12-30-2018, 09:46 AM | #1 |
Rep 14
Headlight Condensation
Hey guys -- New BMW owner here. Just got a 2011 535i xDrive.
I've been reading old thread about the apparently very common issue of headlight condensation. My driver's side headligt is full of it. My plan for now is to use the hairdrier method to clear out what's in there and to tape some silica gel packets in the round assembly cap. But I do have one question about the drying part -- If I'm just going to blow hot air in the casing from that initial round opening, do I need to remove the bulb in order to let the air freely go into the face of the headlght where the moisture is? The videos on You Tube imply not to, but how will the hot air get in the casing? There is also the option of heating the casing from the outside. Has anyone tried that and can that solve it? I know this won't fix the problem permanently, but if I can get this water out now I can live with some occaisional maintenance. The outer casing has a very subtle crack (can only see it up very close) which is where the moisture is probably coming from. Thanks in advance for any input.
12-30-2018, 10:16 AM | #2 |
82
Rep 217
I have Done this a couple of times since I really don't have the desire to pull and reseal the headlights. Just pull the round black plugs and let her run until it's dry. Mine stay condensation free if I just leave the caps off. If I put the caps on the will gather moisture again.
Is there a reseal your F10 headlights DIY? I run without the caps these days. |
phatchuck2.50 |
12-30-2018, 10:26 AM | #3 | |
Rep 14
10-28-2022, 06:41 AM | #5 |
Rep 1
No usual caps on my headlights
Hi Guys,
I'm having the same problem with the condensation but there is a thing. There are no usual caps as seen on other people pics. Mine looks more like in the attached photo. Does anyone know if this is removable? |
11-08-2022, 04:56 PM | #6 |
Rep 10
07-01-2023, 09:50 PM | #7 |
1777
Rep 439
Drives: 2016 F10 BMW 535i M Sport
I have a similar issue with the driver side on my 2016, I may possibly have to replace a module or some part of the entire assembly because I got the adaptive light fault. it condensates quite a bit.
