TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Coding my reverse mirrors to tilt further down
      06-22-2016, 01:41 AM   #67
ka_rai
Drives: F20 118D
Originally Posted by cn555ic View Post
You have to Nettodat code the values in
without value modification no work ? value is not ° position ?
      06-29-2016, 11:12 AM   #68
aaddam2
aaddam2's Avatar
32
Drives: '11 e90 335d M-Sport
man i wish ICarly had this feature. When I actually got around to using my memory seats, I was shocked that i was unable to also save a reverse mirror position. I had an '03 passat and it allowed you to pick the position of your reverse mirror, not just generically tilt down.
      09-03-2016, 06:33 PM   #69
2fast4
2fast4's Avatar
30
Drives: 2008 BMW 335i
I can't get first step working. From #7 thread:
"-Code using NCSexpert like you normally would and when the Nettodat file pops up, close it out and make a note of the FRM module that is on your car.."
When I load up NCSexpert(with ignition key on), I can't seem to get the Nettodat file or anything come up. I can load profiles etc but Nettodat? No...
I've done a few codings done before successfully...I wanna git her done
      10-17-2021, 01:15 PM   #70
ceri0
M.
France
Drives: bmw 530d
Hello all,
I'm from france and have an e60 without foldable mirror I would like to know if it's possible to activate the mirror inclinaison when Reverse is activated.
Could you please share a Tuto or steps to do in order to get this option ?
Also I would like to have angeleyes welcome when opening the doors,
thanks for your support
      10-29-2021, 01:40 AM   #71
allex29
13
Drives: BMW E91 M47
I used Nettodat coding using NCS for Dummies
Frm2
Fahweg_bordstein_autom
custom value is 5A
Frm3
Asp_weg_bordstein-autom
custom value is 5A
Here are the steps required: Again you should be pretty experienced in coding..
-Load up NCS for Dummies
-Load E89 chassis daten folder
-Look up the module that your car has within that e89 daten
-Load the Nettodat.trc file in the NCSexpert Work folder
-Then the trace editor will pop up at the top of NCS for dummies if you have correctly matched the module and the trc file..Once it reads the entire module..
-Look for the script above that pertains to your module on your car
-Right click on the script line I posted above for your module on your car
-There will be a new custom line, click on it and now in green there is a new entry at the bottom of the script line your coding..click on it and at the bottom change the value to 5A
-After changing it make sure arrow is checked on the new custom value
-Export trace file to nettodat.man ( it will state there is already the same file copy over it..yes)
-Go back into ncsexpert and hit basic functions...use CoapiCodeSgNettodat
-It will then have a box pop up with your module your coding at the top and the bottom part you need to
-Enter Nettodat.man and hit return (make sure ignition is on because as soon as you hit return because coding will begin immediately after hitting return)
Coding will commence and you will see your lighting module reset itself, and then NCSexpert will return back to the page before you went to NCS for dummies...Close out the ncsexpert at this point. Congrats you coded your mirror
to show the curb and the rear passenger tire and basically did what BMW should have done in the first place to make this functionality USEFUL!
Make sure after you close out the NCSexpert to clear your man file or your next coding experience you will run into errors..
Big thanks man!
