      03-25-2014, 07:11 PM   #1
e36addict
137
Drives: 2013 X1 35iX
Anyone know what the inside of the PE muffler looks like?
I bought a spare muffler.. decided to cut it apart and make a project out of it. I pulled all the glass out of it.. not sure if I want to try it like that, or try to weld solid pipes in place of the perforated pipes.. I figure that is probably what the difference is with the PE..
13 X1 35iX, 98 Z3 2.8, 01 M Coupe, 96 Z3 1.9 DASC, 95 318ti, 13 smart fortwo
      03-25-2014, 09:47 PM   #2
stuggy
133
Drives: F80 M3
I have been interested in doing something similar because I want the sound of the performance exhaust but not the price haha. I believe there was a post awhile back where someone cut open a bmw performance exhaust on a e92 335i. I'm sure there is difference between the 335i perf exhaust and the 135i perf exhaust, but maybe you can take some ideas from that. I'll try to find it. Good luck with though
      04-03-2014, 09:50 AM   #3
e36addict
137
Thought I'd update this in case anyone's interested. A friend with an e92 M3 gave me the idea of wrapping the perforated pipes instead of welding. Much easier and fully reversible.. sounds much deeper, the video does it no justice, and got cut off for some reason..
135i N55 OEM muffler mod:
Today I was able to look inside the pipes of a PE with a boroscope, turns out that it has the small perforated pipe intact, but the pipe with larger holes is just straight. Explains why mine is a bit louder and deeper than the PE.
      04-03-2014, 10:44 AM   #4
c_ozanich
Mech Engr
c_ozanich's Avatar
82
Drives: 2011 135i 6MT
Sounds great man; looks like you did a good job on it. Thanks for the info! I was debating about PE but hard to justify seeing this.
      04-03-2014, 11:58 AM   #5
edisapimp
Civil Rights Activist
115
Drives: E46 Sedan, E88 Vert
That sounds very very good! Nice work!
I know it's back together already but this would be a wicked good DIY for people who want to get that sound!
Did you put the glass back in? How did you close the muffler back up, just welded it?
E88 Crimson Red Vert MSport 6MT - Listing your mods in your signature is lame.
BMS DCI/MHD E30 Flash!!/AA Sport FMIC/VRSF CP w Tial BOV/VRSF 3" DPs/550i clutch w SPEC SMFW/Apex EC-7s/Whiteline RSFB/E92 M3 FCAs/Bilstein B12 Pro Kit/VRSF inlets
      04-03-2014, 12:32 PM   #6
e36addict
137
Thanks man. I had a muffler shop weld it back together for $30, then I ground down the welds so it's smooth. (muffler shop welds weren't too pretty)
edit: and yes, I did stuff all the glass back in. Figured it might sound gross without it..
      04-04-2014, 10:58 AM   #7
Joaco135
Joaco135's Avatar
178
Drives: 2020 M2C LBB
Any drone with this set up?
      04-04-2014, 12:17 PM   #8
e36addict
137
Slightly more than a PE, but nowhere even close to the Berk race I had.
      04-04-2014, 04:23 PM   #9
edisapimp
115
I love things like this. I think that is so cool. It's the type of thing that could become a cult DIY mod for E8x. "Quick, everyone grab up all the spare N54 and N55 mufflers!" hehe
      04-04-2014, 08:41 PM   #10
805beemer
23
Drives: 2008 135i
Did you just use header wrap and some big worm clamps? Sounds really good! So you think if I only wrap the pipe with the big holes it will sound closer to a PE?
      04-05-2014, 10:32 AM   #11
e36addict
137
Yep. I used stainless clamps that you would use for headers, but if I were to do it again I'd just use worm clamps. It would be easier and probably tighter. And yes if you just wrapped the pipe with large holes it would sound just like PE
      04-05-2014, 12:57 PM   #12
805beemer
23
Drives: 2008 135i
Awesome thanks! Is the pipe with the large hole dimpled/dented or is that just from the angle of the picture? Also did you just use a grinder and cut off wheel to cut it open? Would you recommend I cut off the whole lid or just the center section?
