2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning MHD Flex Fuel Kit, mixing E85 with 91oct B58
      10-29-2023, 10:34 AM   #1
nrg2k
Nrg2k
nrg2k's Avatar
75
Drives: 2018 F22 ZF M240i
2018 BMW M240i  [9.75]
Hey forums,
I live in AZ, we have pretty poor fuel to choose from out here. Highest pump gas is 91oct, sometimes you can find 100oct. I want to start running E40 as I got the TU Pump for my F22 240. I’ve been considering buying the MHD Flex Fuel kit for the convenience factor, but if I remember right I seen a Kern417 video where he mentioned the kit doesn’t read 91 Oct. Is that still true? Would I just limited to Stage 2, and not stage 2+ because I can’t mix the E85 with 93?
Also, if I were to throw 100oct in the car, would the MHD Stage 2+ 95oct OTS tune be safe for the fuel I am running?
      10-29-2023, 07:18 PM   #2
n55david
Check out my Youtube @n55david!
n55david's Avatar
1297
Drives: 2017 m240i, 2015 X3 x35i
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
Originally Posted by nrg2k View Post
Hey forums,
You can mix e85 with your garbage 89 (fake 91).. you just have to use more e85 to compensate.. you'll wanna run about e45 to run the e40 mhd map.
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      10-31-2023, 06:49 AM   #3
marcthedark
120
Drives: M240i xdrive Convertible
But the OP wanted to use the flex fuel kit. That obviously measures E in the tank but not if the rest is 93 or crappy 91 > will the timing be OK as the Arizona 91 might lead to pull
      11-01-2023, 11:58 PM   #4
SpencerC_6MT
SpencerC_6MT's Avatar
199
Drives: '17 M240i 6MT
2017 BMW M240I  [0.00]
I've ran E30 on my stock tune (with a boost controller) just to make the 93 setting run smooth. I'm tempted to suggest you just run an aggressive 93 tune on E40 and go back to a 91 tune when you can't get your hands on E85.
2017 BMW M240i 6MT Slicktop | Wavetrac 3.46:1 Limited-Slip Diff - DinanTRONICS Sport Boost Controller - H&R Sport Springs - Millway Street Camber Plates - Agency Power Intake w/ Paradigm Engineering Turbo Inlet
      03-17-2024, 09:09 AM   #5
cooolone2
cooolone2's Avatar
637
Drives: 20' M240iX B58, 01' 330XI E46
Could order a 55gal drum of Race Gas (Sunoco) and mix that too... Proper ratios to obtain a 95 even or higher if racing and want max benefit (with tune). Lol
      03-17-2024, 07:41 PM   #6
dradernh
dradernh's Avatar
4464
Drives: 2017 M240i
I carried a 55-gallon drum of Sunoco leaded 116 octane when I ran an autocross car tuned for it. Nothing to it, really, when you have a pickup and are towing the car.
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro;
GTechniq Crystal Serum Ultra Ceramic; Suntek PPF
      03-19-2024, 10:58 AM   #7
marcthedark
120
MHD released a 2plus 91 map > so you can use 91 and MHD should adjust accordingly when you add E
      03-27-2024, 01:07 PM   #8
Dantesboyz
recovering e36er
Dantesboyz's Avatar
68
Drives: 2017 M240i Xdrive
Use a couple ounces of boostane to correct the unleaded then add the ethanol to E target.
That's my fix when I suspect bad octane in the fuel.
I use this app (android) when calculating Emix
https://play.google.com/store/apps/d...anolCalculator
And I also have an Ethanol Content Analyzer.
In the F22, I get the most accurate mix by calculating the tank to be 12.8 gallons instead of 13.
2017 F22 M240i, Xdrive, M Performance Package
Active Autowerke Downpipe, Dinan Carbon Fiber Intake, Dinan Carbon Fiber Turbo Inlet, Dinan Mid-pipe, xHP Flashtool, MHD Stage 2
To do next list- #1- Wheel Spacers & Tires, #2- B58 TU Pump, #3- Flex Fuel Kit
2addicts
