Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > DIY and Coding Discussions
      03-09-2015, 10:32 PM   #23
tom @ eas
BimmerPost Supporting Vendor
tom @ eas's Avatar
8215
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Good catch! Edited OP, thanks.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      03-09-2015, 10:36 PM   #24
NorCal f80
346
Drives: M3
I just want to stab the tail lights of the cars I see with rear fogs on. UGGGGGGGGGGGGH
      03-11-2015, 09:28 PM   #25
nene
nene's Avatar
137
Drives: Various
2015 BMW M4c  [9.00]
You should probably stay away from sharp objects then...You may hurt yourself!
I doubt I'll ever use this feature. Just could not resist this DIY.
      03-21-2015, 09:13 PM   #26
gtrsam
224
Drives: 2015 m3
edit nm worked
      03-23-2015, 04:42 AM   #27
Chan
66
Drives: 2015 BMW M4
Originally Posted by nene
Took a couple of snaps to post here, in case my details sounded confusing. Nevertheless, Tom's snaps from the original mod were extremely useful in getting this mod completed, and giving me the idea to try to pry the buttons off without having to remove the vent.
One thing I also found was a small mistake in the coding Tom. You have it showing both left hand side entries. Here is the correction:
REM -> 3063 -> Mapping_Nebelschlussl_L_output (Value = nsl_l)
REM -> 3063 -> Mapping_Nebelschlussl_R_output (Value = nsl_r)
This little trick worked perfectly. Thanks for sharing and thanks EAS for starting this thread!
      03-23-2015, 07:34 AM   #28
Mr. Hankey
Christmas Poo
Mr. Hankey's Avatar
1029
Drives: Incoming G87
Thanks for the tip as well Tom.
Even if you don't use the rear fogs as "fogs" I found they provide quite a bit of extra light when backing up at night....about 5 times as much as the regular backup lights.
Read...no drive, the manual.
      03-25-2015, 03:17 PM   #29
gtrsam
224
Drives: 2015 m3
Added a sticker to mine
      03-25-2015, 03:32 PM   #30
tom @ eas
tom @ eas's Avatar
8215
Drives: BMW
2018 BMW i3s  [5.00]
2010 BMW M3  [6.50]
2015 BMW M4  [6.20]
Fixed:
Turned out pretty good!
      03-25-2015, 05:23 PM   #31
vstM3
vstM3's Avatar
84
Drives: 2015 F80 M3
Fixed:
Where did you get the sticker?
Current: 2015 BMW F80 M3
Retired: 2012 BMW 335is
Other: 2014 Mini Cooper
      03-25-2015, 07:11 PM   #32
gtrsam
224
Drives: 2015 m3
thanks tom!
I made the sticker. I do vinyl cutting for a living. I was actually thinking cutting a stencil then painting it on with a touch up pen but this ended up working just fine.
      03-26-2015, 05:55 AM   #33
vstM3
vstM3's Avatar
84
Drives: 2015 F80 M3
thanks tom!
Send one to me
      03-29-2015, 12:16 PM   #34
E92FI
E92FI's Avatar
24
Drives: F80 M3
How's everyone coding this from home?
      03-29-2015, 02:00 PM   #35
gtrsam
224
Drives: 2015 m3
coding cable $20 and free software
      03-29-2015, 02:10 PM   #36
E92FI
E92FI's Avatar
24
Drives: F80 M3
Any links that would help?
Thanks
F80 AW Blk- MPE Front Lip/Splitters
2021 L405 ATB Fuji White - Pimento Seats
      03-29-2015, 06:49 PM   #37
gtrsam
224
Drives: 2015 m3
Thanks
got mine off eBay. search f80 coding cable. It's the first one that shows up. it's the red enet obd2 cable
the seller will also provide links and instructions for the software
      03-29-2015, 11:56 PM   #38
mdrobc13
mdrobc13's Avatar
341
Drives: Made in Bavaria
2021 BMW X3e  [0.00]
2016 BMW M4  [9.00]
Me too..used the painters tape on a knife edge and it popped out easily also. Question. Does the button push in and stay detented or is it a push and then return back to normal position? Mine moves easily enough after removing the tabs and was easily reinstalled.
Now to figure out the coding part. That has given me a bit of confusion this afternoon. Is there a coding for beginner's guide or something that explains step by step how to move thru the E-Sys menus.
'22 BMW M4 Comp (SSG/Black)
'16 BMW M4 (Shakir Orange/Black) - gone not forgotten
'15 BMW M3 (Black/Black) - gone not forgotten
'10 BMW X5M (Black/Black) - gone not forgotten
'08 BMW M3 (Space Gray/Black) - gone not forgotten
      03-30-2015, 12:24 AM   #39
E92FI
E92FI's Avatar
24
Drives: F80 M3
Thanks
Awesome thanks
      04-22-2015, 08:38 PM   #40
CanAutM3
CanAutM3's Avatar
21117
Drives: 2021 911 turbo
Your trick worked like a charm. Took me less than 5 minutes to get the whole thing done.
Now I just need my coding cable to get here to complete the job
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black
      04-22-2015, 09:24 PM   #41
nene
nene's Avatar
137
Drives: Various
2015 BMW M4c  [9.00]
I bought the cable from a forum member which was also available on eBay. It came with instructions on how to install the software and run it.
I used a PDF I found on the internet on how to do your first coding mod to get my feet wet and comfortable to proceed with others I eventually found available.
First Coding Instructions
      04-24-2015, 08:50 AM   #42
FandIGuy
Drives: 2015 BMW M3
I performed this mod on my E92 and loved the safety benefits it offered. With the rear fogs illuminated, I would always feel much safer when driving in heavy rain storms or across foggy bridges like we have in my city.
With the E9X you could purchase the OEM rear fog button to give the mod a factory appearance.
Does anyone know if the F30 headlight switch is swappable with our cars? I couldn't imagine it being incompatible so I did a Google search for "F30 rear fog switch" and found this...
http://www.ecstuning.com/ES2771030/?...7lZBoCHJvw_wcB
Now if we could buy JUST the button cover then we're in business.
      05-01-2015, 07:25 AM   #43
vstM3
vstM3's Avatar
84
Drives: 2015 F80 M3
I must have coded some other place these settings, because in REM the settings were already active. And now, headlight and taillights are on all the tine when the switch is on auto. :
      05-01-2015, 08:08 AM   #44
Warranty P
167
Drives: F83
Your sticker is facing the opposite way, it indicates front fog lights right now.
f80post
