11-08-2016, 09:20 PM | #1 |
1121
Rep 1,087
Official Signature Wheel Gallery | Fitment Q&A Thread
Introducing the official Signature Wheel Gallery and Fitment Q&A Thread. We will showcase our wheels in this thread and we will also openly help you figure out the best wheels/tires setup for your vehicle. It doesn't matter if you're interested in Signature or not, we will even use our team of engineers to help you ensure you'll have the perfect fitment. At Signature, we believe in sharing our knowledge and making the car community a better place. We publicly disclosed proven "flush" fitments/offsets/tire sizes on our website and the list will grow as we test fit more vehicles. At Signature, we believe in pushing the fitment limits to be "aggressively tasteful." We call all of this the Signature Movement, so come on in and ask questions... http://www.signaturewheel.com/fitments Who are we? Signature is founded by a group of car enthusiasts who spent years of modding and racing our personal vehicles. We realized when choosing a set of wheels, you have 2 of 3 choices as follow: (1) Reasonably Priced (2) Strong (3) Lightweight. We created Signature so you no longer have to choose, you can have a set of reasonably priced, ridiculously strong, and ultra light wheels. On top of that, we promise our wheels to arrive at your doorsteps within 5 weeks from ordering. No ifs, buts, or ands... We haven't missed our deadline yet, that's a promise we plan to keep. Signature wheels are designed in California and manufactured by one of the top forged wheel manufacturers in the world. We have 50 CNC machines allocated, same factory coating, and a team of engineers to ensure there's no delay on deliveries. Our wheels are machined from the highest grade 6061-T6 aluminum that's been pressed at thousands of ton and heat treated at proprietary temperature. We believe in designs that are strong, light, and timeless. JWL/VIA CERTIFIED HUB CENTRIC ACCEPT OEM LUG BOLTS AND NUTS MAX BRAKE CLEARANCE Our 2-Piece wheels are available with hidden or exposed hardware. If exposed, you can choose the hardware colors to be Black, Raw Aluminum, Gold, or Blue Titanium. OEM TPMS compatible. Optional Center-Lock, Anti-Slip Knurling Bead Tread, and OEM caps center hole. Go ahead, ask us wheels and tires fitment questions... "Leave Your Signature"
Jimmy | BMW Addict | Signature Performance Wheels | OBSESSED WITH PERFECTION | IG: Signature_BMW | Email: jimmy@signaturewheel.com
11-09-2016, 08:18 AM | #2 |
1121
Rep 1,087
Signature SV302 - brushed black barrel, brushed black face, and hidden hardware. 20x9.5 ET15 and 20x11 ET30 - 235/35/20 front and 285/30/20 rear. CATuned Coilovers. More aggressive than our standard recommendation, but the owner Seth loves the look.
11-09-2016, 08:50 AM | #3 |
1121
Rep 1,087
Signature SV102 - Brushed Aluminum - 20x9.5 ET20 and 20x11 ET40 - 265/30/20 front and 295/30/20 MPSS rear. KWV3 coilovers.
Owner: kitw
11-09-2016, 09:35 AM | #4 | |
2176
Rep 4,118
Looks sick! I just got a 11" ET25 for my F82. The manufacture told me there gonna be no rubbing with 285/30 …. ... ET30 is already close to the fender |
11-09-2016, 10:03 AM | #5 | |
1121
Rep 1,087
Here's a better angle of 20x11 ET30 with 285/30/20 (NITTO NT555). NITTO width is between Pirelli Zero and MPSS. As you can see, I don't think there's even 2mm room left let alone 5mm.
11-09-2016, 10:45 AM | #6 |
2176
Rep 4,118
Oh shit ... I want to use my stock 285/30 Michelin tire
I don't want to roll my fenders, camber should be ok, but no fender rolling Another Member is running ET30 with 295/30 http://f80.bimmerpost.com/forums/sho...highlight=Zito F80 and F82 have the same fitment? Front gonna be 20x10 et25 with stock 265/30 Michelin |
11-09-2016, 11:16 AM | #7 | |
1121
Rep 1,087
No mod needed in front, unless you run KW HAS or KW CS then you'll need 3mm spacers front. Rear: you should be fine with cambering in w/o rolling fenders. F80 and F82 have the same suspension/offset. Toyo Proxes 4 have almost the same section width as MPSS. The seller did mentioned it was too aggressive. The black M4 rear camber was in very heavily to fit.
11-09-2016, 03:53 PM | #8 | |
1326
Rep 1,481
Is it even possible to roll F8x fenders? It looks like it's already flat and rolled from factory? |
11-09-2016, 04:12 PM | #10 |
1121
Rep 1,087
How about this angle? Notice the muscular shoulders and sharp angles.
11-09-2016, 04:13 PM | #11 |
6586
Rep 5,305
Rolling the fenders isn't just to flatten the excess sheet metal. A roller can also pull the existing fender out a few mm to make room for a more aggressive tire/wheel offset. Stance bro dudes have been doing this for a long time. Not recommended.
Signature Wheel BMW1121.00 |
11-09-2016, 04:14 PM | #12 |
6586
Rep 5,305
Signature Wheel BMW1121.00 Coloradom3295.00 |
11-09-2016, 04:16 PM | #13 |
1326
Rep 1,481
I consider that pulling fenders, not rolling. Not a fan of pulling fenders but don't mind rolling the inner fender / lip to gain a little more clearance. Pulling fenders makes the fenders look messed up sometimes.
11-09-2016, 04:18 PM | #14 |
6586
Rep 5,305
JamesGames1326.00 |
11-09-2016, 04:26 PM | #15 |
1121
Rep 1,087
Correct. The back quarter is pretty flat, front could be rolled which is pointless with the plastic limning in the way.
11-09-2016, 11:13 PM | #17 |
1121
Rep 1,087
11-10-2016, 08:15 AM | #18 |
1121
Rep 1,087
Signature SV103 in Brushed Black Tinted - 20x9.5 ET20 front and 20x11 ET40 rear. MPSS 265/30/20 and 295/30/20. Eibach Springs.
11-10-2016, 11:43 AM | #19 |
2176
Rep 4,118
11-10-2016, 12:19 PM | #20 |
1326
Rep 1,481
11-10-2016, 12:29 PM | #22 |
6586
Rep 5,305
Tags |
f80 wheel, f82 wheel, forged wheels, signature movement, signature wheel |
