09-13-2023, 04:04 AM | #1 |
3437
Rep 4,057
Nit Picking the X3 M - Volume 1 (those with lowering springs)
I've always noticed that the fender gap on my right rear tire is higher then the other 3 corners. Therefore, are any of you guys who have lowering springs OR factory springs too for that matter noticing and/or experiencing this same thing / issue... ?
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten 2011 E90 335i M-Sport - Daily Driver 2017 F87 M2 - Sold & missed 2020 F97 X3 M Competition - Finally arrived /// |
09-14-2023, 02:05 AM | #2 |
3437
Rep 4,057
97 views... And not one single comment. LOL
09-14-2023, 09:02 AM | #3 |
20
Rep 40
What lowering springs? If they are non adjustable I'd say there is some sort of install error somewhere. Have you measured the gap on level ground to confirm the difference?
09-14-2023, 09:18 AM | #4 |
105
Rep 53
Drives: X3MC
What springs, how much higher? Keep in mind fuel tank placement and fuel level, also be sure ground is level. Maybe try backing vehicle into same position and re measure all 4 corners and see if notice any changes from side to side.
doooooooook31.50 |
09-14-2023, 12:33 PM | #5 |
32
Rep 29
Check again after a full tank of gas
ThirstyX3M105.00 Potatohead-M2220.50 |
09-15-2023, 12:41 AM | #6 |
3437
Rep 4,057
DINAN springs which are pretty much rebranded Eibach's from what I've heard. Had a top notch shop do the work & the alignment specs are dialed in to a razors edge.
Was really hoping that others (weather the X3 M is lowered or not) would have some more concrete feedback on if they're experiencing / noticing this same thing.
05-07-2024, 10:01 AM | #7 | |
Rep 8
As i know,dinan is different with eibach eibach wire diameter lenght number of coils Front 14.8mm 256mm 4.5 Rear 14.5mm 297mm 8 H&R wire diameter lenght number of coils Front 14mm 260.5mm 4.4 Rear 14.75mm 292.1mm 7.7 Dinan wire diameter lenght number of coils Front 15.5mm 247.7mm 5.5 Rear 15.5mm 273.1mm 8 |
05-07-2024, 10:52 AM | #8 | |
219
Rep 218
05-07-2024, 02:08 PM | #9 |
39
Rep 41
Not going to be of much help, but I had this issue on my G20 M340i. Never figured out what the problem was. I noticed the height difference in one corner even on stock suspension. Figured lowering springs would take care of it, but it didn't. Then I bagged it. Lol. Never had that issue again afterwards. But like I said, I never figured out what the actual issue was, if there was even an issue to begin with. I feel like all corners should be equal when the car isn't loaded up with stuff of course.
Kevin_The_Clean13436.50 |