      04-05-2014, 07:23 PM   #13
e36addict
137
Probably just the angle of the pic.. I'd just cut the center section out, only reason I cut the whole thing was to see what's going on in there. One thing though, one of the holes is in a tough spot right at the bend, and it's impossible to cover the whole thing... might be able to get someone to weld that one up if it's a worry.. also I'd make sure to do the golf tee mod with this.. if the flap closed, the backpressure in the pipe may cause some damage to the wrap.
      04-07-2014, 02:02 PM   #14
805beemer
23
Drives: 2008 135i
Ok thanks. So the pipe with the large hole has more than one hole? Bought the header wrap today so if I get off work early enough I'll start cutting it open. Is the muffler SS? I know you can't just use any old welder on stainless. If not I have a buddy that has a welder.
      04-07-2014, 02:20 PM   #15
Dackelone
European Editor
Dackelone's Avatar
Germany
10626
Drives: N54 e82
@e36addict sorry I have never seen pictures of the inside of the PE. But a friend of mine cut open his 1M's mid pipe resonator. He was gonna weld up the resonator - for a louder exhaust note. When he cut it open he found that BMW beat him to it! This is why the 1M has so much drone and why when you install N55 mids on a 1M, the drone goes away.
Name:  N54T mid pipe fake     Midpipe-Mittelschalldaempfer-Original-BMW-N55-N54-135i-1M-High-Flow-Versi.jpg
Name:  N54T mid pipe fake      Midpipe-Mittelschalldaempfer-Original-BMW-N55-N54-135i-1M-High-Flow-Vers.jpg
Matticus913483.50
      04-07-2014, 08:01 PM   #16
spain4065
18
Drives: EM1 and 08 135i
Sweet mod, can you take a video of from inside the cabin doing some pulls?
      04-07-2014, 10:46 PM   #17
trainerjon
trainerjon's Avatar
51
Drives: 2011 BMW 135i M package
Ahhh, so that's what you did with my muffler. Nice work man!
'11 135i M-Sport DCT, M3 RSFB, PPK, CP, BMS intake, Agency Power Axle Back, VRSF 5.5" FMIC, FSB, M3/M1 Front + Rear Control Arms, Ground Control Coilovers, Ground Control Camber Plates, E92 M3 Front Seats, VMR 701's Squared 255's, E92 M3 Steering Rack - Daily Driven, Occasionally Tracked - 157k miles <SOLD> >2021 HS M2C Manual
      04-08-2014, 05:17 PM   #18
e36addict
137
Yes I think there are 3 large holes. The muffler is stainless, so ideally need to use a tig. But I had mine welded at a shop with a bird-shit welder, that's why I had to grind them smooth to look decent. It's not too bad..
Haha yep, I had been looking for a spare for a while to make a project out of as if I don't already have enough projects...
      04-08-2014, 07:43 PM   #19
805beemer
23
Drives: 2008 135i
Started on it today. Dropped muffler, cut the lid. Wrapped just the pipe with the large holes. Brought it to the muffler shop. Have one other quick mod I'm going to have him do when I go pick up the muffler. Driving around without a muffler currently. It's actually not THAT loud.
      04-08-2014, 11:19 PM   #20
e36addict
137
What's the other quick mod? I'm excited to hear this! Glad someone else is tearing into it.
      04-08-2014, 11:57 PM   #21
805beemer
23
Drives: 2008 135i
I see you already deleted your resonator, so for you it won't be of any use. But when I removed the muffler I could see inside the resonator. The only place it looked like it had holes was after the y junction in the straight piece. So my plan is to either have him tack all the holes. Or slide in a piece of very thin pipe so exhaust flow isn't affected to much inside the res and tack into place to block all the holes. Hoping it works out and sounds very similar to the PE.
      04-09-2014, 11:13 AM   #22
e36addict
137
Nice. After I put the res delete on, I noticed this inside the resonator, and thought about the pipe method. If the pipe was just the right size it would work beautifully.
1addicts
