04-27-2019, 03:56 PM | #1 |
398
Rep 1,519
Lug bolt torque now 140 Nm
Thanks to forum member Tag who posted the online version of the M2C manual, I’ve been dong some reading while waiting for my car to arrive in a couple of months. I noticed that BMW’s recommended wheel lug bolt torque is now 140 Nm (101 lbs-ft). For as long as I can remember, BMW’s recommended lug torque setting has been 120 Nm (88.5 lbs-ft). Not sure when BMW changed this value, but I’m glad I noticed it. Heads up for anyone who’s had past BMWs like me and assumed 120 Nm was still correct.
Past: E46 330Ci, E60 545i, E60 M5, E90 M3
Present: 2020 M2 Competition, 2022 GT3 |
04-30-2019, 12:13 PM | #6 |
319
Rep 660
04-30-2019, 01:20 PM | #7 |
234
Rep 350
My understanding was that when BMW switched to M14x1.25mm threaded lugs that the torque spec changed. With my 2014 228i the spec was 103lbs/ft (unfortunately not printed in the manual, I think it was in service manuals), my 2017 M2 states 101lbs/ft in the manual. I think all F-series use the M14x1.25mm thread while E-series use M12x1.5mm (exception apparently being E70 X5, they use M14x1.25mm).
The M12x1.5mm has a lower spec, I've worked on a 2000 E39 which is 88lbs/ft and a 1998 E36 which specifies 74 lbs/ft (!!! this seems really low to me so I have usually gone a little higher at 78lbs/ft). The proper torque spec is going to depend on the thread and materials, with the M14x1.25mm I think you probably want to stay in the 100-105lbs/ft range while M12x1.5mm is 80-90lbs/ft. |
05-03-2019, 01:39 AM | #8 |
725
Rep 929
Drives: 2019 F87 M2C, 2023 G87 M2
I've never torqued a lug nut in my life! Always gone by feel. Why is a number different by a few Nm so important?
05-04-2019, 02:46 AM | #9 |
7364
Rep 7,318
Judging by the number of shops that tighten them to 9999 ft-lb with an impact gun, I’d say you’re fine exceeding 100 as long as you can get them off and you’ve tightened them in a star pattern and equally. I tighten mine 10% over the spec because my wrench is cheap and rather be a little over than under.
They probably won’t fall off at 80 either, who knows why they changed the spec slightly. |
05-04-2019, 12:50 PM | #10 | |||
398
Rep 1,519
Same with tire pressures. I brought my OEM Audi S3 wheels to Mavis Tire the other day to have the winter tires switched back to the stock PZeros in preparation for lease end. When I got home I confirmed pressures before sticking them in the garage. Three tires were at 40ish psi (fine) and one was at 75 psi. You can't make this stuff up.
05-05-2019, 10:56 AM | #11 | |
861
Rep 923
05-05-2019, 04:51 PM | #12 | |
375
Rep 428
05-05-2019, 05:11 PM | #13 | |
861
Rep 923
10-28-2019, 01:33 PM | #14 |
2660
Rep 448
Sun Motors in PA recommended 120 nm, they just did this last week on another M2C with the same winter wheel setup 641m staggered setup
They disregard the 140?!? Maybe the 140 is for the stock wheels? Confusing |
10-28-2019, 03:54 PM | #15 |
1717
Rep 1,899
More likely they made a mistake. Take into account they have to support lots of different BMW models from many different generations. Mistakes can happen. Can't refute solid text in a manual
10-28-2019, 05:37 PM | #16 | |
2660
Rep 448
another store "what ever you want man" lol, seems not to matter much AND these are Bmw service advisor(s) tight'ish is fine ?!? Btw, never had any vehicle that I needed the lugs torqued to spec until now or ever cared to confirm the spec on Edit: simple answer I'm going with 140 nm on my 19 m2 |
10-28-2019, 06:01 PM | #17 |
342
Rep 396
Several of you have noted it already but it's to do with the diameter of the wheel bolts. Bigger diameter = more torque required. Hence the change from M12 to M14 bolts has lead BMW to a revise their torque specification from 120Nm to 140Nm.
140Nm is actually on the conservative side for what a grade 10.9, M14 bolt is designed to handle. As usual, all this stuff can be found with a quick web search. [IMG][/IMG] Realistically, the correct answer is "tight enough not to come undone but not too tight to strip the threads". But being German, they like specifics. Therefore 140Nm it is. |
Killed by Death12773.00 |
10-28-2019, 11:10 PM | #19 |
1919
Rep 2,138
Those with wheel locks from the dealer, check them if they’re torqued properly.
I noticed all 4 of mine were hand-tightened at best. Came loose with minimal amount of force. I re-torqued every bolts to 101 lbs/ft |
10-29-2019, 01:31 PM | #20 | |
323
Rep 393
https://www.metric-conversions.org/e...oot-pounds.htm |
10-30-2019, 08:45 PM | #22 |
398
Rep 1,519
