01-15-2019, 12:47 PM | #67 |
1148
Rep 2,877
Drives: Anything
01-15-2019, 12:56 PM | #68 | |
60
Rep 932
I changed gas to Union 76, Mobile, and Valero from Chevron. I used Chevron exclusively and see if there are any changes with sodium. I am due for an oil change once rain stop here in NorCal. |
01-15-2019, 02:39 PM | #69 | |
#buildnotbought
11005
Rep 4,912
The fan blows agains the middle of the block. The stock intake sits in front of the radiator, so thats impossible, unless you poored it in. A csl airbox or such sits way at the side, also very unlikely. Especially at a minor leak. It would also mean your air intake sucks out masses of air from the engine bay, especially hot air as air coming from the fan is per definition hot (as I said, the fan blows towards the center of the engine block) instead of drawing air in from the outside. My guess, if you really have elevated levels (maybe you use oil with some sodium), and it is related to coolant, it has to come from a gasket leak. But my guess is that other factors are just as likely. Driving in salt air, roadsalt elevated sodium level in the oil itself or such. I also think that if there would be coolant in the oil, not only sodium but also the potassium level should rise.
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
01-15-2019, 03:26 PM | #70 |
1148
Rep 2,877
Drives: Anything
Doesn't look like BMW coolant have potassium, if I'm reading the MSDS correctly
01-15-2019, 03:42 PM | #71 |
#buildnotbought
11005
Rep 4,912
hmm yeah looks like thats potassium free (at least in high quantities). So trace elements of potassium might not be the best marker.
I looked up some more and they mainly contain sodium based salts, although it seems that each manufacturer uses different ingredients, sometimes displayed with "Aqueous solution of inhibiting salts" rated "not classified, so that could be anything really as long as its not harmful. Some do seem to contain potassium (like potassium ethylhexanoate and such) but certainly not all coolants indeed. Its a very mixed bag. But it would still be bad if hot air from the fan and engine would reach the intake. Usually everything is done to prevent that, so I still think that there are numerous other ways sodium can get in an oil analysisreport.
XMetal1148.00 |
01-15-2019, 03:48 PM | #72 |
60
Rep 932
I'm not sure about coolant leak is the caused. I noticed it went down a bit after replacing radiator. At this time, I am checking if it is fuel additives by switching fuel brand.
01-15-2019, 04:10 PM | #73 | |
1148
Rep 2,877
Drives: Anything
Another trend that I've noticed is that most of the S54s that have high sodium readings are Z4Ms...just another datapoint. |
01-15-2019, 04:55 PM | #74 | ||
60
Rep 932
01-30-2019, 10:12 AM | #75 |
60
Rep 932
My Blackstone report for sodium is a bit lower with one fill up of Chevron gas. I will use one specific brand near my house exclusively and check sodium level on next analysis.
https://www.dropbox.com/s/eo9umpiy91...oupe.pdf?raw=1 Last edited by RobMCoupe; 01-30-2019 at 10:23 AM.. |
XMetal1148.00 |
01-31-2019, 10:28 AM | #76 |
1148
Rep 2,877
Drives: Anything
Thanks for the follow up, Rob! It looks like my sodium level may get a lot worst before it gets better if it follows your trend. Like you, I will try to stay away from Chevron for this oil change interval to see if that may be a factor. Glad to see that at least sodium is starting to drop on your analysis and hopes that it keeps following that trend!
03-06-2019, 08:54 PM | #78 |
your average JAMF
3170
Rep 4,106
Drives: '21 M2 Comp, '19 Golf R
^^ those look pretty good for 58k, no?
'21 M2 Comp
'19 Golf R |
03-06-2019, 09:31 PM | #79 |
1148
Rep 2,877
Drives: Anything
It looks good if 100k, not 58k. You would not expect to see copper for less than 60k
JimBob0047270.50 GuidoK11005.00 |
04-08-2019, 09:37 AM | #81 |
1148
Rep 2,877
Drives: Anything
This is really your preference. I don't believed there's a big enough difference to justify the extra cost. No one had complained about the OE bolts and I had not heard a single thing that's wrong with the OE bolts. If ARP was really that superior, I'm sure Lang would have pushed for those when I had mine done, but he didn't.
JimBob0047270.50 |
04-08-2019, 09:46 AM | #82 |
61
Rep 116
Drives: Z4M
That's pretty much what I thought. If I were planning on another bearing change I would go with the ARP because they can be reused.
04-17-2019, 05:03 PM | #83 |
61
Rep 116
Drives: Z4M
Does the tri-armor coating have to be removed from the parting lines before install on the be bearings?
04-23-2019, 06:26 PM | #84 |
61
Rep 116
Drives: Z4M
Done, pretty bad wear 63,000 miles And you don't remove the coating from the parting lines. Direct from BE bearings.
04-23-2019, 06:46 PM | #85 |
1148
Rep 2,877
Drives: Anything
Yike
Glad to see you got this taken care of |
02-11-2020, 04:53 PM | #87 |
1148
Rep 2,877
Drives: Anything
Looks like my WPC treated bearings are wearing-in nicely I also decide to add a can of Ceratec to "coat" the new bearings on this sample since they appeared to work so well the last time I had used it...so the results you see here are from Castrol 10w60 with Ceratec added.
One interesting note, my sodium reading has dropped for whatever reasons The only change I had made (from the previous 2 samples) was a change in filling-up habits - going from mostly Chevron 91 to Shell 91. I will continue to trying to stick with the Shell blend this year to see if it will further reduce those sodium levels. Last edited by XMetal; 02-11-2020 at 05:08 PM.. |
wdb4754.00 JimBob0047270.50 |
