DIY: Spark Plug Change N55 (2011 335i Sedan) Video
04-10-2013, 01:08 PM | #1 |
29
Rep 57
Feedback appreciated. Some advice before you start:
1.) PLEASE USE METRIC TOOLS! This is a European car and guess what measuring system their engineers use? I see other DIY's saying to use SAE or English size sockets and such... It MIGHT work, but you run a big risk of rounding off the nuts/bolts! If you do that, you will need special tools to extract. 2.) Be patient and take your time (2-3 hours). Its tempting to do things right before a run or such, but trying to do a repair under time pressure is not ideal. You run a big risk of doing something wrong and then having to redo it. 3.) Try to do this on a level surface as you are removing a strut brace. And for your own safety should parking brake fail, etc... Here's Part 1 of the video. Takes you all the way through removing the first spark plug. And here is Part 2. Takes you all the way through starting the engine back up! |
04-11-2013, 08:48 PM | #2 |
15
Rep 272
That was a great DIY video sir. I'm sure plenty of us on the forum will use it!
Afe Stage 2 Magnum Intake - Custom SS Exhaust - AG M359 Staggered - CF spoiler
03-02-2014, 07:06 PM | #4 |
157
Rep 1,409
Excellent DIY. Congrats! Really helpful as Im lining up to do this soon.
2011 X3 35i with M pack + 2011 135i w/6SPMT | 255 square tire setup | Quaife 3.46 LSD | Diff lock down bracket | Bilstein B8+Swift SpecR springs+H&R FSB | CDV delete | BMS Oil Tstat bypass | ER FMIC & CP | N54Tuning DP | GC Street Camber Plates | M3 FCA +guide rods+RSFB's+Tranny mounts | Manzo toe arms | Cobb Stg2 agressive tune | Hawk DTC70 brake pads | RB SS brake pistons | Goodridge SS brake lines | Custom brake cooling ducts
03-04-2014, 11:46 AM | #5 |
Autobahn Addict
22
Rep 173
Drives: '11 E92 N55 6MT Msport
Excellent video!
I want to add that I always cover the pipe going down to the turbo after you removed the air intake at 3:10. If anything falls down there you are screwed. I use a plastic bag and a tie wrap.
defi boost gauge in custom 3d printed pod, jb4, bms cdv/cs, er cp, vrsf 7" ic, m3/poly diff/tranny mounts, st coilovers, cyba 3.8 tips
11-10-2016, 02:35 PM | #6 |
Rep 103
Excellent DIY - many many thanks.
One hiccup - I thought I could use my existing 14mm spark plug socket. WRONG! You need the thin walled 14mm socket. AutoZone Part No. 72-376. |
11-11-2016, 03:42 AM | #7 |
624
Rep 3,200
Drives: E92 325i MSport Coupe
Also worth bearing in mind that if your cylinder head spark plug access passage has the 'kink' shown in this video, you may like to think about using an articulated socket:
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
01-14-2017, 08:17 PM | #8 |
55
Rep 157
Drives: 2011 E90 6MT 335i
Old post but deserves appreciation since I used these vids today to change my plugs. First time I've done it to any car and this made it extremely easy.
01-15-2017, 05:26 AM | #9 |
Rep 103
04-29-2017, 03:11 PM | #10 |
DSC OFF
23
Rep 181
Drives: 2011 135i, N55, 6MT, MPK
Thanks for the video, attempting later this afternoon on my 135i! Does anyone know what the exact etorx socket sizes are for the strut brace bolts?
05-31-2017, 08:32 PM | #11 |
23
Rep 88
Thank you for this DIY, just changed the spark plugs in my 135is using this. Was pretty easy, just take your time people!
2020 F97 X3 M Competition Donington Grey
Retired: 2018 G01 X3 M40i Carbon Black Retired: 2018 F80 M3 Individual Blue Retired: 2013 E82 135is Carbon Black Retired: 2007 E90 335i Silver |
06-03-2017, 05:18 AM | #12 |
480
Rep 1,600
Definitely use a wobble extension. I prefer the skinny Ko-ken ones. The risk of cracking plugs using straight extensions is too great.
Strut brace bolts are supposed to be disposable items. ie they are a torque plus angle bolt. Usually i just put a 2ft breaker bar on them |
07-12-2017, 10:35 AM | #13 |
78
Rep 290
Doing this soon. This will be a great help!
2011 E92 335i xDrive M-Sport
MHD 93 Stage 2+ | xHP Stage 3 | xDelete | Catless Downpipe | Phoenix Racing Intercooler | ARM CP | AFE Drop In Filter |
11-06-2019, 05:43 AM | #16 |
Rep 103
I used this DIY again this past weekend to replace my spark plugs. Heads-up: be sure not to pinch the windshield wiper wiring harness when reinstalling the right strut brace and bolt. I pinched it when tightening the bolt and severed one of the wires. Didn't know this until I tried to use my wipers. Soldered-in a splice wire and all is good now - easy fix but frustrating.
