colored bearings, yellow is the thinnest bearing shell. My crank is probably on the thicker side so they decided to loosen the top side to get the optimal oil clearance. Number 2 was most likely real tight, hence the yellow on top and bottom and also the accelerated wear on the number 2 bearing.
01-03-2024, 02:05 PM | #38 |
Field Marshal
6732
Rep 1,829
Drives: '08 E92 M3
How does one tell this intriguing piece of intel from the pics?
01-05-2024, 08:39 AM | #40 |
53
Rep 36
BMW gauges the crank before install and they laser etch serialize the crank as shown, they print what the bearings should be.
The block is also (supposed to be) engraved with the same information, since a tech needs to know and this is viewable without having to drop the pan. There are supposed to be 3 different "colors" or sizes for the tolerance band meausred, Red, Yellow, and Green, most are Yellow or Green. I don't know if BMW has ever published the actual tolerance band. dealer service proceedures are to just replace like with like, no measuring, since that actually takes quite a bit of time and skill. This is why blueprinting matters. Also why putting in a differrent used crank isn't ideal, but literally YMMV. |
DrFerry6731.50 |
01-05-2024, 08:42 AM | #41 |
53
Rep 36
01-05-2024, 11:10 AM | #42 |
205
Rep 204
Can’t find Glyco PNs so I’m just going to order the oem ones from fcp euro. They have lasted me this long with no problems. Another 130k will be fine for me.
01-05-2024, 11:48 AM | #43 |
53
Rep 36
Glyco in the US doesn't sell them direct AFAIK, you/d have to get them via BMW OE. King makes a good solution. Only one size there but they are provide a bit more clearance vs OEM as I recall.
01-05-2024, 12:04 PM | #44 |
205
Rep 204
If my engine were all GRN, I would consider King. I don’t mind Glyco, it’s an old trusted German manufacturer that Mercedes and Audi uses. I wish I could buy it directly from Glyco because it’s $500 a set from BMW!
